header plug up?
Old Mar 31, 2003 | 07:16 PM
burnemonm1's Avatar
Arrow header plug up?
I just bought some edelbrock shorties and a loud mouth system and I am putting a cut-out in place of my cat. my question is should I just go to the hardware store and get some bolts to plug up my o2 sensor holes and my oxygen pump holes or is there a better way to do this. thanx for the help
http://www.streetlethalperformance.com
Old Mar 31, 2003 | 07:38 PM
94BlackBowtie's Avatar
I would think you need to get some 02 Sensor simulators...
That way at least you are less likely to see the SES light.
Old Mar 31, 2003 | 09:54 PM
burnemonm1's Avatar
I don't need sims because I have a 94-obdI with only 2 o2 sensors the check light won't come on. anyway the sims only plug in to the wire harness but thanx for the help anyway.
Old Mar 31, 2003 | 10:22 PM
Jason Dove's Avatar
Just plug the o2 holes, the AirPump holes you've probably got to use special bolts, so search the board. I've seen posts in the past that say what type of plug to buy, all I remember is that it's a plumbing fitting of some sort.
Old Apr 1, 2003 | 12:31 PM
I think I will just apologize for my first post and not even try to clarify it...needless to say, I totally missed the point on that one - nevermind the fact that you only got a '94 as I...
<----RETARD!
(That's what you get for not responding in the first thirty minutes after reading the post...)
Old Apr 1, 2003 | 12:55 PM
KGRESOCK's Avatar
Use a BMW drain plug for the air pump holes.....M20 I beleive
pep boys carry's them.
I'm a little confused....why would you want to eliminate the 02"s?
Old Apr 1, 2003 | 10:05 PM
burnemonm1's Avatar
because my stock o2 sensors are stuck in my stock exhaust after 94xxx miles. and times are a little rough right now and I want to drive my car in the warm weather up here in mi
thanx for all the info
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Drtryder
Apr 22, 2015 04:17 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
