bowtiepwr
04-19-2003, 02:46 PM
>I got the Mondo bypass valve and it came with a gasket , but do you need the flange (8D003-051: Flange, Mondo Bypass Valve, Steel - or - 8D003-052: Flange, Mondo Bypass Valve, Aluminum) for the Vortech supercharger ?
Mondo bypass valve flange ?bowtiepwr 04-19-2003, 02:46 PM >I got the Mondo bypass valve and it came with a gasket , but do you need the flange (8D003-051: Flange, Mondo Bypass Valve, Steel - or - 8D003-052: Flange, Mondo Bypass Valve, Aluminum) for the Vortech supercharger ? mongse_1 04-19-2003, 03:49 PM It depends on what you're attaching it to. If you've got aluminum, I'd go w/ the aluminum flange. bowtiepwr 04-19-2003, 05:49 PM >But do you need the flange ?Or can you mount it without the flange ? 10secz 04-20-2003, 09:50 AM Originally posted by bowtiepwr >But do you need the flange ?Or can you mount it without the flange ? You need the flange welded to an appropriate spot on the blower dischrage tube. I have a spare aluminum flange that I can send to you if you PayPal me $10. But as he said, that only works if you're welding it to an aluminum tube. Here's a pic of my flange location: http://para.noid.org/~lj/bypassflange.jpg | ||
