Jeff 96 SS
04-12-2003, 01:39 PM
I wanted to get in one more run for the SS before I retired it from track duty. I also needed to try the Pro Yank 3600 Extreme converter I put in and hadn't had a chance to run yet.I only got two runs and the other I spun bad.
60 1.618
330 4.730
1/8 7.331 MPH 94.17
1000 9.582
1/4 11.474 MPH 119.24
Well not bad for a stock headed Powerdyne set-up. Now time to get the TA on the road hopefully low tens from it :)
I will have my YANK up for sale soon if someone wants a monster converter.
Jeff 96 SS
96 TA
1st and goal
04-12-2003, 04:05 PM
Good numbers ;)
You should try and crack 120 before you retire it :)
Marc :usa:
95Zdroptop
04-13-2003, 01:12 PM
Hey man that is pretty good times. I am right down the road in hagerstown. Did you change anything besides the supercharger. I have always been afraid of blowing something up.
95 Silver TA
04-13-2003, 03:31 PM
WOW!!
IMPRESIVE! :bow:
What Kind of cam are you running?
How much Boost are you seeing?
And How much does your vehicle weigh?
Thanks,
Claude
Jeff 96 SS
04-13-2003, 04:06 PM
Fully loaded fat pig 96SS t-tops with me in it close to 4000 pounds. The car has all the bolt ons you can think off, 94-95 style AS&M headers with dual cat random tech y-pipe, lt4 hotcam 1.6 RR, 52mm TB, Stock heads, 7inch crank pully I see about 7#s of boost. with my old conerter it ran a best of 11.64 @ 119.04 This new converter is a monster. My TA won't be ready for the event next weekend at MIR so I guess the SS will get one more track day. I would expect 11.3 at MIR its a much faster track.
Jeff 96 SS
96TA
GEES97TA
04-13-2003, 07:06 PM
Hey JEFF96 SS, I have a ? for you if you dont mind i have a 97 TA which weigh's about 3800 with me in it ..It has a M6,powerdyne 6 psi should see about 7 to 7.5 with the soild intake up-grade and larger aif filter,Also i have a set of stage 2 head's with 2.00 int.-1.56 exh valves fully ported/polished and it has 1.5 RR'S,and MAC headers OFF road pipe, And what else in my SIG. plus they are getting rid of the FMU and using 37 lbs injectors and doing a complete wide band dyno tune. My question is do you think i can get into the 12's with my mods and do you know what kind of RWHP youare making if so do you think i will be close to yours thanks alot...:)
95 Silver TA
04-14-2003, 09:04 AM
Again...Very nice Numbers man!! Especially for what you have done and a Vehicle that weighs that Much.
IllusionalTA
04-14-2003, 06:27 PM
Originally posted by GEES97TA
Hey JEFF96 SS, I have a ? for you if you dont mind i have a 97 TA which weigh's about 3800 with me in it ..It has a M6,powerdyne 6 psi should see about 7 to 7.5 with the soild intake up-grade and larger aif filter,Also i have a set of stage 2 head's with 2.00 int.-1.56 exh valves fully ported/polished and it has 1.5 RR'S,and MAC headers OFF road pipe, And what else in my SIG. plus they are getting rid of the FMU and using 37 lbs injectors and doing a complete wide band dyno tune. My question is do you think i can get into the 12's with my mods and do you know what kind of RWHP youare making if so do you think i will be close to yours thanks alot...:) i think you'd be quite past 12.90's w/ that setup.. :) at least low 12's i hope.. :D
Jeff 96 SS
04-14-2003, 08:28 PM
GEES97TA
I would say mid to low 12s. I think you will need a cam to get in the 11s. Every car reacts so differently to mods its very hard to predict. Go hit the track and let us know how you did. My car isn't a good one to base times on. My car has always been very fast for some reason. I don't know anyone with a Powerdyne even close to my times. I can't explain it but I'm not complaining either :)
Jeff
GEES97TA
04-15-2003, 12:18 AM
:) Thanks Jeff 96 SS, i hope for the 12's but your right i guess i have to do a cam next that will be a winter project thanks again.....
macksz
04-15-2003, 03:43 AM
Was Just wondering what psi you were running ? I just put the 4.5 on my 96 and Can't get my boost past 3 psi . :confused:
Maldo
04-16-2003, 02:30 PM
What is the Fastest times you have seen sombody run with a powerdyne?
