funina91ss
04-06-2003, 04:05 PM
Malf. 34 Map low
I swaped map sensors and still no luck .. does anyone know how to fix this problem? Thanks Sean
Data Master engine DTC errorfunina91ss 04-06-2003, 04:05 PM Malf. 34 Map low I swaped map sensors and still no luck .. does anyone know how to fix this problem? Thanks Sean Injuneer 04-06-2003, 04:47 PM DTC -34 - MAP sensor, signal voltage low, high vacuum. Terminal A = black wire = sensor ground from PCM (Ckt 470) Terminal B = light green wire = MAP signal to PCM (Ckt 432) Terminal C = gray wire = +5V reference from PCM (Ckt 474) A loose wire..... the light green one or the gray one, can cause this problem. With engine idling, does scanner snow MAP voltage below 0.25V? No = no problem, probably intermittant Yes? Ignition off Disconnect sensor harness connector Jumper harness terminals B to C Turn igntion on Is MAP voltage over 4V? Yes = faulty connection or sensor No? Ignition off Remove jumper wire Probe terminial B with a test light to battery voltage Ignition on Is MAP voltage over 4V? Yes = 5V reference circuit open, or shorted to ground, or faulty PCM No = Ckt 432 open or Ckt 432 shorted to ground or Ckt 432 shorted to sensor ground or Faulty PCM funina91ss 04-06-2003, 04:58 PM thats what I needed to know thanks funina91ss 04-08-2003, 09:34 PM when engine idiling I got like 1.4 volts. With jumpers in place I got 4.99 volts. with car off ignition on. So that should point out a wiring problem right or wrong? If right where do I need to trace these wires to to get a ohm's reading? Thanks Sean | ||
