  1. Can a stuck caliper cause Brake and ABS lights to come on?
  2. cutout nut comes off bolts/similar results?????
  3. I need some good aftermarket brake pads.
  4. cai
  5. doing a water pump removal/install got a couple questions
  6. DEI Exhaust wrap
  7. HUH... I wonder......
  8. How can I make my car feel lighter off the line????
  9. What is the largest tire size I can put on a 17 x 9 rim?
  10. why isnt my car shifting at WOT
  11. What size inectors??
  12. What is going on with my spark plug wires?
  13. B4C Police Interceptor
  14. Help, popping noise when I open my door is driving me nuts!
  15. Great day for the LT1 (dyno day)...
  16. Help, popping noise when I open my door is driving me nuts!
  17. 224/230 536/544 lift is in and running video's inside
  18. Fuel Pressure problems...
  19. car bogs hard when started WTF???
  20. A/C and cam install question
  21. All with LCA
  22. wierd rattling noise, help
  23. Opti cap and rotor ?s
  24. 94 Camaro Z28
  25. Rippin'er Clothes Off
  26. fans not working properly
  27. Fuel Problem
  28. E Brake sensor?
  29. Decode the RPO Game!
  30. Keyless Remote Replacement
  31. EGR help pleaSE
  32. Eletrical Forum??
  33. How do I Complete the TB Bypass
  34. Quick! What all holds the dipstick in!
  35. Is 22 PSI of Oil Pressure using the PF1218 Normal it Used to be 25 with the PF25?
  36. Will my LT1 rear brakes fit on my new 2000 rearend?
  37. Car runs better without front 02's?
  38. Problems with fitment with LM and Sweet-Thunder?
  39. opti install
  40. Eagle H beam - Need ARP L19 replacement bolt part #
  41. Matching numbers
  42. i need help choosing a y pipe
  43. Mobil 1 at Walmart
  44. Clutch issue with brief description.
  45. All hell just broke loose on my car!!!!
  46. guage face ?
  47. tires - bigger on the rears?
  48. Can I convert my opti to vented?
  49. Coolant leak?
  50. Airfoil blocking IAC, car will not idle-what to do?
  51. oxygen sensor help please
  52. midlength headers, off road pipe, and Loudmouth -- I need a sound clip!!
  53. Weight?
  54. A/C recharging
  55. Serious Help Fellas...
  56. Quick muffler question
  57. Need a part #
  58. in depth AC questions
  59. Clips that hold in fog lights on camaro, where to get them?
  60. Mcleod adjustable Master cylinder for T56 Conversion
  61. LT-1 randomly dies.....
  62. Help! Car will not start, Just put motor in..
  63. 1.5 Rr On Exhaust Side
  64. fuel pump
  65. mac headers egr question
  66. What kind of clearance issues will I have with true duels on 95 Z28?
  67. no response from Speed-Pro ECU
  68. windshield wipers
  69. Which ATF and how much?
  70. A/C Compressor
  71. Holy frickin' pancake mix...LT's
  72. prom scanner question.
  73. Have some specific questions on A4 to M6 conversion
  74. How to Fix LT1 Hesitation!
  75. ported heads
  76. fan problems
  77. gear ?
  78. Cleaning sensors. (MAF)
  79. pushrod length?
  80. Alternator or Voltage Regulator Replacement?
  81. Advanced look at subframes
  82. runs fine but lost some power???
  83. Ugh.. Just bought ramps and...
  84. Anybody Have XE224/230 Cam On A 111 LSA?
  85. Power Antenna Broken from CarWash
  86. ****in ****
  87. Hiding wires
  88. What do you use to remove pass side pipe plug
  89. Simple But Stupid Mistake
  90. optispark
  91. computer tuner ?????
  92. after $100 I still have the squeal.
  93. New motor drops cylinders after warmup(possible miss)
  94. Cleaned my MAF, WOW! what a difference!
  95. Fluidampr Questions
  96. Is this a "miss"?
  97. Broke a starter bolt... Now what?
  98. Splayed Main Caps
  99. 10psi oil pressure drop after 5k!
  100. My 94 Z (A4) 4L60E is acting up..need advise
  101. Fuel System
  102. Another overheating problem
  103. Lt-5????
  104. Car Died Battery Dead!
  105. Leaking coolant after cam install
  106. Fitting for TB bypass...
  107. CC305 Idle Video?
  108. LT1 and 87 Octane-will it run right? 87 Octane up to $2.07 here in Phoenix.
  109. thanks to the guys that helped me, i fixed my AC problem...
  110. Lash setting techniques for Sollid Roller
  111. Another Power Windows question: Down but not Up?
  112. Quick Coolant Bleeding Question.
  113. problem with my 95 z28 can anyone help?
  114. Is this the best from to ask for suspension upgarde for 4th gen LT1?
  115. Really High Flowing Heads----l@@k
  116. Weld in or Bolt On LCAB??
  117. bad opti?
  118. My vents don't work
  119. tranny went out!!!!!!!!!!!
  120. What is a good low-dust brake pad?
  121. Alternator Problems
  122. SVO injector installation
  123. i got beat, im ashamed
  124. Oil/Fuel Additives: Truth or Gimmick?
  125. Removing Valve Seals
  126. hot cam install trouble with overheating/poor runnin'
  127. calling all tuners...Madz28 and pcm4less
  128. A/C blowing cool air but not ice cold
  129. ses light after man. fan mod
  130. need work done in glenburnie md
  131. summit fabricated valve covers ???
  132. Just off the dyno…393rwhp/356rwtq, (SAE) stock bottom end
  133. SES light
  134. Big Problem!! Help
  135. "Free" LT1 mods...what are they??
  136. LT4 KNock Module part #
  137. Still baffled!
  138. Removing old motor mounts from clamshells
  139. How to remove knock sensor?
  140. Fuel Regulator Question???
  141. Reverse Flow
  142. Best tool for removing a rounded bolt?
  143. bad MAP and Temp. readings
  144. Did 94 Formula's come with a ram-air hood but no intake???
  145. PCV valve was now replaced and WHOAAAA
  146. Water Pump Question!
  147. 1.6rr on intake, exhaust or both...
  148. LS1 to LT1 conversion
  149. Is my brake master cylinder shot?
  150. What would cause this? (Electrical)
  151. 93-97 body on an LS1? Is it possible?
  152. I have read I can't put a different timing chain on my car is that right?
  153. My transmission sings....why?
  154. Factory alarm question
  155. How's the dang water pump come off?
  156. Broken main cap
  157. Question for anyone with a manual fan switch
  158. how long of pushrod length for deck block?
  159. All else being equal, how much HP per cfm?
  160. brake question
  161. How Screwed am I Part 2
  162. Windshield wipers
  163. Shoe box: I'm still baffled.
  164. computer tuning a 93
  165. anyone ever have the front bumper cover repaired???
  166. Ready to weld in rollcage, but a ? first
  167. Air Pump question...
  168. Time for brakes, what to get?
  169. any body with 93z have indiglo gauge faces?
  170. Props to Bryan, who never ceases to amaze
  171. Misfire Gremlin help
  172. 1.6 RR conv. questions
  173. Is the ground clearnace with Jet Hot LTs really that bad?
  174. what is this?
  175. Launching on DR`s
  176. McLeod Adjustable master cylinder and slave unit.
  177. need more help with EVAP system!!!
  178. aftermarket bumper and fender?? quick questions...
  179. 1.5 to 1.6 rockers
  180. Car won't start when cold, any suggestions?
  181. Tune?
  182. 7.5 inch ford 4.10's work on chev 7.5 inch?
  183. Cylinder Walls
  184. Someone Has To Help Me!
  185. what gears, for long distance driving?
  186. opti spark
  187. How difficult to replce rear caliper?
  188. Where in the HE double L can I find pre-bent brake lines for my 95?
  189. Numbers for a build
  190. Question.....
  191. Cheapest headers & y-pipe
  192. CSI Electric WP question
  193. Knocking from Right Rear
  194. i need some ideas
  195. Do jethot headers come with 02 extensions?
  196. Trans fluid smell through a.c.
  197. Gear Change
  198. fuel rail covers
  199. Stock headunit cd's get stuck
  200. Do headers make your exhaust quieter?
  201. CODE 83 what its it, how do i fix it
  202. Charged A/C with 134 and still not cold?
  203. Stock Oil Pan Bolts part #
  204. 52 mm TB s
  205. Weird SES Light
  206. 3.73 = lower top speed??
  207. The most ridiculous item of the day
  208. 3pt stb ?
  209. Cam for 383?
  210. Timing Set Change Needed On Cam/heads Lt1?
  211. Want some suspension upgrades what are your ideas??
  212. Power To The Ground
  213. Question about opti, rain, and plugs
  214. whats the factory wing worth?
  215. pre oil pump failure symptoms
  216. Help. Is my timing off? Exhaust might be causing perf loss?
  217. subframeconnector pics
  218. rebuilt engine?
  219. LT1 + cutout=
  220. To gut or put on a ORP?? Need top end!
  221. 95 Z28 Camaro Engine Belt
  222. hesitating
  223. Gears and Converter
  224. Duel cats or one cat?
  225. 7k to spend on mods help me out
  226. Driving with MAF unplugged?
  227. cheap 1le???
  228. Remote keyless running on what seems 50% power???
  229. Intake leak
  230. Clutch making "chafing" sound
  231. Plugs and Wires after headers are installed
  232. CC305 guys
  233. 4 bolt lt1 price?
  234. Have 1000 to spend what do i get?
  235. 1994 optispark
  236. best shifter for m6????
  237. Where Can I Buy An O2 Sensor Bung?
  238. To all people that have done the A4to M6 swap. I have a few questions
  239. Why the need for a 54mm tb??
  240. SLP air induction on traction control car??
  241. Should I spin past 6300 rpms with this set up?
  242. 25-30 PSI AC compression??
  243. Installing double roller need help?
  244. FLP owners inside
  245. Usless ABS box, remove? convert? Cuss?
  246. What does a cam package from Combination Motorsports cost these days?
  247. Port and Polish
  248. Sorry off sub. Turbo 400 Trans experts inside.
  249. Quick! BMR Adj Panhard Bar, what size are the jamnuts and rod ends?
  250. Think I found why I failed smog....
