  1. Any good shops that know LT1's in CT?
  2. what should i do?
  3. Took off valve cover..FOUND THE PROBLEM..what does this mean?
  4. SES and OBDII...
  5. Question about exhaust manifolds.
  6. Possible Opti problem, please help!
  7. Any of you Mufflex catback guys have soundclips??
  8. guess my time w/ my mods
  9. Taylor OVC wires and stock manifolds?
  10. Felpros Website shows same part # for Camaro and Impy Head Gaskets!!!! HELP!!
  11. Which oil pump pick-up to use?
  12. Question on lifter retainers so lifters dont fall during cam install
  13. Electric W/P o-ring pn??
  14. Dowel pins necessary?
  15. Need part no.
  16. noisy injectors or bad lifter?
  17. 160 thermostat
  18. Nitorious LT1 stumble, whatcha think?
  19. Let me know what TC you have or had...
  20. car died, wont start, no spark please advise
  21. MAC or Hooker LT Headers???
  22. dual cat MAC ORP?
  23. What size is an oil pan bolt?
  24. accurate stock LT1 in Desktop Dyno?
  25. Question on wheels
  26. what voltage for maf?
  27. Anyone read the info tech section of this month's GMHTP...?
  28. Something is draining the battery...
  29. Will I have PTVC Trouble with my Heads Decked .030 a .039 Gasket and this cam?
  30. Need ft/lb ratings...
  31. Vented opti conversion,... what do i need?
  32. LS1/LS6 into a 93 f-body?
  33. Oil Pressure Drops on hole shots.........?
  34. How do you figure correct 1/4times for diff. elevations?
  35. Suspension Q's. What's the differences? Lowering, etc.
  36. Any Ideas
  37. Hooker shorty header install this weekend....Need suggestions.
  38. Blew my rear. Does anyone make re-build 12 bolts? Or am I looking at $2K for a Mosier
  39. Another Wheel Question
  40. Fuel Injectors
  41. MAS direction important
  42. oh my god went to track last night 13.5 at 100 please come in cant be!!
  43. Track tommorow! What will I run?
  44. part #...
  45. I hate bench racing but....
  46. Vibration problems - You will ABSOLUTLY NOT believe this!!!
  47. Swapping thermostat?
  48. New Borla sounds awesome!!!!!!
  49. How to Change Pinion Seal?
  50. What does "knock" sound like?
  51. What Exactly is a lean Condition?
  52. Important Info on lashing out the rockers
  53. Ordering Tires today nitto or yokohama?
  54. how to get 400 rwhp ?
  55. Revalving necessary for DMS springs ?
  56. Engine stalls from time to time
  57. Scaned SES Codes
  58. need help changing blinkers and side markers!!!
  59. Anyone know what the wheel stud size and thread is?
  60. Help car does not want to start
  61. engine light
  62. If it's not one @%@#$$% thing it's another.
  63. Bad vibrations at 3000-4000rpms.
  64. Hmm wtf Density altitude is messing with my head, Please help!
  65. Lifters for LT1/LS1
  66. Coolant Passages in Intake?
  67. TB Bypass on 97Z
  68. Map sensor volts and spark advance readings
  69. How much does a K member usually cost?
  70. Any idea on prices??
  71. Just go my PCM back!
  72. Quick question on trouble codes
  73. Electronic Spark Timing
  74. Gear choice for auto: once and for all, 3.42 vs 3.73
  75. Where is the best place on the body to jack up your f-body??
  76. how much should i tighten the stock rocker arm to? ASAP
  77. 5% more power with fuel additive?
  78. o2 Simms Pre-96?
  79. Changing my rear but staying with the 10 bolt
  80. Smoke from dipstick and oilfiller cap??
  81. Shorty headers for 93. Will they bolt up to the stock y pipe?
  82. dynaspark??
  83. '93 rough idle when cold
  84. How much $$ for a shop to change valve seals?
  85. why change to OBDI??
  86. Backfire between shifts
  87. Problems with mounting Lakewood D/S safety loop.....
  88. Cam Breakin???
  89. Ever since I got the car tuned it has felt sick...
  90. Do the Cometic head gaskets require sealer?
  91. Jet-hot LT parts list
  92. Would the egr cause.....
  93. My steering wheel shakes/vibrates a bit....
  94. best heads
  95. My car just gets slower...
  96. edelbrock head and cam package
  97. $1,300 to fix my A/C????
  98. Timing Chain choice....
  99. Snapped a bolt trying to remove the cats
  100. How much does fully loaded 95 T/A weigh?
  101. fan switch
  102. Can i use the stock retainers and locks on CC 983-16 Valve Springs?
  103. Preventative maintenence on AC system.
  104. Speedometer recalibrate for 3.73
  105. Need help with header install ASAP
  106. TPS Bad?
  107. 02 question
  108. somebody school me on heads!
  109. Question on ABS idiot light for GM Techs here
  110. way to bypass compressor? quick!!!!
  111. Anyone want an LS!?
  112. how many quarts of trans fluid?
  113. Spark Plug accident
  114. BMR Torque Arm Install ?...Lowered & Moser 12 Bolt
  115. spark plug/wire replacement method
  116. NEWBIE here...Fill me in on these LT1s
  117. LTCC users!! What wire do I hook my MSD window switch to?
  118. Good drag strips in cincinnati
  119. Brakes Are Pissin Me Off!
  120. Car STUCK in OPEN LOOP!
  121. 2 weak cyls.
  122. 314/292 Rwhp/tq
  123. Air/Fuel Gauge?
  124. TB Question
  125. So I think I got one of Jet-Hot's "test" headers
  126. Lt1 Tpi?????
  127. LT1 swap wont start. PLEASE HELP!
  128. Anyone here purchase one of these???
  129. Gains from AC Delete
  130. when i put springs/shocks on do i want to put LCA's at the same time?
  131. What Air Filter Is This
  132. loss of power
  133. Removed ram air box vanes...looking good
  134. car beeping?
  135. after cam install will car start????
  136. DYNO PULLs???
  137. can i use universal plug wires?
  138. Q about installing new lifters?
  139. Springs: On their way
  140. Headlights
  141. MAP sensor issues - wiring experts needed
  142. Intermittant starting/electrical problem - Please help
  143. adjusting rocker arms
  144. best way to change #1 wire
  145. headlights shaking
  146. More Trouble Codes ???
  147. So if you bleed down a lifter when the car is off...
  148. Fixing the problems UPDATE:
  149. Are these Pro Mag Rockers Fugged up? Pic
  150. RKsport airbox?
  151. Oil Pressure
  152. First time track results!!!....what should my next mod(s) be??
  153. Jacking up engine...need help soon!
  154. My turn for new opti. odd ?s inside
  155. Hesitation still there!!(Part 2)
  156. Part Numbers
  157. Seized Motor
  158. Poly torque arm mount, need help!!
  159. need 5 minutes from ANY LT1 owner ASAP
  160. *Possible* Mystery hesitation fix
  161. Installed the LTCC setup today!! WOW!!
  162. How to Remove Rusty Rotors?
  163. Questions about LT1 to LS1 rearend swap. Help please?
  164. Jet Hot Install: THE Passenger side
  165. RPO Code Help Please
  166. finally got the SFC welded in!
  167. Please help, car runs horribly!
  168. AC line to back of compressor?
  169. What is the power difference between shortys and long tubes?
  170. My car is eating IAC's?!
  171. backfiring? or what?
  172. The same header bolt is lose??
  173. Brakes and Rotors
  174. Driver Side Window
  175. Exhaust Leak
  176. Anyone with an SLP CAI
  177. Radiator needed for 96- LT-1
  178. Intake elbow
  179. Cam and Headers ???
  180. Vote for my next mod please.
  181. What could cause lean condition?
  182. 350LT1 Tech
  183. Need help with jethot install ASAP
  184. How hard to change plug wires on lt1?
  185. Shoebox wiring?
  186. i need to change my elbow in the tb and trans mount!help!
  187. How do these corrected times sound?
  188. Anyone make a 12 bolt support brace?
  189. stock lt1 heads....?
  190. My battery is draining,how do I find the problem
  191. valve springs
  192. What are these heads worth ???
  193. Quick Bleeding question, fast awnser plz
  194. HELP!! car wont start after all this work
  195. Best way to get to and clean the EGR?
  196. Brakes
  197. Is this possible?
  198. what all do i need to buy for a cam swap?
  199. alternator mounting?
  200. Flywheel??
  201. new best et
  202. are these rockers worth getting?
  203. who makes a 1.55 rr for the lt1
  204. 96 SS ram air CAI... filter cover replacement?
  205. OBD-II Codes
  206. XE cam dyno results
  207. Crazy Stuttering...... O2 Sensors??
  208. 94 Camaro LT1 hesitation problem
  209. Valve spring retainers & keepers w/LT4 springs
  210. Anyone install Hal shock and springs?
  211. head flow
  212. need advice on truck
  213. M6 PCM for 700R4?
  214. S-Trim or Nitrous?
  215. shift light questions
  216. Brake and power steering fluid capacities...
  217. How to get off wiper arm?
  218. need part number
  219. lt1 to ls1
  220. hotcam install
  221. Need response ASAP on Dyno muffler
  222. DFI and Speed Pro guys needed
  223. Anyone in cali pass smog w/ hotcam kit?
  224. a 1.52 rocker will change the lift to??
  225. Accel 300 Plus ign.?
  226. How much can i sell these for? TB, Fuel rails/regulator/injectors, egr
  227. NGK plugs part #
  228. Stock rev limiter?
  229. Best sounding and performing cat-back?
  230. Is the LT1 a quality product
  231. rollor rockers
  232. LT1 chokes before hitting red line????
  233. Car wont crank
  234. gear change from 3.23 to 3.73
  235. CC SA wide body rocker arms?
  236. Walkthoughs for LCA's w/ bolt on relocation brackets
  237. Carb manifold for LT1
  238. meziere water pumps
  239. want 11's N.A. with only 3000.00 dollars, can it be done??
  240. Optispark parts
  241. crank sensor?
  242. What mods for my cash?
  243. Injector Circuit
  244. Anyone dyno before & after MAF SCreen? I have head/cam.
  245. Idle stumble
  246. Throttlebody gasket?
  247. Are the clearances in the LT1 same as SBC?
  248. precautions when restarting the car
  249. lt1 stroker kits
  250. Dont laugh, Homemade CAI, how do I seperate?
