does this sound right?
detska
04-02-2003, 02:56 PM
went to the track for the first time friday and the numbers don't add up in my opinion.
maybe you guys can decipher the results for me.it's a 94 z28 a-4
.8037 reaction time
2.7550 60 ft.
15.5019 1/4 E.T.
96.92 trap speed
does this look like a traction problem. it felt like it was spinning till about half way through 2nd. how is it possible that i can run a 15.5 quarter and kill a high thirteen second car on the street, from a roll?
any input would be greatly appreciated! thanks!
larson_lars64
04-02-2003, 03:25 PM
well, i would say you spun through first gear cuz your 60 foot is really high. And you probably spun some after that too. I think most guys are at least around 2.2 with a little spin, maybe even lower.
red
04-02-2003, 03:36 PM
With a 2.75 in the 60' you were way beyond spinning. That is just about a full on burn out past the 60' mark. An average driver should be able to pull below a 2.25 with a stock A4 on street tires. A good driver would be in the 2.0 range. No offense but learn to drive the car. Roll in to the peddle some, don't just stab it.
sideways_Into_3rd
04-02-2003, 03:44 PM
a friend of mine got a 1.80 60' with his A4 TA on H rated all season tires :D
i got a 2.0 with my M6 back in the day ...
ur mph is way low too .. check ur wires / plugs .. do some maintenance ... u should be trapping closer to 100 mph if ur bone stock
RacinLT1
04-03-2003, 07:04 AM
with a 60' time as bad as that,the mph is about spot on.
Gotta remember,when you spin that bad,it severely affects mph,especially if it spun into 2nd gear.....then the car is accelerating from a "flat spot".
