tweetybirdy
04-16-2003, 12:01 AM
Ok so i am installing the Turbo Tech 60-1 high Fi kit on my car in my sig w/out the super fueler and having programming done by PCM for less, i am simply wondering if any one has anys suggestions for experience and what i should run for inj, or any other fuel requirements for that matter. So if anyone can think of anything i might have over looked or even gimme some advice i would greatly appreciate it, thanks
MEAN LT1
04-16-2003, 02:17 PM
How many pounds of boost do you plan on running, Have you done any more block work does your motor, whats the compression ?. Depending on how many pounds of boost your going to run will tell you what size injectors you will use.
tweetybirdy
04-16-2003, 11:46 PM
I have a new block i am slowy building but money is tight right now so it is going on the car as is which is stock compression, inj, and so on. I am planning on running 5-6 psi because i am under the understanding that that is about all i can run, but if someone knows different i am willing to try, and i by no means expect this engine to last very long, i am hoping the new engine will be done by the end of summer
