  1. Hesitation off idle
  2. *excellent info* 93 specific info list.
  3. ALL MEMBERS READ!!!! Abuse of "TTT"
  4. Who Wants a MSD Replacement for the Opticrap?
  5. Clutch going, signs?
  6. Crane 10308 spring kit for LT1s
  7. please help.....have a constant miss over 5K, please read, i cant figure it out....
  8. Who has 160 thermostats?
  9. CAM QUESTION
  10. Transmission Temperature Sender.
  11. Wiring the CSI, quick questions, i've read the archives...
  12. Just threw DTC P0420 Catalyst System Below Threshold
  13. "Hole in the Hatch" fuel pump removal
  14. OPTI to PCM wire?
  15. Autometer Cobalt Gauges
  16. Idle stumble, plus clicking now????
  17. Gasket for oil filter adapter?
  18. Spec or SLP clutch ?!?!?!?!?
  19. Should I get rid of my Flowmaster?
  20. Spec II anything good about it?
  21. mcleod clutch?
  22. HELP!! Car is cursed. runs rough after 2 min of driving, msd problem?
  23. accell dfi, speddpro, tec 2, etc
  24. Who's Got a JET FAN SWITCH in their LT1?? Need opnions!
  25. Pinging After Cam Install?
  26. LS1 brake upgrade
  27. Knock Sensor Mod
  28. Having a problem with getting my balancer far enough back on my LT1
  29. okay, i have a dilemma...baer or motive?
  30. Which AFPR do you recommend?
  31. Knock on startup?
  32. True Duals w/ new Torque Arm??
  33. Car backfiring after heads/cam install....solutions??
  34. New clutch installed, worked fine, now slips....
  35. Post Hooker LT install question
  36. Will a LS1 airbox fit a LT1 (with stock hood)?
  37. Looking for an alternator relocation kit....
  38. SES Light-Code P0400: EGR Flow Malfunction...is this for the recall?
  39. Stall converter
  40. PLEASE HELP!!! I have no heat
  41. Z28 95 front brake pads change
  42. 1.6 RR/LT4 KM Dyno Results
  43. What needs to be done to install pushrod guide plates??
  44. CAI, really getting cooler air?
  45. Apexi on camaro
  46. XE 224/230 Cam guys in here please....
  47. Any New Tricks For The Lt1, Already Ported Mass Air, And Throttlr Body Bypass
  48. Hooket LT's on lowered car?
  49. Broke Tranny mount......AGAIN....
  50. Power Window Replacement
  51. Help Ttop Leak
  52. What are your thoughts, or better yet, your experiences with the Z06 85mm MAF?
  53. bad clutch chatter in reverse
  54. Monsoon stereo locked after power loss. Help!!
  55. same amount of money on civic and LT1, which one is faster
  56. ST3500 stall and OBD1.....help
  57. Shorty hookers and off road pipe
  58. GMMG Sound Clips?
  59. Advantages of Titanium retainers over stainless steel?
  60. tightening exhaust manifold bolts
  61. Are 30 lb injectors too much for heads/cam combo?
  62. Donkey Dong clearance and CSI electric water pump
  63. Grinding noise? Clutch?
  64. New Opti Help
  65. Is the low trac light point less, or dose mine just not work?????
  66. check out this mod
  67. Difficulty of changing all front bushings.
  68. Thinking About An LT1 vs LS1 Shootout For GMHTP
  69. faster than my speedo
  70. 400+rwhp with heads/cam and under 6k rpms??
  71. Guys w/ headers and !cats....
  72. Vibration
  73. Replaced some EVAP stuff. Still getting code P441.
  74. Meziere Electric Water Pump.. What a piece of crap!....
  75. K-Member Removal...
  76. Are LT1 vette and LT1 Camaro Torque Converters Interchangeable?
  77. Idle problem, intermittant
  78. Accel Gen VII DFI?
  79. true duals with stock manifolds?
  80. 98+ Cluster pinouts (93-96 to 98+ swap)
  81. Pro Performance Heads, Cont...
  82. Help! Exhaust Manifold Leak Questions.
  83. Valve springs/seats/retainers/valve locks
  84. True Dual Exhaust ?'s
  85. Who has a nice looking engine bay?
  86. Car Shutting Off Problem .. SOlved ICM
  87. Anybody have pics of valve covers modified to clear 1.6 pro mags
  88. 3.4 is not enough :-)
  89. C5 clutch, pedal feel.
  90. Which LT1 motor would you choose for a transplant?
  91. TAZZO 1/4 mile meter, how accurate is it?
  92. Pilot bearing removal
  93. EGR causing this wierd smell?
  94. Idea for NOS setup.......
  95. Cat-back vs. Cut-out
  96. Off road pipe
  97. how can i tell if i spun a bearing?
  98. ODBII code question
  99. What valve springs?
  100. Anyone with a solid roller step inside...
  101. what the hell happend?
  102. Alarm keeps going off!!!
  103. Cut-Out not doing anything at for E.T. on LS1
  104. TPS low voltage after TB swap
  105. Just completed the head light mod. w/pics and instructions
  106. Scoggin Dickey CNC LT4 Heads
  107. Question about turning flywheel.
  108. Hub and balancer..
  109. Replacing the Stock Elbow .. whats a good one?
  110. What's this fuse do?
  111. Code 45 on my 93
  112. front licence plate bracket removed, now what can i use to plug the holes
  113. magnaflow and or slp 2otl sound clips?
  114. code 1870, and 4l60e
  115. Redline Performance Engineering?
  116. Moser 12 bolt owners..
  117. need kn air filter part # for 96 ss
  118. Lightweight battery
  119. Blew up 2nd transmission, need some thoughts
  120. I think my clutch is going... got a question
  121. 97Z vs 30th
  122. 2.02int. 1.60exh to big?
  123. For anyone considering Solid Engine Mounts-
  124. LT1 1/8 mile
  125. Gutted Cat
  126. Accell DFI - computer management?
  127. carburating a 97 trans am
  128. Quick Question About 30th Aniv. LT1's...
  129. Very disappointed with Flowmaster
  130. LT1 head chamber volume
  131. How much boost can you run with stock motor & 54cc LT1 heads?
  132. tranny going? rev limiter? what is it?
  133. Highest Mile LT1's Hollar if you hear me! Come in!
  134. Help me I'm having a debate: Keep the true duals/ x-pipe or switch to Mufflex 4"???
  135. 383 Stroker LT1?
  136. Waiting 20 mins to shift in gears(M6)
  137. tranny swap
  138. edge racing converters?
  139. Dyno numers for XE 230/236 with stock heads?
  140. SES light when driving long distance
  141. Please can anyone help I cannot take this anymore.(Fred??)
  142. Best way to remove exhaust manifolds
  143. torque NEW ARP head bolts mutiple times?
  144. who has total engine airflow that dynoed 390-400
  145. Power Window Motor Install
  146. LS1 wheel bearings with upgrade??
  147. Viper T56???
  148. Exhaust Cutout Placement
  149. Slave cylinder or clutch going bad???
  150. Racetronix...takin' care of business
  151. Anyone heard of aca enterprises??
  152. New book on rebuilding LT1 engines!
  153. 30# Fuel Injectors
  154. Borla w/ AS&M headers question
  155. Does anyone elses heat suck??
  156. anybody got pics of slp TOTL on their car?
  157. Oil Filter Adapter Assembly?
  158. How hard to change out window.
  159. Those w/ Mallory Hyfire VI CD...
  160. Cam Dowel Pin
  161. Headlight knob doesnt illuminate..
  162. Does anyone here have Hooker LT, Flowmaster cat-back keep the cutout open always?
  163. Power Windows
  164. how to degree cams ofr install.
  165. Hard Accels = ABS Inop light = no traction control / Very odd
  166. Injector control circuit code help please
  167. HELP!! car wont start and the security light is on
  168. m6 guys that switch from 3.42 to 4.10 only
  169. best cam for my application?
  170. Longtubes causing 02 sensors to go out????
  171. 2.73 vs 3.23
  172. Speedo hookup M6 to A4
  173. header help: mating surfaces uneven [Pacesetter]
  174. What's a Crankcase Evacuation kit?
  175. Wrecked Mybaby.. Plese help..
  176. 383,HV oil pump, and stock pan people...
  177. Need help on Hurst line lock install...
  178. rocker arm stud thread sealer
  179. TB Bypass: What Is It & How Does It Work?
  180. Turn signal fuse...
  181. LOW RPM STUMBLE! FOR ALL THAT HAVE SOLVED OR HAVE FACTS INSIDE PLEASE! ?'s
  182. Twin Turbo Kit for the LT1
  183. 93-94 Firebird streering wheel radio contols FIX!!!
  184. Corvette accy. brackets on fbody
  185. How do I control shift point in 700R4?
  186. 561 casting flow #'s
  187. Dynomouth=DYNAMITE
  188. Cam Question
  189. True dual exhaust questions...
  190. Headers
  191. DIY HEADS...some pics of my progress
  192. 30th anniversary question????
  193. sprung weight vs unsprung wieght vs rotational mass
  194. i hit the 60k mark
  195. Need help on WEIGHT REDUCTION!!!
  196. Can timing be altered between 100 KPA and full boost at a given RPM?
  197. Where to buy a replacement FOG LIGHT
  198. How much for a Header install?
  199. Bad miss under throttle... ideas??
  200. New Trick Flow Elbow?
  201. Water in floor board!! Not HeaterCore!!
  202. LT1s representing in the Gumball 3K
  203. Stumbling After Header/Plug/Wire install, WTF?
  204. Will Rockers make THAT much diff *part 2*
  205. gm part number?????
  206. Another GM Part Number Question?????
  207. Fuel Cell - Ideas?
  208. GM hp ratings
  209. single exhaust (dynomouth)?
  210. High wattage aftermarket Bulbs
  211. help... is an LS1 gas tank the same as an LT1 tank?
  212. hurst shifter
  213. Where to get MAC Headers
  214. Very bad gas milage and rough idle
  215. Helped a friend do a intake manifold gasket and couldnt believe his car ran....PICS..
  216. Use a pilot bearing or bushing with new clutch?
  217. Swapping an Lt1 out of my car for a new one, easiest way?
  218. Head gasket is blown. Need parts list for heads, cam, & 355 rebuild...
  219. clutch is acting up after car sat for 3 months (street twin)
  220. NE 1 runing a midwest stall conveter?
  221. what all gaskets do i need for my vented opti swap?
  222. Difference between dyno tune and pcmforless?
  223. Top Speed Limiter
  224. 49320 "Universal Kit" Accel 300+ ignition
  225. Car Broke down today...
  226. Canton oil pan issue
  227. Valve Cover FABRICATION for 1.6 Rockers...
  228. step by step opti replacement?
  229. AC Oil Filter part numbers change?
  230. is my tranny dead???
  231. Dimmer switch doesn't work, HELP...
  232. which is worth more power true dual or borla catback??
  233. difference between a4 and m6 which is better
  234. Keyless Entry remote doesn't work correctly
  235. Can't feel my legs!
  236. Anybody running the Comp XE 224/230 cam with a 114 LS?
  237. I have $800 to spend on mods need some help
  238. Guys running Hooker LTs w/ Borla get inside
  239. I need exhuast sounds
  240. PCMFROLESS tuning help!
  241. I Think I solved the LT1 tire wear issue!
  242. I keep hitting rev limiter in an auto
  243. LT1 with LS1 airlid?
  244. anyone with centerline telstars in here please
  245. I just cut me cats of my z!
  246. racenet.net...thumbs down
  247. Problems With My Lt1 !! Hesitation And Clutch Noise
  248. Engine Vibration...........
  249. Squealing noise after rear brake pad and rotor replacement. How can I fix it?
  250. help! my cooling fans dont turn on
