i have some ?'s
Old Apr 2, 2003 | 06:15 AM
97LT1TA's Avatar
i have some ?'s
Do you guys use relays for your solenoids? one for each or one for both? and is it normal that both my solenoids are pulsing? i hooked them up to a 12 volt source to make sure they are working but they are pulsing open and closed. Thanks
Old Apr 2, 2003 | 08:10 AM
95greendragon's Avatar
Could be a bad ground, You can use one relay for both solenoids if it is a double pole relay. Are you using a fuel pressure safety switch?
Old Apr 2, 2003 | 11:32 AM
OffspringZ28's Avatar
same here and i have a fpss.
Old Apr 2, 2003 | 11:45 AM
If your FPSS is adjusted to high it will do this. Check and see what psi it cuts on at.
Old Apr 2, 2003 | 05:36 PM
97LT1TA's Avatar
well actually i dont have the kit installed yet, I bought it used and i have more things to get before i put i in. i got an msd window switch and a purge but i still need the fpss and a bottle heater. along with relays and a wot switch. anyone have a 5700 and a 5800 pill laying around they dont need? thanks for responces guys.......
