zhevy-1
03-30-2003, 07:47 PM
I've been trying to figure out what could've broken a valve and a roller rocker on my 383 LT1 Stroker. It has a 11.5:1 CR w/6" rods, JE Pistons, and AFR 190cc Heads. For more details...see sig below.
A little info to help me out. The car started to make a high pitch ticking sound, and started to miss. I towed the car home, and while fishing for origin of the sound, I rev the car a little, and that's when everything broke, and a nasty rattle sound emerged, I shut the engine off, removed the head, and found the damage.
The valve broke at the base, and made a hole on the piston. Cylinder wall is fine. Thanks God.
Out of the 16 roller rockers, one broke and 4 on the same side -including the broken one- had the retainer form etched on the bottom, as if the rockers were pushing down on the retainer flush.
My car never knocked, and the most I ever saw was like 2 degree knock.
After talking to some people they say stainless steel valve don't break that easily, and some have commented on my 11.5:1 compression as perhaps a cause, since it may generate more heat in that area. The rr's were the Crane Aluminum, similar to the LT4 Hotcam kit ones.
Anybody here has had any valves issues with high compression strokers?
