Is there any steel spring wedges out there?
Silver Pig
03-29-2003, 01:07 PM
I have broken my second set of spring wedges last weekend. The ones I have are aluminum. I was wondering if there are any steel wedges out there?
I might pull the rearend and take it to a chassis shop to get new spring perches welded on with the correct angle if I cannot find any stronger spring wedges.
Thanks,
Sean
Damon
03-29-2003, 06:55 PM
I assume you're using them to adjust pinion angle.
That's a good question. I haven't owned a leaf spring car in a while but I know there are steel ones out there somewhere.
What they of device are you using to control the spring wrap-up? Slappers? SLide-link? Once such a device engages it should stop outting stress on the shim. What have you tried as far as suspension adjustment so far?
Silver Pig
03-31-2003, 12:14 AM
I have Global West L2 leaf springs and caltrac bars. I have been through 2 sets of shims so far. I have a manual tranny as well that means I am not nice to my driveline!:)
Thanks man, I will try to get on the hunt for some steel shims.
Sean
