Chupa 04-04-2003, 04:38 AM So, almost all my friends have had Mustangs for the last few years. About 3 weeks ago, I upgraded from a '90 Cherokee to a '00 T/A, and am loving the hell out of it. I was also quite happy that I could scoff at the performance of all my friends' cars. Now, one of the punks has gone and bought himself a Z06. I'm not really seriously considering it, but I've been wondering just what the fastest (and cheapest) upgrade path would be to make my car faster than his. I would not want to use nitrous, as I don't want to screw up the lifespan of the car.
If you were to attempt this, what would you do?
z top 04-04-2003, 04:58 AM there are so many things that you could do to be up his alley. a heads and cam package would probably be enough to do it. you could start off by doing simple bolt ons such as headers and the rest of the exhaust, air lid, hypertech power programer 3, maf sensor, etc but i don't know if all of the bolt ons would be enough if your friend's z06 has the 405hp ls6.
chuck 04-04-2003, 05:22 AM 380 rwhp will get you the same power to rwhp ratio as a typical stock Z06. 400 will be faster. Most heads/cam packages well exceed that these days.
rncotton 04-04-2003, 08:51 AM We've got a Z06 in our club and he's running 12.4's
We've got a 2002 SS that is faster ... 12.3's. To get there, he's got a lid, dynomouth exhaust, heads and cam, and a few minor suspension mods, along with drag radials.
Granted, this is a 2002 so it has a different cam and the LS6 intake.
Erik 94TransAm 04-04-2003, 09:18 AM You'll need more horsepower than him to be even with him. They are lighter and the IRS hooks very well.
Intake, longtubes w/ catback and an LS6 cam will be pretty cheap and should put you in the 360 rwhp range, which is pretty dang fast.
badeSSt 04-04-2003, 10:36 AM actually, i thought the independant rear made it harder to hook up?
Capn Pete 04-04-2003, 11:15 AM Originally posted by badeSSt
That's what I thought too??:think: I thought that 'Vettes shine at high speed, not off the line?:confused:
But to match or exceed the Z06's power, basically get a cam that's similar to, but a little better than the Z06 cam (not sure what that would be, but I'm sure someone here knows), and even with the LS1 heads, if you upgrade your exhaust and intake, you should be able to run close or better;). That's my opinion anyway?!:cool: Sticky tires would also be a good idea!:D
stik6shift00 04-04-2003, 11:55 AM make sure you can drive better than he can :) and what happens if your friend puts intake/exhaust on his car...mods in my sig should help out, you wont need all of that, but i would suggest the nittos they hook nice after a brun out
Chupa 04-04-2003, 12:09 PM Well, my friend is griping enough about monthly car payments that I think it will be quite a while before he mods the car. He went from a slightly-modded '99 GT to a 2002 Z06, so he's quite happy with the performance right now :) And remember this is all theoretical. The mods I see in the near future are the free mods, a whisper lid, a QTP cutout, and maybe a FTRA kit. Once the Kumho's that came with the car wear out, I'll probably put on some Nitto's, though I think I may want something I can get a little more mileage out of than the 555r's.
Yeah, so right now its just benchracing. I did just get a Ripper shifter, so I can't wait to get that installed, and the cutout is on backorder.
stik6shift98 04-04-2003, 04:42 PM Originally posted by stik6shift00
the mods in your sig didnt help u that much when we raced now did they :p ....and just wait till i spray:D :bow:
slvrbird2000 04-04-2003, 07:25 PM Originally posted by rncotton
Wow, he must a really poor driver, or have a horrible heads/cam package. Did he get stage 1 and the GM LS1 Hotcam? LOL
Some of you guys are really misinformed. IRS makes it harder to hook.
Chupa: You need all the bolt ons, and a good cam like the TR 224, TR 230, or MTI X1. You can benefit from the latter two since you have an M6 and can street it better. Just make sure to have your car tuned properly and (obviously) upgrade the valve train to rev higher to take advantage of those cams' powerbands. Then add suspension mods and tires so you can hook up. And alot of practice at the track before you take him on. Z06s can run like no other bone stock and are even better with internal mods. Intake/exhaust doesnt make much of a diff on them, the stock stuff is fairly efficient (but as with anything there is certainly room for improvement). I should know, I'm buying one soon. :D
Good luck!
GrdLockV6 04-04-2003, 07:31 PM My thoughts exactly Scott... an SS w/ heads/cam runnin a 12.3? Dude must not know how to drive, or his car is just plain broken lol. Hell Nate's runnin a 12.4 and he's got headers/torque convertor/intake and thats about it.
But ya, I'd say a decent cam, some bolt-ons, and a few other minor things outta get you in the Z06 range.
TransAmLS1 04-04-2003, 09:26 PM Originally posted by GrdLockV6
Why are you selling your car?:)
chuck 04-05-2003, 01:26 PM In the IRS/live axle discussion, I like the think about it this way.
Camber is the tilt of the top of the tire relative to the bottom of the tire, as viewed from the front (or rear). This is negative camber: /--o--\
And this is positive camber \--o--/
Either reduced the patch of tire that is on the road. Now, when a car accelerates, weight transfers from the front to the back. This causes the car to squat, and it is the nature of IRS to for from this |--o--| to /--o--\ because the halfshafts are hinged on the pumpkin.
Live axle, or solid axle cars, always have 0 camber, assuming the axle and/or housing is not bent.
So on paper, a live axle is better for drag racing than IRS. But the C5 IRS is among the best ever, and a Z06 will typically cut a better 60' than a typical M6 F-body assuming both are stock.
rncotton 04-05-2003, 05:18 PM Originally posted by slvrbird2000
He can't get too aggressive with the cam ... he still has to pass emissions. :(
stik6shift00 04-05-2003, 05:40 PM He can't get too aggressive with the cam ... he still has to pass emissions.
hahah, dont worry about that, i heard that pep boys emissions cheater works awesome, get that and get a good cam
ChrisLS1Bird 04-05-2003, 05:46 PM Originally posted by Chupa
So, almost all my friends have had Mustangs for the last few years....Now, one of the punks has gone and bought himself a Z06.
ahh yes...
"friends"
ULTIMTEORANGESS 04-06-2003, 04:36 AM youll be able to beat him on stock internals but it wont be easy.ls1s have run 11s NA but most are a4s due to high stalls.youll need a killer hook so get a tire like BFGs or stickier.youll never every bolt on that works.gears,headers,catback,pullies,lid,ram air.i mean everything.you might get away with less if he cant drive but z06s are nasty mothers.a little weight reduction will help too.
danziger 04-06-2003, 12:55 PM Put the car on a diet and do a Stage II heads/cam package from any of the major shops like ARE, MTI etc. Too bad you are so dead-set against nitrous use...that would be the cheapest and easiest way to do it...
