At what boost level is O-ringing the block neccessary?
383 LT4
04-17-2003, 09:06 PM
Will it be ok to run up to 15#'s of boost without O-ringing and reciever grooving the heads? What boost level are you guys running without any modification to the block? Thanks for the info.......The D1 will be a lot of fun on the 383:D
Brady
04-17-2003, 10:56 PM
IMHO, you don't need to o-ring for 15#. I ran 15-17# with felpro gaskets and ARP bolts and never had a problem. I did start lifting the heads when we upped the boost over 20#...
good luck!
383 LT4
04-18-2003, 02:09 AM
would you guys recomend head studs? That is great that you can run so much boost on a fel-pro gasket. What was your compression ratio when you ran that much boost?
