Shane87Irocz
04-13-2003, 11:48 AM
I have a 9 bolt and today i am gong to change the oil. Is it ok to seal it with rtv blue will it seal thanx Shane
9 boltShane87Irocz 04-13-2003, 11:48 AM I have a 9 bolt and today i am gong to change the oil. Is it ok to seal it with rtv blue will it seal thanx Shane TheGreatJ 04-13-2003, 04:43 PM Should be fine. I personally prefer black because you can't see it as easily but that's just me. In a 3rd gen you really can't see it anyway. angel71rs 04-13-2003, 06:03 PM Just make sure to use a light coat. If you over do it and a glob squeezes into the housing, it could end up between ring and pinion. Kaboom would come next. irocz8957 04-15-2003, 11:42 AM yeah thats what i used and it worked great! mr diabolical 04-15-2003, 11:49 AM does autozone not carry a gasket for the 9 bolt? 87DJP2001 04-15-2003, 05:26 PM Originally posted by mr diabolical does autozone not carry a gasket for the 9 bolt? Yea, just like they stock all 9-bolt parts. Good luck. TheGreatJ 04-15-2003, 07:19 PM I can't even get a 9-bolt gasket from the local Chevy dealer. They say they've got one and they're gonna send it to me (I work at a shop,) but it always turns out to be a 10-bolt gasket. It's happened 3 or 4 times. Paper/rubber gaskets don't seal as well as silicone anyway. If you could find a cork gasket that would be the best but good luck..... 88 427 Camaro 04-16-2003, 02:03 PM 9 bolt gaskets (and lot's of other 9 bolt parts) are available at www.9bolt.com Miles | ||
