my car wouldnt start this morning
Black6SpdTA
04-13-2003, 03:30 PM
im about to leave for church this morning and my car didnt start, when i turned the key it clicked then no more noises. try again and one click then nothing. it happened like 5 times. cd player, lights, everything worked it wasnt dim or anything. then i gave up and was ready to call someone but tried again. pushed the clutch in turned the key and vroom. clutch switch? what should i check for? thanks
TheGreatJ
04-13-2003, 04:55 PM
If it clicked it's probably not the clutch safety switch. I'd say it's most likely a sticky starter solenoid but it's hard to tell. One sure way to eliminate the clutch switch is to pull the wires off of it and use a paperclip to jump them together. If the problem persists, the clutch switch is fine. You can do the same thing with the neutral safety switch.
irocz8957
04-14-2003, 09:07 AM
get under your car and find the starter and hit the thing that spins with a hard object to knock it lose!
Black6SpdTA
04-15-2003, 09:29 AM
HA guys i feel like a complete idiot. well my positive battery cable was loose, tight enough to let the lights and accesories work but when i turned the key the extra load made it not work. tightened it all up and its good as new
