- Radiator Hose?
- Anyone with SLP headers?
- msd blaster coil
- My Dyno numbers?
- drag shock question. please help!
- idle vacuum for cammed cars
- Cruise control, ABS, shifter and steering linkages, wiring harness ... PROS/SHOEBOX!!
- Tomorrow!!!!!!!!!!
- Guys who rev their car and get the pop sound at the end read inside..
- 315/30 18's?
- does my SPEC ressure plate need to go on certain way for balance
- looking for somone who does powder coating
- Two raw eggs in the radiator and call me in the morning.....?
- weird bounce
- short block build ?'s
- lt1dave.com
- blown head gasket, NO PROBLEM.....but, is this for real??
- Scary Valvetrain Noise
- Hawker Genesis G16EP lightweight battery good for my application?
- bad o2 sensors can cause my car to run rich??
- 75% water and 25% antifreeze safe for anti-corrosion and WV winters?
- any one have bbk headers?
- Need Your input on this.
- Cat Rattling....
- How are the 02 sensors supposed to ready??
- Torque converter cover.
- T-56
- Need Help...asap
- were to buy nitto's on-line
- How many say no to radiator stop leak?
- Brakes/rotor need replacing...advice?
- 30lb injector p/n
- Engine wise whats the best way to go?
- Problems with AFR heads and FLP Headers
- ? about rebuild....cam/timing chain/opti,H20 pump?'s
- is it worth changing ONLY the cam?
- cat or O2 sensor?
- 30th ann Z28, how much?
- best mod for under 500....
- Pinion Seal and Ring Gear Question
- How much gain from switchin 3.23's out for 3.73's? M6 !Guru's only!
- Anyone Run a HotCam with their 383? If so, any numbers/times?
- 30# Injectors???????
- IAT, Low RPMs Stumble, K&N relationship?
- Stick with the 3.73 or go to a 3.42
- installing aftermarket speakers
- Hey whats this crap about the Harmonic Balancer?
- Cheapest Place To Get Goodyear Egale F1 G3
- Scanmaster or Autoxray...
- Pro Magnum 1.6RR's
- LIst of all the free mods...
- questions for the guru's
- O2 sensors??
- Fuel pump question
- which header will work
- Torque Arm bracket on tranny top bolt size?
- hot cam install-loud ticking-help please
- RPM Vs Speed....What is it
- Converting Over, My Mustang Sucks!
- random miss but no code please help(long)
- y-pipe an longtubes
- SES light after header install!!
- Thought this was weird....
- Dropping the K-Member; Instructions
- Anyone running 500+ h/p and 3.5" or smaller exhaust???
- Rear caliper mounting bracket
- plug
- Anyone know the K&N part #
- Found a 97 Z28 6 spd. w/74K for $7950
- Good installation prices?
- what's a good tuning program??
- Drag Radials?
- Which Transmission and Gears do I have?
- Low Oil Light on...no oil leak
- I Think I have a bad FPR or leaky injectors
- Which Plugs to run?
- Tranny Rx
- shift points w/ xe 224/230 112
- Change in weather = enhanced performance??
- Best cats and mufflers for true duals
- Anyone with Edlebrock headers and..............
- Part Number Help....
- What all can cause a high rpm miss??
- Should I Change Injectors
- Alternator
- Forest Green Z28....$3300...what do you guys think? ( More info )
- Backfiring like a MOFO/Burning after LTs
- How do O2 Sims work?
- Low oil senser
- Fuel pressure regulator location????
- Gear Change?
- From LT1 to v6.
- Spin bearing
- SLP and MAC headers?
- does anybody use octance boost??
- Max RWHP on stock heads N/A.
- lt4valve spring?
- Thoughts after installing Racetronix pump "the RIGHT way"
- xe cam ?
- shift kits
- 95 Z28 Camaro Trunk
- LT4 Hot Cam Setup Vs. MD Emissions
- The BIGGER Oil Filter!
- new track times
- Best Price on Hooker Exhaust
- 95 Z28 Camaro Solid Roller Cam
- Oil pressure woes
- Mass Air Flow Sensor 1995 Z28 Camaro
- Initial Dyno Numbers with 224/230 XE
- weird ass problem w/ car! Anybody got any ideas??
- I am so sick of my car!!!!
- What is this cord under my hood??
- which would you swap out first?
- What times SHOULD i be running
- LT1/4 Starter Differances?
- relocation brackets required for aftermarket LCAs? or just better to have?
- valve spring installed height??
- Corvette vs Camaro
- What is the best RWHP from a 396?
- Question for shoebox.
- Engine Blown! Whats next????
- Do I have a bad lifter?
- Do your A4's shift like this?
- Anyone ever have their Posi break (not the gears)
- Comp Cam 305 Questions?
- LT1 probs: will start then die
- Attn: Shoebox, Coil test question
- Clutch problem (any suggestions?)
- Oil Cooler Removal!
- Brodix Lt1 Heads? Flow 308!
- ram air hood?
- LT4 hotcam and 1.7 rockers
- Thinking about taking my CAT's off?
- My first time and I suck!!
- Does anyone have a dropped suspension and true duals?
- biggest valves in stock LT1 heads?
- 02 sensor ?'s
- Hooker Y pipe ??
- VSS leaking
- heads and intake manifold cleaner
- why did this happen?!?!
- Wingbut size on flowtech cutout
- which springs for cam (cc306)?
- Flowtech Warlock?
- Dynatech long tubes
- Widest and smallest sidewall for Kumho's
- Random KR and other weird readings log inside
- Injectors, LT1 and LS1 the same?
- 218/224
- 9 inch question
- Has trouble starting when hot?
- Does the defroster on our cars kick on the A/C
- Wierd Sound
- Flywheel balancing question
- Why do i keep going through alternators?? Also question about a/c delco waranty
- How to install driver side motor mount....
- Opti-sensor?
- are hooker and jethot problems the same for tpis and as&m?
- ABS in 12 bolt
- internet how to?
- I bought a moser 12 bolt used...
- under dash connections
- AC compressor storage
- window help
- HOW TO REMOVE AC COMPRESSOR?!?! SHOEBOX! (again)
- Rough Idle problem
- Flywheel???
- Do most people take out, or add timing when tuning your car OBD1
- AC = less power
- HELP! Car running like crap after Headers and Cam
- Oil leaking.....
- thread of m6 shifter?
- Data Logging Software
- Removing Cone of Silence
- Having problems installing crank gear
- I need a new (used) computer (A/C problems)
- How To Remove EVAP Purge Solenoid?
- guys with ported heads& xe 230/236 what stall are you runnin
- AFR 190s or Ported LT1 heads for 383 / part-time N20 engine
- rebuilding rear calipers
- Gear Grinding
- AC blowing warm air caused by a bad PCM??
- what kind of hp gain
- How loud are roller rockers supposed to be?
- How much trouble can i get in for having a off road pipe?
- Vibration above 60mph with energy tranny mount?
- LT1 swap into 3rd gen. Should I use Mass air or speed density?
- suspension
- BAD hi-speed vibe.
- Radiator Baffle ...
- Bad alternator, or maybe a bad battery?
- 398 or 383
- LT1 to ---> LS1 brakes
- My A/C system is screwed up....
- valvetrain ?s
- What is a good ign. on power source?
- Annoying Rattle
- Crank pulley install...
- correcting the MPH difference with 4:10 gears
- Frozen Power Antenna
- O2 Sensors
- need some help please
- GTP's vs AFR's
- intake
- Opinions On Changing Oil??
- Running Hot
- Steering problems
- Balancer?
- What makes Comp R lifters better than OEM?
- driveshaft vibration
- What is the best fuel pump for my setup??
- Can pcmforless.com do.....
- HARD starting, cant seem to find the source
- Need software for a 97
- STR....stall....streetabilty
- can't get the clutch fork in-what am I doing wrong
- Chicagoland area, anyone have a Cam Retainer Plate laying around?
- Is there a website for LT1 engine torque specs?
- I think i may have a factory FREAK
- How tight should these front latches be on my vert?
- Those who have done the A4-M6 swap, or wiring gurus
- Tips on 02 lengthening
- Wow my mechanic just said my fuel pressure was in the teens (need advice)
- Anyone added 2 "MORE" bullet mufflers to their True Duals??
- Dyno Question
- fuel pump
- injectors??
- New Low Oil Level Sensor!!!
- changing thermostats?
- HELP! My LT1 has become a 4 cylinder.
- Locations for temperature gauges
- O2 sensor and ses light.
- Rpm@60 Mph
- someone give me some help!?!
- You can't have any cooling if you can't heat your meat
- Poll for guys who have relocated there battery!
- knocking, clunking or tapping noise
- need help with catback pipe purchase...
- chugging
- ticking
- Airfoil
- Forged LT4 383 ready next week, what will be my rwhp?
- This Is Hard To Explain
- Gear whine...or not?
- idiot lights
- no more 6 banger--i got a V-8
- LS1 12-bolt in a LT1 ?
- Intake elbow
- First mods to LT1?
- need help
