- What makes an off road pipe different from a regualr pipe?
- What does getting the valves lapped mean?
- Craftsman bolt extracter Bravo!
- so here are my goals. would shorties do?
- HELP! ? about welding relocation brackets
- Is it safe to drive with a Code 16?
- Low profile jack suggestions?
- Window motor help
- question bout timing chain,gears,opti install
- I think my oil intake pick-up fell off??
- WTF cant get slp y pipe back on???? HELP ASAP
- What exactly fails when the optispark gets wet?
- Hard starting FIXED!!
- Scanning the Car... HELP
- T56 Output Shaft
- LT-1 takeout
- Air Bag
- High RPM Miss (long, please help)
- Anyone able to get longer studs in the back axles?
- Fuel shootong out of headers, it it a leaking injector??
- head porting and sound
- Anybody using this for an exhaust??
- Making this Camaro consistent
- engine missing after new plugs and wires
- Detonation problems (need help)
- Old input shaft ?? What did you align cluth with. Aligment tool with clutch won't do
- What could be wrong with my car?
- How much gain from a tune
- Recalibrating Speedometer?
- False KR(long)
- would a obd1 scanner work on a 95 if
- LT1 to LT4 ?
- where to buy front bumper cover for 93 to 97 trans am
- scanning question
- what causes awful gas mileage??
- What kind of gains will i get with these small mods??
- hey shoebox
- Why does my car run smooth one day and not another?
- cam change
- lt4 cam compared to CC306
- fuel pump
- head gasket or two
- Oil leaking from valve covers?
- best muffler?
- Who here is running Mobil 1 15w50?
- which gears are best for me
- rotors
- LS1 exhaust
- calipers
- chevy 9 bolt work w/a 4th gen
- is bbk a good brand for a TB?
- MAF= Tranny Problems
- How much does a new gauge cluster cost?
- which tires to go with 17x9.5 front and 17x11 back?
- Opti Problem, please help asap
- Is my car falling apart?
- Taylor OVC wires installed!
- Multiple Cylinder Misfire
- copper header gasket leaking
- too much tension from new springs?
- No power - clicking from near front bumper
- Anyone running Jet-Hot Y pipe?
- Removing Jounce Bumper spacer?
- Right Bank = Which Side?
- Will a cutout cause this error code?
- 15.1 in a 1/4
- front shocks
- Hub position in relation to keyway?
- aftermarket tachometer
- is this a bad water pump, a bad sensor, or LT1 cooling system just suck??
- how much for a clutch bearing
- over cover wires??
- Screwed up. Need help.
- Alternator "squealing"
- O2 Sensor
- rear end drippin
- Master Cylinder Problem
- Car doesn't properly drop down to idle from a rev
- Hooker LT's and Pro kit- How much clearance do YOU have?
- Heads and cam Auto dyno #'s?
- Could my MAF have been damaged?
- Double roller timing chain install
- Can bad IAT cause crazy idle when hot?
- could i have installed my fuel filter wrong?
- under drive pulley [ebay]
- Oil In Hose Going To Throttle Body.
- my 93 has traction control....???
- Borg-Warner sparkplug wires any good?
- Bad miss upon acceleration ?
- ANYONE know how I can fix this stupid nut?
- high oil pressure and rpms.??
- speedo problem
- Fixed my over-rich problem
- What does it take to get 300hp?
- Opti Spark Alternatives
- if you had 100 bucks, would you get LCA's or reloc. brakcets???
- LTCC Users
- Anyone ever deal with or hear of advanced dyno technology?
- 3.73's Worth It????
- help needed badly!!!
- Light Weight Capret for LT1's???
- Gears or Suspension?
- Where to find a 2 into 1 Y-collector (3")???
- Steering shaft question
- parts list
- Cam install
- Hesitation cured Thanx PontiacX2
- Anyone upgrade your brakes? Either w/Baer or LS1?
- Stock Oil cooler or aftermarket?
- Fuel Pressure
- Headers
- Over doing Top end?
- 95 t/a vs 2003 srt
- !egr, !air
- Why my driver side window wont raise up?? Help?
- !ABS/Brake booster ?s
- fuel line??????
- rear end help!!!!!!
- Doing Doughnuts...Something broke.
- New best times and questions to go with them
- need an opinion
- A4 --> M6 swappers
- What else can I do to help me hook?
- Special spark plug socket... Is this for real?
- Which Headers???
- Problems with K&N Cold Air
- Dummy Light For Brake
- why wouldn't my car start in the rain?
- When do headers become a requirement?
- 1le bushings
- 1le bushings
- optispark upgrade
- how much will this drop my ET?
- Do I need to machine for valve springs?
- a/f gauge
- fuel leak
- Arcing msd wires & every other problem....
- How do I get the water pump drive out?
- Rod or Lifter Knock
- Knocking noise from rear...
- Noisy Lifter
- negative 22 degrees timing??!!??
- NOS it or not???
- Rhoads lifters?
- 1le bushings
- A4 and M6 driveshafts the same length?
- Do I need a new console for A4-M6 conversion in a 97 fbody?
- PCMFORLESS questions
- Got $350, what to buy
- Non ASR throttle cable...
- Pic of subframe connectors please??
- What Did I "mess" Up ? (edited by moderator)
- WTF no SES??
- What rpm should my A4 be shifting at?
- Weird AC Charge Problem
- LT1 Valve ?'s
- Hey 383 people!!!
- Part number needed please
- need pic of 4" single out and dual 3" dumps ASAP
- POLL: Which Headers ??? Also, How insight on the install ?
- Quick oil pressure question: is something wrong??
- Lt1 weight
- test plug wires with ohm meter?
- help with trouble codes shoebox and ne one else
- I hate the " please guess posts" but..
- What happens when your fuel pump begins to die?
- Pics of my clutch... what's wrong???
- jet hot lt headers
- Overfilled Gastank
- removing back seats
- T56 to TH350 swap
- will crossed plug wires throw codes?
- brakes
- SLP headers and O2s
- How restrictive is the stock exhaust?
- something not expected
- 02 question (good reading)
- starting engine without tranny?
- Mcleod Street Twin help please =)
- Gauge install...drilling firewall
- What is up with my plug wires?
- Tranny going south?
- bent spindle?
- Cam Question
- Front End Squeals/Squeaks-No glove box data tag
- Weird starting problem...help me out
- HOW MUCH smaller of a belt for Delete A/C pulley
- Who sells MAC headers?
- how much wieght can our rims handle?
- any "how to" do the a cheap manual fan switch??
- How is my air fuel ratio?
- BMR LCA relocation brackets
- Veh. spec tag missing... where to find out specs?
- Is it my opti?`
- Starting Issues, Need help please!
- Stock Gears????
- Do I have to use a 95 trans in my 95
- Gas Gauge goes "SLUUUURRRRRRPPPPP"
- How to adjust throttle and TV cables?
- PCM for less options....
- Need Dyre Help! I think my OPTISPARK was wet by the shop!!!
- Should I do my clutch now or wait...
- Broken spark plug
- American Racing wheels
- E-brake
- More air for k&n filter???
- SES light flashes
- LT1 will start and die...is it IAC
- Annual G.M. Performance Parts Garage sale?
- Cam shaft for LT-4
- Cam sound clips...
- White smoke? Do I worry?
- Those of you without front swaybars...
- I done a Very Bad thing
- should I get a M6 or stick with A4
- Pacesetter headers,burning wire HELP!!
- where can i get a fuel line
- Got LT's do i need LT4KM?
- EGR Valve
- (ATT Injuneer/Shoebox) Low Vacuum with new Hotcam install...
- Need bottom line answers on !EGR and !AIR and effects on gas mileage
- S&W racecar rollbar
- Exhaust
- Quic Opti Install Question
- Whats next (mods)?
- LT1 396 Stroker questions
- Stupid Turn signal covers!!!!
- Anyone know the surface temperature of an exhaust header?
- Some stroker questions
- Rear Airbags
- Stall after hard turn
- Water Temp. Gauge
- Cooling
- SVO's??????
- Just ordered CAI...
- DO i need bigger injectors?
- How hard is it to replace the conv. top frame, yourself??
- Wiring difficulties
- 02 Simulators
- complete engine swap
- New Member....Quick Questions....
- Short Throw Shifter
- Strut Tower Brace
- Pro 5.0 install...quick question
- Install Websites?
- Dyno #'s with XE 224/236...anyone??
- ls1 and lt1 fuel pumps the same?
- LT1 short block....same as any SBC?
- Paging anyone w/ Pacesetter headers
