turb0racing
03-30-2003, 02:12 AM
I suscribe to diy turbo and they sometinmes have good discusions adn i just wanted the share the knoledge.
second, there is some cool combustion chamber stuff that is showing that you really don't want a heterogeneous mixture in the combustion chamber for maximum power and efficiency, that you really want to generate a chamber filled with the richest mixture around the plug and getting progressively leaner as you move away from it toward the pistons.To do this you COMPLETELY AVOID TUBMBLE and concentrate on generating a
swirl using the chamber shape. Some engine tests have shown that you can get incredible detonation resistance this way and run very lean overall mixtures (averaging about 18:1). The idea here is to create a condition where you can ignite the charge very quickly (rich mixture around the plug), but the lean areas will not ignite till the pressure in the cylinder drops some from the piston moving down the cylinder, the end result being that the combustion event supplies a larger impulse over a longer portion of the power stroke. Ultimatly resulting in more power,broader power band and better mileage.
This is what is referred to as 'stratified charge', right? I've heard
that diesels approach this scenario more than any N/A engine. Isn't the injector event timed such that it sprays into hot, compressed air, where it ignites as it is sprayed?
In a diesel it is. And I've heard of it being called that and a number
of other things in 2 strokes. I'm not sure about a 4 stroke gas engine.
Some of the lean burn engines worked on a similar principal with a
stratified, lean charge in the main combustion chamber and a small
prechamber that has a much more easily ignitable mixture that is used to
light off the charge in the combustion chamber.
I believe that this is the way that they're going with some of the
direct injection gas engines.
