Cant Hit Reverse
Old Apr 7, 2003 | 12:11 PM
ollie-99's Avatar
Cant Hit Reverse
Its really tough to get in reverse all a sudden?
could it be a snesor or somthing like that?
it worked fine i was running ym car hard for a few passes, i was g-techin it
i was able to reverse then i got back, then when i went for a cruise 30 min later and its really hard to hit reverse
Old Apr 7, 2003 | 01:09 PM
Style's Avatar
Hard resistance or hard grinding? Resistance sounds like the
solenoid on the trans. Make sure that it is connected and no corrosion on the contacts. If you have a DMM, check to see if you have power to it. You din't disconnect anything else on the car, did you? I think if you disconnect the speedo signal, you can have the same symtoms.
Good luck!
Old Apr 7, 2003 | 01:15 PM
ollie-99's Avatar
Good luck!
it does not grind
just hard as hell to put into reverse, every other gear is good no grinding or problems gettin into em
the speedo is workin fine as well
where are these solenoids?>
blac94Z
Nov 4, 2015 01:59 PM
PopoFormula
Oct 12, 2015 04:19 PM
Hal Fisher
Sep 30, 2015 09:03 PM
SergheiS
Sep 29, 2015 08:56 PM
alliance12364
Sep 23, 2015 12:40 PM
