  1. How to install opti???
  2. Trans-go install problem, please help.
  3. 95' Y pipe in a 97?
  4. LS1 air intake on LT1?
  5. Wire routing
  6. Zr28
  7. In car wideband, any of them good?
  8. Getting clutch info straight...
  9. T-56 Swap
  10. OBD code 26
  11. Ignition swap
  12. Exhaust and Headers help...ASAP
  13. combination motorsports springs...
  14. I think I may have figured out my extreme tranny noise, please help
  15. To all on here : Thank You (MY car is now a beasat thanks ALL your help)
  16. airplane spoiler
  17. pinging problem between 1k-2krpm under load
  18. Book time for this?
  19. 2800 stall and 3.73s on stock LT1...
  20. Clutch Compatibility
  21. SFC's...Kenny Brown or SLP???
  22. How's the SPEC 6 puck stage 3 holdup?
  23. removing stock exhaust manifolds
  24. is my engine running too cold after 160stat?
  25. recommended rear fluid?
  26. Exhaust component discussion..
  27. how would i do this??
  28. Couple T56 questions...
  29. copper intake gaskets
  30. URGENT!!! Pistons and Lift
  31. hot cam dowel
  32. ls1 motorsports can suck it
  33. Crate or Rebuild????
  34. Am I getting Raped?
  35. PLEASE HELP car keeps turning off
  36. Diff between ASP and March pullies ?
  37. Stock '95 Z28, what should they run in the 1/4?
  38. Shoebox I need your help with vats again
  39. What year lt1 should I look for?
  40. Delco tape deck losing pitch?
  41. Quaker state high performance oil any good?
  42. Backlighting aftermarket gauges...
  43. 3.42
  44. Which set up flows better ...
  45. torque specs on valve covers bolts
  46. Street or Drag Radials?
  47. HELP ME! its gonna rain soon... (pictures inside)
  48. Hey guys, I just bought an LT1...
  49. T56 Clutch Disc
  50. How much vaccum should i have after cc305 install?
  51. Best clutch -nonSpec
  52. Serious Engine Problem
  53. Are there any visible signs of a bad opti??
  54. anyone have problems with A/C??????
  55. Having A Hard Time Starting
  56. 95 Z, 2 series or 3 series???
  57. another EGR question
  58. guys with duals, what mufflers are you using
  59. gm t56......
  60. Poltergeist Car
  61. Cheapest place for a Throwout Bearing?
  62. Jet Hot LTs and O2 Extensions???
  63. 230/242 problems???
  64. misfires and some knock
  65. OPTISPARK??? Whats the symtoms
  66. How do you port a TB?
  67. fan mod
  68. LT's effect lowered cars???
  69. best deal for parts...o2 sensor, etc.
  70. How do I
  71. over filled trans, what do i do?
  72. What is the best cam for a daily driver??
  73. Where to place O2 sensors?
  74. street twin FW balanced??
  75. Where can i get scanning software?
  76. Overheating problem
  77. more lt4 conversion questions
  78. Is 3500 too much stall
  79. Hotcam VS CC304
  80. what's needed for clutch job
  81. burnt valves
  82. Buying a '95 Trans Am
  83. Do Street Twins wear out?
  84. Need ideas for cousin's LT1
  85. stud girdle
  86. ? about hood pins
  87. Switched from 2.73 to 3.73 A4! Question
  88. i need a part number...shoebox?
  89. I just opened the gates to hell
  90. Rear Main Seal
  91. what should i get my boyfriend
  92. twin disc need spec
  93. 2.73 vs. 3.23
  94. How to remove front seat belts?
  95. Jet Stage 1
  96. msd 6
  97. best fowing heads
  98. Removing 3-4 shift fork...
  99. Can I tell the difference between lt1 and lt4 heads by look?
  100. which stall is better?
  101. What Motor Is This
  102. Dual/single Cat Headers
  103. car lurches when speedo hits 115...
  104. what valves to run with a supercharger.
  105. How loud should a Comp Pro Magnum valvetrain be?
  106. Anyone Using Hays Clutch?
  107. gears
  108. Opened up the Opti Spark
  109. XE 224/230 guys... where are you shifting at?
  110. Pacesetter Headers
  111. Driveshafts
  112. anyone know how to take the drivers side window out?
  113. 97 Stock SS Specs?
  114. A/C Delete Pulley?
  115. Where to get an LT4 Knock Module?
  116. What type of oil do I use for my A/C????
  117. Teach me some basics of Cam #'s and selection ...
  118. my track times: WTF
  119. Why????/ AC Comp
  120. Sold the 5.0, bought an LT1, Q's!
  121. Rough Idle
  122. What size stall?
  123. What should i do to my car ...
  124. As the world turns...
  125. computer question
  126. Which TC??
  127. What's the absolute best way to flush coolant??? HELP???
  128. just ordered stall but haveing second thoughts.
  129. The shop says it's a bad lifter..... that sound right????
  130. Can exhaust leaks cause a low end hesitation???
  131. RIP, my camaro
  132. Do cammed Lt1's have any engine longevity problems?
  133. Can someone help me decide on an exhaust combo?
  134. Where do I start?
  135. Bad water pump take out the OPTI?
  136. aftermarket lower a arm weight?
  137. need exhaust clips of LT and 3" exhaust
  138. Inflateable Lumbar leaks
  139. Blown head gasket and on a budget.
  140. Who Has Had Problems With 6 Speed?
  141. negative effects of bypassing heater core...
  142. Cam/Stall Question
  143. RPMs with 3.42s on 4l60E and stock height tires
  144. 93' Z-28 Help?!?!?!
  145. Will this work?
  146. cc305 with hotcam springs?
  147. Help ASAP
  148. 12:1 compression....
  149. people with Ball joint failures??
  150. SES related with MAF sensor, please help.
  151. What should I expect?
  152. Need Help With TH350 install
  153. How to host video
  154. Tall Centerbolt Valve Covers for LT1?
  155. o2 sensors, where to buy??
  156. coolant light STAYS ON help any1
  157. MSD Ignition
  158. When do you need to upgrade your fuel sytem??
  159. who can get new 93-97 oem fog lights for $27????
  160. LT parts list... again.
  161. *Update* Hard Starting Problems
  162. What are the best shift kit and headers??
  163. Down shifting
  164. Wheel Bearing's.....WTF??????????
  165. EGR valve, need pic and help, SHOEBOX pic please????
  166. a4 to th350
  167. How much can a 2bolt block handle?
  168. How to get the A4 shifter knob off?
  169. Safe MPH downshifts for each gear?
  170. Headers are going on, what should i know?
  171. Exhaust Comparo
  172. Idle surge
  173. plug wires touching?
  174. WTF!!! Fel-Pro oil pan gasket Is retarded and im pissed off *PICS*
  175. Dependable parts, reasonable prices
  176. How do you change a throttle cable on a 94Z?
  177. Any of you got this problem?
  178. Firebird trouble 2
  179. Can a 3rd gen rear fit a 4th gen?
  180. LT4 hotcam kit installed by dealer?
  181. Is My Timing Off?
  182. high performance o2 sensors
  183. Can I swap lifters with the heads still on?
  184. think my car is running bad, but i beat a sc cobra
  185. "DeCarbon Take-Off Shocks" are these any good? better then stock?
  186. Few questions about pcmforless???
  187. Snapring tool for T56?
  188. clutch for high power lt1
  189. Tired of this coolant smell, especially since I can pinpoint when I'll smell it
  190. Optispark upgrade questions...
  191. Visa 245/50/16 tires (model VK-50G) tires
  192. Exhaust leak??
  193. SES Light, OPTI maybe?
  194. Clutch slipping, all parts that i need include?
  195. dynomax bullet or high flow cat?
  196. hp #'s
  197. Changing Lifters????
  198. Borla Flow Control Plates, Few quick questions...
  199. Rear turnsignal wont work.
  200. Total rebuild......what do you guys think?
  201. Whats this trouble code mean?
  202. New Starter
  203. stainless works y-pipe from sumitt :(
  204. shorten my driveshaft?
  205. If My Spark Plugs Are Bad...
  206. where can I get a good fuel filter?
  207. SS intake + CAI?
  208. Help, my radiator blew!!!
  209. Widening wheels...
  210. Recharging my A/C (Repl Compressor)
  211. Where's the best deal on o2 sensors and extenders?
  212. problem after 230/236 install
  213. FLP Headers...
  214. Deciding on tires
  215. Carsound Cats?
  216. What is this??
  217. oil leaking from low oil sensor?
  218. 93 hotcam/ported heads/pcmforless users, please read.
  219. 350 question
  220. FLP guys where to get replacement clamps?
  221. I need a bigger cam, Suggestions Please
  222. LT4 knock module
  223. Power steering gone??????
  224. ? dyno's & tuning
  225. I love a Loudmouth, but I'm in love with a Hooker
  226. Are Jason Cromer's prices for real!?!?
  227. Crank Pulley
  228. here we go again, cam help please :(
  229. Lug nut thread specs?
  230. what headers are CARB legal in CA
  231. offroad pipe and people without a cat or cats please come in
  232. Is My Waterpump History?
  233. is cc306 big enough for my new motor
  234. How do I drive this thing?
  235. Stainless Y Pipe
  236. Question on rearends
  237. Flywheels
  238. Need Help Fast!!!
  239. Dip in airflow around 5000-5200RPM
  240. Oil Leak I need your opinions
  241. Shocks
  242. vig stall converter
  243. gauge install
  244. flywheel question
  245. rear end cover ??
  246. where did you mount your ignition?
  247. Hey 383 peps gimme some luv
  248. The LT1 motor gremlins got another bolt!
  249. exhaust
  250. Listen to this
