jamesge
04-04-2003, 12:41 PM
I have a 95Z28.
TH350 conversion, how did you get the speedo to work?jamesge 04-04-2003, 12:41 PM I have a 95Z28. kazman 04-04-2003, 01:07 PM I haven't worked that out yet. My speed reads way high. It is unpluged for now. I hope LT1 edit will correct the reading. I installed the ring reducer and stuff listed in other postings but I still have the problem. Maybe my 4.11 gears has something to do with it. Shon Herron 04-07-2003, 09:24 AM If you have an OBDII car you can hook up to the ABS stuff. if you have an OBDI car then it is a bit more difficult....I had to get a set up from Dakota Digital for less than $110 and it works. i have to fine tune it but i know how fast I am going within a couple of MPH. email me or post here and I can give you more info as needed. ie part numbers from Dakota Digital and how i set mine up. | ||
