  1. hpp need vin cleared?
  2. Engine is runnin hotter after Headers
  3. Bent pushrod
  4. Looking at cams again..any thoughts?
  5. $1000. What should I do?
  6. need new Rotors wich ones?
  7. Opti- Rotor melts down & disintigrates into cover 2x/6h
  8. Oil Pressure question
  9. Clynder Head Torqe Pattern for LT1?
  10. How do I know if my intake manifold is leaking?
  11. car missing bad
  12. Service Engine Light
  13. Solved my 2000-3000 rpm stumble!!!!
  14. How to align a stock y-pipe?
  15. Full throttle, won't shift into 2nd????
  16. Guys that know Engines (general engine question)
  17. A little off topic (ok, way off topic)
  18. Stumble At Low Rpm
  19. Fan Question
  20. Whats a good coil to buy?
  21. Best way to load suspension with car in the air?
  22. What would cause a pushrod to come off the lifter and rockerarm?
  23. How much will 3:73s help me with ET STREETs
  24. Fried Wire?
  25. Should I buy these?
  26. LT4 vs. LT1
  27. Anyone unhappy after putting p&p heads on a cammed motor?
  28. Anyone with ASM headers
  29. While changing oil...
  30. Getting a Scanner - Suggestions
  31. confused about injector upgrade for wet nitrous kit...
  32. drop 2k and go for hte ls1 or lt1 build up just as strong?
  33. Broken dipstick tube look's like a P.I.T.A.
  34. what would it take me to go 12.s???
  35. What Exhaust Should I Buy???
  36. 97 SS exhuast tips
  37. 355 build
  38. Anyonw change their oil pump w/o rebuild
  39. 4 quarts of Honda ATF-Z1, okay for M6???
  40. opti..plz read
  41. Those with SLP dual cat shorties...
  42. Part number for a TPS sensor...
  43. help putting on shocks
  44. EGR soda can mod?? help
  45. Bearing Squeal
  46. jet hot long tubes
  47. Washer Seals aournd the Reverse Coolant Bolts????
  48. Thanks to SAR2K..........
  49. Small exhaust leak on Hooker LT's
  50. LT4 conversion
  51. AFPR that bolts to the stock rail and fuel lines
  52. Need a CARB # for the JBA headers, help me out.
  53. ignition cylinder replacement: turn signal harness removal?
  54. Need Help and Totally confused
  55. Free mods...?
  56. car wont start
  57. Cold air intake
  58. Front license plate frame
  59. tick tick tick grrr
  60. performance shift button install
  61. My radio quit working>>>
  62. Car died, along with windshield wipers
  63. Autometer Tach only works undr 5K
  64. Air Bag light after LT install
  65. brakes
  66. wide open throttle switch install
  67. Long Tube Guys.... Does your starter get to hot?
  68. AIR crossunder pipe
  69. 12's with lt's and hotcam?
  70. late model dash swap...
  71. car is ticking and coating back of car with black soot
  72. Front main seal leaking BAD
  73. VSS Question?
  74. 3 in. vs 3.5 in. vs 4 in. exhaust
  75. GM847 cam?
  76. Finally got some pics of my car
  77. Spark plugs.
  78. seat belt lock
  79. Whats an out of balance engine feel/sound like?
  80. GMMG on stock manifolds (vid inside)
  81. Vote on Pilot Bushing or Bearing.. and why
  82. Smoke rolled out of CAI ....WTF???
  83. Did I get a good deal?
  84. Help, can knock feel like a missfire?
  85. engine stalls after running normal???
  86. ported lt4 heads and WHAT CAM?????
  87. horsepower
  88. About Weld Pro Star Skinnies???
  89. *Pics of Relocated Coil*
  90. I need cam selection help.
  91. rear deck opener
  92. Fuel pressure regulator problem
  93. Diagram for hoses on the charcoal canister/gas tank area?
  94. 1.6rr
  95. vert truck space?
  96. HPP III, worth the money???
  97. Wierd Intake Manifold Question
  98. Cat Glowing - Is this normal???
  99. What size screws?
  100. What have I been missing?!?!
  101. lloyd elliott head porting
  102. Removing the cat
  103. Trans Am Or Trans Am Gt
  104. Tubular K-Member Advice
  105. Help! Car won't start.. errr..
  106. what weight oil?
  107. paper air filter to replace K&N FIPK filter
  108. Unable to Solve Valvetrain Noise?
  109. How to plug holes after !EGR
  110. Lifters
  111. A/C compressor pulley and clutch assembly louder then hell!
  112. Hooker y-pipe for LT1 Hooker longtubes
  113. High pitched whining coming from MAF
  114. oem ram air on 94 trans am
  115. Moroso oil pan part numbers
  116. LT1 edit
  117. trans question
  118. Why do I get better milage on 87 than on 93??
  119. 6th gear, low rpm, high MAP hesitation insight
  120. why do i idle at 1100 when the car is hot???
  121. Rocker Arms won't clear valve springs
  122. No Light!
  123. SLP Y Pipe
  124. Cleaning MAF
  125. AIR! and M22 bolts
  126. how much would u say this costs
  127. Remove SES light
  128. adjusting rockers??
  129. What exactly constitutes a 'Balanced & Blueprited' engine?
  130. New Leak
  131. Engine??'s
  132. HELP!!!! My hatch won't latch.
  133. Getting up to 20 deg. of knock
  134. Long story, possible problem causing slight miss.....please read if you dare
  135. Ls6
  136. Trap speed question?
  137. power window motor??
  138. air intake sensor
  139. whats the best i can do?
  140. Stock WS6 cat back exhaust
  141. Two peice main seal crank and LT1
  142. 1994 camaro lt1 cap & rotor
  143. Polished Radiator Shroud...WHO?
  144. AIR tubes on MAC header question
  145. Fuel filter question
  146. How to put in water pump shaft seal?
  147. Need ideas where to look for troubleshooting blown fuse
  148. 96 T/A Rough at Idle...
  149. Swithced OBDI to II What wire do I need for ALDL??
  150. best/cheapest way to get 300rwhp
  151. help me run 13.1-.5
  152. quick question
  153. Questions about GM847 cam
  154. Cost and Location of Cheap Replacement Optis?
  155. anybody who has done a older 350 conversion
  156. Tach wire corresponding voltage with rpm
  157. SLP dual dual help!!
  158. Electrical
  159. opti, cost to much
  160. ? about car with burnt wire and backfire
  161. alternator parasitic loss
  162. plug wire installation
  163. Kleen Wheels
  164. SA rockers with guideplates
  165. whats a good cam w/o too much lope?
  166. I need somebody who can dyno tune in the bay area...
  167. What grease for poly bushing in BMR LCAs?
  168. got heads flowed,need cam help
  169. ?s about welding relocation brackets
  170. Where to buy cheapest waterpump?
  171. gear swap times
  172. Need substitue pulley after removing AC compressor
  173. How hard to remove A/C compressor?
  174. Can you have both a CAI and the SS air box on 94-97's
  175. So my car is pulling to the right slightly...
  176. SES light and codes
  177. Stb???
  178. Causes of low RPM Stumble/Miss
  179. Dirty intake
  180. Engine is in, starter doesn't turn and other weird stuff....
  181. coolant problem
  182. Edelbrock Heads?
  183. coolant light?
  184. Anyone have Stainless Works 96-97 ORP?
  185. Rocker Arm Studs
  186. Suspension 101 - Questions
  187. What Header gasket to use for the Hooker LTs?
  188. All Those With Qtec Cutout
  189. (Line Loc Instal) ABS Light & No Code=?
  190. Hve A Major Problem, Need Help Asap.
  191. B+M shift Kit problems
  192. What best converter for mostly stock?
  193. new block
  194. need help on coolant lines from heads to TB
  195. Help on GEAR install
  196. How come everyone with true duels have turn downs?
  197. How can you tell if you have a misfire?
  198. Need help
  199. LT1 Picture...
  200. T-Top weather stripping
  201. Need Urgent Help, Transmission Going Crazy
  202. rears brakes rubbing...quick help
  203. Help: Front Bottoming Out? Air Dam Scraping!
  204. Which LCA's are for me?
  205. What causes an SES light while driving for more than 5mins in 6th gear?
  206. What should my car be shifting at?
  207. vibration after header install
  208. Programming the key fob to car
  209. Both Power Windows Quit Working After Car Wash???
  210. Two thumbs and a big toe up for PCMforless!
  211. Plug Wires
  212. Fuel Guage problem
  213. More XE cam dyno results.
  214. Really basic Ignition Coil Wiring...
  215. best exhaust for a 95
  216. 1.6 rollor rocker on stock motor
  217. Alternator Bracket pics, Dont know what bolts go where.
  218. Loose Catback?
  219. Fireworks unger Hood
  220. Need Help With Car Asap!!!!!!
  221. What is the most ci an lt1 can be?
  222. ZR-1" on Z-28?
  223. best Intake Elbows
  224. Head and Cam time! Help me make a comprehensive list of parts!
  225. Could soemone please tell me exactly what is back pressure?
  226. What would strenghten my body more?
  227. Which stroker parts for NA CC306
  228. LT4 conversion?
  229. crankshaft pulley???? NEED HELP!!!!!!!!!!!!
  230. Another roller rocker ?
  231. crankshaft pulley???? NEED HELP!!!!!!!!!!!!
  232. Honda ATF is really good.
  233. Do I need the install kit to fit on the loudmouth?
  234. Thanks to all for helping me find my short
  235. Just finished intake man. install, wheres this hose go?
  236. Universal Plug wires
  237. coil problem?
  238. Need Help Selecting Camshaft for 383
  239. Engine mounts
  240. Holy smoke - New found power with Lloyd's heads!
  241. What else could it be....losing coolant :(
  242. How much HP from 355
  243. Top end rebuild... Need some help.
  244. going quick with manifolds
  245. Question about Waterpump. Been sitting for awhile and its hard to turn.
  246. ignition / coil upgrade
  247. Need pics of your homemade LT1 CAI..
  248. Free Mods
  249. new pcm
  250. my throttle response sucks
