Might buy a 92, have some Questions
jas142
04-13-2003, 01:26 PM
I might be buying an automatic 92 Firebird Formula. I haven't seen it in person yet, just called the owner from the classified ads. How much horsepower did the 1992 Firebird Formula Automatics have stock? Also, what kind of 1/4 mile times would the autos run stock?
Are there alot of aftermarket parts to chose from if I want to increase performance?
Also, he says it has 59,000 original miles which I'd think would be amazing. Did they have 5 digit odometers or 6 digit odometers? I'm asking so I can know if it might have rolled over and hes just lying about it?
Thanks!!!
fbird95
04-13-2003, 02:36 PM
you could have one of three choices for enigines (8 cyl)
L03- 5.0 TBI
LB9- 5.0 TPI
B2L- 5.7 TPI (Only with Automatic)
Not sure about the 1/4 mile times.
The odometer should have been a 6 digit odometer (059,000.1)
If the Odometer has been rolled back, look between the numbers on the odometers if you see white small white lines between them walk away.
Hope that helps you.
jas142
04-13-2003, 02:48 PM
L03- 5.0 TBI
LB9- 5.0 TPI
Thanks for the help!
If the owner doesn't know, is there anyway for me to tell if its the 5.0 TBI, 5.0 TPI, or 5.7? Whats the differences between those anyway (other then the obvious size difference between the 5.7 and the two 5.0s)
Black6SpdTA
04-13-2003, 03:22 PM
TBI =Throttle Body Injection
TPI =Tuned Port Injection
You can look at the motor, if its got a snorkel type air cleaner, its a TBI (see my motor in sig)) TPI would look like this cars motor, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2410146789&category=6420 and as far as 5.0/5.7 i wouldnt take the guys word, get the number off the back of the block (drivers side) and thatll tell you. peace
fbird95
04-13-2003, 06:14 PM
To tell what engine it is you could look at the Build List in the car. I think it will be on the door jam or in the arm rest. In the ohter post the codes are there. If you find that one on the list then you'll know.
The differences are the
LB9- had 205 horsepower
L03- had 170 hp
B2L- had 245 hp
jas142
04-13-2003, 09:59 PM
Wait, so some Firebird Formulas had ONLY 170 HP?!? What did the normal V6 Firebird have?
Why does a good lookin car have to be so slow :cry:
krazzycowgirl
04-13-2003, 10:17 PM
well you can tell if its stock & what should have been in the engine compartment by the 8th Digit.
T = 3.1L V6 MIF
E = 5.0L V8 MIF
F = 5.0L V8 MIF
8 = 5.7 L V8 TPI
irocz8957
04-14-2003, 09:00 AM
with the 305 you could expect the be in the high 15's 350 low 15's maybe high 14's
