colder stat, engine wear down quicker?
Old Apr 1, 2003 | 01:10 AM
bachehbad's Avatar
i heard when you get a 160 deg stat tht your engine internals wear down quicker, is this true???
Old Apr 1, 2003 | 01:17 AM
z28Power's Avatar
actually, it's the heat and running an engine at hotter temps that typically causes engine wear to occur quicker. The only thing that will happen with the lower thermostat is if you dont have your fans set to come on earlier, your coolant will get moved around a lot more, might need to flush and recharge it more often. Other than that, a cooler engine = happier engine :-)
Old Apr 1, 2003 | 01:20 AM
bachehbad's Avatar
so thumbs up for the 160 deg stat???
Old Apr 1, 2003 | 01:31 AM
HM Murdock's Avatar
Get the stat, and a fan switch or something like it. Very worth it.
Old Apr 1, 2003 | 05:38 PM
stonecoldz's Avatar
fans
what temp u recommend the fans come on i just installed a 160. haven't programmed fans yet.
Old Apr 1, 2003 | 05:40 PM
z28Power's Avatar
I forget what they recommend for a 160 thermo. 175-180 I think?
Fatdog2
Feb 13, 2015 08:19 PM
guionM
9
Aug 29, 2002 01:48 PM
Fastbird93
Jul 28, 2002 09:14 AM
