MSD 6AL Install....
Old Mar 31, 2003 | 06:50 PM
95TA8280's Avatar
MSD 6AL Install....
OK I'm new to all this stuff so I got some ?s.....
Where is the coil and how do I know which is the positive side and which is the negative? It says I need to connect to a 12 volt source? What does that mean?
Old Mar 31, 2003 | 07:31 PM
grygst76's Avatar
Re: MSD 6AL Install....
the heavy red is the battery positive--heavy black is solid ground (negative) if I were you save the aggravation and also buy the adapter kit for it to directly connect and no splicing.
Old Mar 31, 2003 | 08:50 PM
95TA8280's Avatar
In the 6AL do I have to connect it to the coil?
Old Mar 31, 2003 | 08:57 PM
94FlamdS10Blazr's Avatar
ok yes you connect to the coil. Did you get this used? The new ones have instructions so I gotta ask. Coming from your ignition module its a pink wire for the coil positive and a white wire for the coil negative ,stock. If you get the adaptor you save alot of hassle for less than $30, but if your not:
Big red to battery, big black to the ground.
Orange (+)and small black(-) go to the coil
Little red (+) and white (-) go the cars pink and white
Old Mar 31, 2003 | 09:04 PM
All install instructions are at MSDs web site and the harness is well worth the money so that you don't have to hack up your wiring. It will also give you the capability of removing it and going back to stock in only a few minutes for troubleshooting.
Old Mar 31, 2003 | 09:36 PM
95TA8280's Avatar
Where are these?
Old Mar 31, 2003 | 11:56 PM
maybe you should go to the MSD website. It might help you better than we can
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
