Transmission/clutch problems. Experts needed!!!
Old Apr 12, 2003 | 03:51 PM
scyzoryk's Avatar
I have problem with my clutch/transmission. I can’t put any gear in. On the beginning only 1st and reverse were hard to put in, but from today none of gears is working correctly. When I turn off the engine gears work fine, but with running engine I just can put any gear in. I know that he problem is declutching. I recently change master clutch cylinder so this is not it. I think that I didn’t assembled my clutch with the engine correctly when I swap it last week and the fork that should push pressure plate back is in wrong position or is bent. What do you think guys…
Old Apr 12, 2003 | 04:00 PM
hsyr's Avatar
Sounds like what happened to me. I ended up pulling the tranny to find a spring wedged between the PP & disc. I'd check your slave to see if its leaking, if not pull the tranny!
Old Apr 12, 2003 | 11:07 PM
scyzoryk's Avatar
ttt
Old Apr 13, 2003 | 01:49 AM
cals400ex's Avatar
same problem here. i added a little fluid to the resevoir and it does shift smoother now. however, it did not cure the problem. i think i will be replacing the slave. i have a feeling a spring is out of place or broke though.
Old Apr 13, 2003 | 09:35 AM
scyzoryk's Avatar
What spring is out? Anyway I have another question,. I think that my problems is that the fork that’s connects master clutch cylinder and pressure plate is in wrong position. Is there any way to remove it without taking tranny out?
Old Apr 13, 2003 | 01:32 PM
cals400ex's Avatar
i think he is referring to a spring in the clutch for the pressure plate. i believe the tranny needs to come to replace the fork.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
