Car studering BAD at WOT
Old Apr 2, 2003 | 07:54 AM
93transam1234's Avatar
Unhappy Car studering BAD at WOT
I drove the car last night and everything was perfect. When i got in it this morning i turned the key it turned over but didnt start right away. took about 1 1/2 seconds to start. Not normal for my car. So it started up and sounded fine. I backed up put it in drive and hit the light to pull straight then when i got on it just a little i studared and i heard a popping sound from under the hood and it studered and the SES light came on (dont know what code) so i stop and looked onder the hood i thought the belt broke. when i look onder my home made air intake wasnt on all the way so i put it on it isnt in there tight loos enuf to just push it on. So i started aging and same thing. The poping sound is a backfire comming out the air intake. I drove it for like 5 min to see what it was doing. It seems to run fine at low RPM's but when ever go above around 2500 - 3500 it studers really bad. Is there some thing that i can check now befor i have to go to a shop? I dont have any cash right now i have to move next weekend all money is in that.
Old Apr 2, 2003 | 08:59 AM
ALSO
Also when the car is in park it seem to rev up fine no studder or anything. I had work done on the tranny last weekend too.
Old Apr 2, 2003 | 10:06 AM
MZK4252's Avatar
You gotta get that intake on there good, man. Any vacuum leak after the MAF will cause stumbles. The bigger the leak, the larger the stumble.
Whats happening is that the car is getting a lot more air than it thinks, so it's running super lean and backfiring out the intake.
Seal that intake up real good and see how it goes.
Old Apr 2, 2003 | 10:10 AM
NXz28's Avatar
Change your spark plugs, and spark plug wires...that fixed the exact same problem i had with my car...
Old Apr 2, 2003 | 10:18 AM
Umbrae's Avatar
Check your MAF. It might have gotten dirty from the filter not being on all the way. I know thats what happened to mine, something got past the filter, and got the hotwires a little dirty.
-Cam
Old Apr 2, 2003 | 10:53 AM
I will try the mass air but i thining about the coil too maybe.
WELLS brand name ok?
jayblev95
Jan 20, 2015 01:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
mattszm6
Dec 14, 2014 07:09 AM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
