Anyone using one of these..
Old Mar 29, 2003 | 07:35 PM
craigffb's Avatar
Question Anyone using one of these..
Anyone using one of these activation switches? Just wandering if it's worth it or just as esay to use the stuff that came with the NX kit?
Old Mar 29, 2003 | 10:18 PM
funina91ss's Avatar
for 30 bucks I would say so I dont really like the way mine looks but it works I guss.. how much is the tps activation switch? you might want to look into that..
Old Mar 29, 2003 | 11:04 PM
craigffb's Avatar
A TPS is $90.
Old Mar 30, 2003 | 02:10 AM
stik6shift98's Avatar
get the nx switches they are defintly worth it
Old Mar 30, 2003 | 04:09 AM
craigffb's Avatar
I have a NX switch, I came with the kit. I just don't want to jerry rig something to make it work if I can get this braket. How did you mount yours? Just wandering if any one has one of the jimmy-jams switches yet. It may just be worth $30 to not have to try and bend up the braket that came with the NX kit to make it work.
Old Mar 31, 2003 | 05:05 AM
craigffb's Avatar
So if no one has one of these switches, how are you mounting the WOT switch that comes with the kit?
Old Apr 1, 2003 | 09:11 AM
Zippity'Z's Avatar
Actually what I keep consistantly hearing from people is that the tps activation switch has problems misfunctioning and just plain not working right. Remember it works electronically and apparently it isn't always accurate. The JJNS activation switch is mounted right to the throttle body and is activated at wide open throttle - click and activate basically- so there isn't a problem with misfunctioning or activating too soon. Just like if the wot switch is put on the gas pedal- that's not always activated properly either because what if the gas pedal is not pushed all the way to the floor for some reason - then you don't get activation! Anyway- everyone has their ways and every has their favorite ways that work for them so that's what matters is that what you have- works! :-)
*R
Wicked94z28
Jan 31, 2011 08:07 PM
Caps94ZODG
11
Aug 30, 2009 08:58 PM
GaJoe
Aug 4, 2009 04:11 PM
