18x9.5 verse 18x10.5
Old Apr 5, 2003 | 01:32 AM
XCES PWR's Avatar
Ok i can get 4 chrome Y2k C5 wheels in 18x9.5 on ebay for $899. Is it worth an extra $400 to get 18x10.5's for all 4 corners ($1299)?
If i got the 18x9.5 i was going to go with 275/35 on all corners and if i got the 18x10.5 i was going to run 285/35 on all corners. Will they look that much better and perform that much better to justify the extra $400 on wheels that are 1 inch wider and tires that are a little wider? Will both these fit fine without rubbing on a camaro with a pro-kit and revalves.
Old Apr 5, 2003 | 01:20 PM
jd13's Avatar
I don't think you'll need the bigger ones, especially if you're only the running 285s. Hmm....actually you could probably fit those on the 9.5" rims.
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Johnnynsac
Jul 22, 2003 01:44 AM
kandied91z
May 21, 2003 01:53 AM
kandied91z
3rd Gen / L98 Engine Tech
Jan 6, 2003 03:05 AM
