Fuel Pressure with 30# injectors
Old Mar 31, 2003 | 04:41 PM
LPE Z convt's Avatar
My car is a heads cam LPE car with 30# injectors and LTs, borla,the fuel pump is a walbro 340s series intank i want to know what i should set the pressure at with the vaccum unpluged or plugged what do you guys set yours at also the car is stock bottom end with custom tuning for the package and reprogrammed for the 30# injectors
Old Jan 5, 2004 | 05:45 PM
LWM's Avatar
LWM
You didn't say if the injectors were SVO or GM Multech.
What ever, SVO injectors are rated at 39psi and GM injectors are rated at 43psi.
If SVO type, then I'd try 45psi at idle with the vaccum line off.
If GM type, then I'd go with 47 - 49psi at idle with the vaccum line off.
Hope this helps
LWM
Old Jan 5, 2004 | 06:33 PM
97 WS6 T/A Conv's Avatar
46.5 to be exact, no vacuum. 30lb SVO's on mine.
Good Luck with it Chris.
Old Jan 5, 2004 | 07:14 PM
CANTONRACER's Avatar
All you should have to do is bump the injectors up to 31.6 and run stock fuel psi...if I remember right.
Old Jan 5, 2004 | 08:18 PM
Where did you guys find this thread (LOL)? Ion changed it in the computer for the bigger injectors and fuel pressure is set at stock 43.5 with vac. off....
Hey gary i put stock heat range plugs in the car and it seems to make a big diffrence..... Did you ever make it back to the track for that 11 sec pass? The injectors are svo injectors... It sucks that you need a ford product to make a chevy run....
Old Jan 5, 2004 | 11:26 PM
Sent you email back and no I'm still sitting at 12.02.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
