- Wet inside bellhousing area
- Where can I listen to slp loudmouths
- how much to sell my car for?
- oil smell help
- Signs of a bad opti?
- can you use self-alligning rockers with lash caps?
- Anyone wanna do an Opti install?
- help with electric cutout wiring
- Ram Air Airbox--cut out the vanes?
- Fuel Lines From Tank foreward
- Fuel Problem Please Help
- which is better? loudmouth or hooker exhaust systems
- 383 Dyno Numbers See Inside
- What all do I need for headers?
- 1.6 Rr
- ac problem, compressor doesn't click on
- Hot Cam Kit and 383
- 6a boxes
- engine flush
- Dyno numbers
- what kind of powerr out of a cc306
- Hotcam 1/4 mile times
- Picking the engine and trans out together from the top? Is it possible?
- can't get coathanger things off
- bad misfire/vibration please help asap
- Buying an LT1
- Just CHanged plugs and wires now huge problem
- Problem with 95 Z28
- coolant fans
- another tranny/ecm question
- 383 Stoker engine
- AirCar Results - Feedback Plz
- ABS INOP light came on. Why?
- Spark plugs
- True duals or Mufflex 4" ???
- Spinning tires
- 12v power sources...
- have aprox 1k to spend on mods
- Which tach wire for shift light?
- Cat...
- need part fast where to order from!!!!!!!!!!please help
- Can we use 1.7 Or 1.8 RR
- Security Light is comming on. Why???
- cc306 question
- Best pully kit to get???
- Gas pedal on my LT1...
- P1870
- put a new IAC in!! Please read...
- harmonic balancer pulling question, help quick
- What do you prefer using when doing exhaust work?
- will Hooker LT work with sportline drop kit??
- Oil leak at the Intake???
- Shoebox's Cam install Guide
- 17"x11" ZR1 rims
- Ses Help
- Cross Drilling Stock Rotors Yourself?
- Buying a used Cam?
- Solid Roller Camshaft in LT1 383
- How to pick up a tenth or 2 for under $300?
- bad day for the z28
- what to spend my cash on....
- o2 problem
- How to take off moroso intake? (sp?)
- Estimated 1/4 mile times?
- Solved my Hesitation!!!!!
- Can I use an MSD or Crane box with my LTCC??? Thanx.
- How to take off the Fog light and ad a new bulb
- Air Conditioning Rattle
- Low Oil Level Sensor BROKE!!! =/
- Newbie Question. What do stock LT1 heads flow, intake and exhaust?
- Hesitation = pissing me off really bad
- Anyone using Metco Adj. Fuel Pressure Reg. Kit?
- went to the track again
- Guys who got gas mileage increase on MSD 6A or 6AL inside
- A4 shifter
- Radiator fan is being weird.
- high rpm (5k or so) miss???
- grrr, it's dark in here!! help!
- what should i buy now?
- 3.73 series
- brake pulsation problem
- Engine out of the car... how to remove the tranny? (auto)
- Aluminum heads on a 93?!
- what are the specs on the hotcam kit springs?
- Fuel, Spark, Compression, But Still Won't Run!!!
- Underdrive pulley
- would this work?
- Oil cooler questions....
- Just pulled my motor today....WHOAAA
- What could I charge to change.....
- How many bolts?
- window motor questions
- Have questions about rearend parts and removal
- Removing Engine
- Quick Question....What size is the fuel tank in a 4th Gen f-bod?
- Pcm
- banjo bolt part #?
- 12bolt rear end- bolt axles or c-clips?
- strange annoying problem after 52 mm tb install
- How long for a cam swap?
- ATI Super Dampers. Anyone use them?
- tranny problem/question
- Can you cross two of the OBD-1 pins to clear a code?
- putting headers on
- Whirring/moaning while turning hard?
- Best CAI
- Scanned the Z and came up with these codes
- looking for headers 5/8 for 94 Z single cat
- Is my combo maxed out?
- 52 MM TB question
- Hotcam w/1.5's, but not tuning, how will it run?
- Do I really need the installation kit for the LM exhaust?
- what kind of power are you 383/396 guys putting down?
- Infamous intake leak....
- ls1 airbox on a lt1?
- Cam???????
- Big TB whats the purpose?????
- anyone know how to delete the ABS box?
- Fuse Box
- 2-steppin a 6-speed
- 2 Q's about Victor style intakes for EFI and rear mount dist.
- car won't start
- Anyone using Royal Purple ATF?
- suspension?
- Which water pump is everyone using?
- cam assembly lube
- need racetronix fuel pump directions for install.
- Hows this log of my 383 look? (datamaster)
- How Can you tell an Opti is Bad?
- Powerband on Hot Cam???????
- plugs/wires help - bracket removal?
- Crank Pulley -- Seperated?!?
- Can you just swap the lt1 for ls1 rear brakes ???
- What is this wire?
- Where can I get some light weight carpet
- My setup
- Those with Quicktime electric Cutout?
- True Duals over the axle???
- Help! car lost 4-5mph over last year
- !MAF vs Stock MAF...Track #'s inside...
- What rotating assembly do you guys think is good?
- Need clip of LTs with catbacks...
- What is the sensor underneath the trottlebody?
- so PISSED off, I think my waterpump is going? Have to yell at shop!
- trans mounts?? poly???
- Shift light
- oil pressure questions?
- Estimated HP
- 96 SS stock CAI vs K&N CAI...
- Need A transmission
- 700r4 in 93' Camaro?
- How to refill the A/C
- need part # for coolant hose, how much for windshield?
- Will it fit?
- Help Removing My Lower Ball Joint
- help me! why is my car backfiring?
- Waterpump and Opti Removal Instructions
- WP Driveshaft
- Fuel Pressure with CC224/230 & heads
- Help!!! Tranny guys enter
- How do you bleed the air from the cooling system
- How does the Oil pressure sending unit work??
- what would it take to run a 4L60E in a 93 Z28 originally equipped with a 700R4?
- Anyone else using ACCEL injectors?
- What kinda numbers are you running with p+p heads and 224/230 cam?
- 1.6rr and stock valve springs?
- Stock valve covers and Magnum RRs
- Someone asked me this today....
- How many grease fittings on 95 Z28
- What am I missing? pic....
- How to delete EVAP system without SES light
- Dipstick differences and 4 bolt mains
- Tell Me a Tale...?
- Fuel pressure with 30 # injectors?
- Tranny making funny noise
- Best header gaskets for hooker longtubes
- Where are there cheap parts online?
- What temp do fans come on at?
- how to change coolant sensor?
- lt4 conversion questions
- what is this?
- gmmg?
- what springs do I have? (pics)
- All 9-11 second cars running a six speed
- All 9-11 second cars running the T-56
- ported heads on a stock motor
- Would having too much oil...
- Best way to find out what gears i have?
- what engine block is stock for lt1
- Roller rockers and springs?
- A few problems with car. Plz help.
- Car running rich, why?
- Is anyone else's gas Gauge off ?
- Cooling fans only go on with A/C??
- 4.10's... too much for a stock LT1
- 4L60E Speedometer reluctor wheel part #
- Best performance gains for around $1000?
- Worrying about Emissions
- Drivers Side Wiper Blade!
- Map Sensor
- Car has trouble starting?
- gas guage
- ABS light is on constantly
- Cooling-Fan is running all the time
- Anyone thinking of rebuilding their motor, check this out
- having problems with this rebuild
- Is it worth it to get an opti rebuild kit?
- Intro and Question
- Best CC306 Stock Short block N/A and Spray 1/4 Times inside.
- Solid motor mounts anyone?
- Idleing at a very hot temperature
- Replacement for oil pump drive gear retainer plate?
- Which engine rebuild kit to get?
- Emission testing
- What is the cheapest way to reprogram your speedo???
- Hmmmmm?
- Magnaflow vs loudmouth
- Torque Converter Stall????????????????
- Ok, I'm confused now (torque converter)
- Header Question
- does not start
- clutch and pressure plate combos
- Anyone ever replaced ignition lock?
- Quick Help!!! How to turn the Flywheel when the engines Seized(T/C Removal)
- replacing clutch
- Gear change
- oil leak on intake
- 93 LT1 had a bad miss, help!!!
- Big valves in LT1 heads?
- Where to get replacement bulbs for AutoMeter Gauges??
- LT1 alternator questions...
- Stange hissing noise coming from the back of car
- Starter Slowly Dying?
- 93 lt1 optispark from Autozone, does this look right?
- Quicktime Electric Cutout
- lt4 intake or port??
- engine vacuum, and etc.
- Suspension
- getting rid of emissions crap
- 17'x11' Zr1 rims
- Transmission
- heads
- I can't believe my 02 sensor is bad??
- what muffler should i go with
- how long do i leave seafoam in oil???
- vaccuum leak Q/A
- Hot Cam guys...What stall converter????
- B&M Trick shift fluid good or bad????
- LS1 brake INSTALL Q's
- header "tick - tick" leak
