- How to bleed the brakes after motor swap?
- accelerating
- People with Prothane front end bushings...
- need help with idiot lights and starting
- Need some expect help on heads and cam!
- T56 Question
- Throttle body
- How can I change my A/F ratio quickly and cheaply???
- pulling the motor.
- A4-M6 Swap problems (just when I thought everything was good)
- Remove Rust?
- www.eriespeed.com
- LT-1 Mod Websites?
- UNIQUE Question for exhaust gurus..
- Need help on heads/cam
- Hydra Rev - Does it work ?
- Which Spin-Tech?
- Aftermarket Heads
- Vats????? Need Answers Quick
- Idle Problem Semi-Fixed
- Would ethanol make my car miss?
- muffler
- Manual fan switch question
- Plugs and wires???
- help quick please
- Anyone running a 224/236 cam with stock heads?
- HELP WITH STEERING COLUMN/need to ge the car started
- Stroker Motor Question
- rear suspension squeek
- Fuel line broken
- Roller rockers not going on right
- Blocking the EGR
- how bad is valve float
- Need opinion..
- Fouth Gen Rear-End Questions
- Front suspension rebuild
- 96-97 SS Air box install
- my SES light came on, then off?!?
- Ran out of gas
- Help car is misfiring! Need a diagram!
- Lt4 hotcam and Supercharger, good combo?
- tie rods
- Stock Rocker arms with CC305
- Anyone have a pic of the IAC?
- Cast or Aluminum Stock ported heads???
- New Drivetrain Forum
- custom fuel rails?
- A4 radiator with m6 swap
- Tunning without a programmer. Can it be done????
- Star Stage 3 first impression
- 93-94 Owners, vent your Opti!!
- tires?
- 10w40
- ANyone change out to a diffenrent Steering wheel?
- How do you know if your ac compressor is working ?
- heater core ?
- going to do cam wich do you suggest for my car (i have searched)
- ses code p300
- Revving to 6700rpm
- Recharging the AC?
- msd 6a questions
- Mechanic says blown chain???
- Windshield Wipers Slamming Into Cowl Piece??
- What tools are needed to remove the MAP sensor?
- Car runs hot and need some help.
- M6ers ... Lugging, bucking
- How much does a fuel pressure regulator cost??
- My widshield wipers do not park after i turn them off..
- Knock-around Guys
- What should I do while the tranny is out? (auto)
- Engine back fires and misses.
- Is there any reason 17's in front and 18's in the rear would cause a problem?
- hooker LT installation instructions?
- Cleaning TB, MAF, IAC this weekend.
- ram air vs CAI
- Missing EVAP vacuum hoses?
- Having transmission problems, any suggestions?
- any good Lt1 books or videos?
- first round of mods....
- bought a new brake pads, and it doesnt fit the rotor??
- PCV valve question, please help
- PCM tuning,who to go with???
- So How screwed am I???
- flashing SES
- Security Light stayed on Car wouldn't do anything!!??
- SES light due to tranny...what's up?
- People with Detroit locker
- plug for tranny output shaft
- need help with water pump relay!!!
- HP rating on a B4C
- Cheap exhaust?
- 2 or 3 series carrier?
- correct idle speed for M6
- transmission is sick
- Manual fan switch
- PCMforless Question
- help! car wont say running
- IAT Sensor "Error Codes??"
- what will it take for a th350 swap?
- quick question on vigilante install
- questions on flow numbers..int. vs. exh.
- What is the max IAC count
- Hood won`t open
- 3:73's or 4:10's?
- 2.73 guys.... whos the fastest?
- How to get to 550 hp.
- Need help calling BS on a shop!
- TA dash in a 94Z
- Where to put o2 sensors
- Bad opti or fuel pump or what?
- TEA Stage 3 heads/XE230 Dyno #'s and story.....
- $500 to spend, whats the best bang for the buck?
- CAI Question
- Big Plans Tomorrow!
- Newest Problems: Shaking at low RPM, Security Light on, Missing at low RPMs
- Cam guys
- What's your gas milage, my average is 20.5 mpg
- If you have a vacuum leak, will the........
- Low coolant light staying on. Tank/radiator full
- Is a 2600 Stall converter good for me?
- Intake Sensor Modification Resistor
- Getting the fuel pump to turn on...
- need help tuning my car
- No oil pressure.
- Car Won't Idle w/ AC on???????
- any disadvantage to too many crack amps?
- electronic interference possible 0420 code
- How Many Miles On Your Timing Chain?
- AC Kills my battery
- Can't Get A Response From Combination Motorsports.
- what kind of times would this setup get? is it safe?
- Springs
- O Where, O Where has my piston gone? DOH!
- Not happy with one of our favorite vendors
- anyone know if a auto and 6 spd yoke are the same O.D.
- Stock LT1, Hooker LTs, no tuning: will it kill the cats?
- Abs Inop Code: C1286
- NEW DYNO NUMBERS with LT4 hot cam. check it out!!!!!!!
- t-tops
- Shocks and Springs
- Will our cars run w/o the PCV valve in it?
- INJUNEER FRED! I have had this small problem since the blower/obdI swap...
- LT1 Intake with LT4 heads
- cant get injectors into fule rail
- my car is runnin like ****
- Is this Normal?
- IAT Q's
- OOps - Seatbelt Light
- are my rockers loose? car runnin rough
- Burning a lot of fuel
- Mail Order Tune...Where to Go??
- Timing chain went. Any recommendations?
- guys who moved altermator
- THe LT1 is dead............
- Bad Gas Mileage
- opti install
- where can i find the differences between each year?
- A/C is acting funny
- How do you like your Lokar dipstick?
- ABS light and Brake light on?
- Cuttting out.....
- What's the best LT Headers in the market today, for the LT1?
- LT4 Knock Sensor or Reprogram?
- Confused about spark plug wires
- SMOKE at high rpms's what si it?
- Madwolf....can you help?
- reprogramming cable
- I bet you haven't been asked this cam question...
- What would cause hesitation at high speeds(100+)
- Smaller alternator?
- Are these hp estimate close?
- 4:10 + 100 shot
- Rough Idle/Stalling Datamaster File
- how to refill a freon (just bought a refill kit)
- Need timing chain info!!!!
- Weird $hit happening
- Valves out of wack?
- Car feels a little sluggish after 3200 Vig
- What to use to fill hole in sheet molded compound?
- IAT Sensor "How To and Where To"
- New suspension set up!!!
- Belt for the Pulleys
- Can you open up the exhaust side of head to match 1470 gaskets?
- Why some f-bodies have different color top?
- Sway Bar End links
- oil drive gear with solid roller cam
- Bilstein BTS Suspension system.
- How to remove this coolant hose...
- Part # Help
- Bad Mods list in LS1 board
- O2s are in...still backfiring...
- 6speed conversion question
- looking for tremec dealers
- Feather Clutch or Dump It?
- Observations on swapping in a 94 engine in a 93...
- Pro 5.0
- tranny ?
- polyurethane bushings?
- 114 traps with stock heads tonight
- Jet-Hots long tubes
- a4 took vacation advice on stall needed
- Where to go from here? Done all the basics
- Sound Clip Needed : Borla / Hooker with Intake , Headers, and Cam...
- Help Me! I'm Back-airwards!
- 16" take offs used for 28x10x16 slicks ?
- Cai???
- need mods- lost to a mustang
- 97 pcm
- Fail the damn emission test need help
- 96-97 SS air box install ????
- Help please! Cooling problems car getting HOT!
- yep
- true duals
- Bad Torque Arm Bushing?
- adjustable or nonadjustable control arms
- Oil Pressure sender going bad?
- how much hp to break a rearend on the street
- Tranny Please Help!
- Radiator leaking from drain valve...help!!
- Whats it mean when.....
- Trying to change pass. side plug wires
- Fast Track harness install question
- To all that went from A4 to M6 how much low end did you loose?
- Can having No cats and no emissions on a car make it smoke a little at high rpms?
- Modifying an aftermarket head to fit LT1's
- remove crank pulley?
- Anyone using Freescan??
- Any way for me to tell if the posi is toast?
- Major overheating after starting!>>>
- How much Hp gain from thinner gaskets???
- Power shifting
- are ET streets DOT approved tires???
- Problem since headers
- What gear do I have????
- What would cause this?? Stalling/No Idle
- Can I move a car after the motor is dropped out the bottom?
- where to get delete pulley & belt?
- NO Fuel !!!!!!!!
- Will 285-40-17 tires fit on 17/9" rims?
- Scanmaster Question?
- necessary to take apart spring/ shock during install?
- car doesn't start, need help
- Online repair manual
- a/c comp part # anyone?
- Urgent Need Help
- Well my day was going pretty shi*** but man did my car make it worse
- Can a bad fuel pressure regulator make your car die??
- Removal of Tranny dipstick for LT's?
- OIL PAN GASKET!!! HELP!!! In the middle of doing it.
- engine almost out
