  1. Moser 12 bolt owners PLEASE HELP, check out this pic....
  2. Headers
  3. where to find....
  4. firebird trouble
  5. Slotted rotors
  6. Identify this part!
  7. Part # for headlight and brake light.
  8. How to remove the IAC?
  9. Cleaning under the hood
  10. Hypertech power pulley coming off,is it the only one?
  11. last minute header question
  12. no compression
  13. No sealant on head bolts among other things...
  14. Autozone Opti?
  15. OIL PRESSURE SENDING UNIT--94Z-which one?
  16. Do flywheel bolts use washers? Quickly :)
  17. I need some help guys.
  18. need help with shifter
  19. How to store an A/C Compressor?
  20. im about to put some $ into my car whats best time improver i should go with?
  21. Rear Brakes Question
  22. what is my car worth
  23. How much does it cost to get a rear end narrowed?
  24. Any Suggestions to Fix High Rpm Miss??
  25. Question on changing heads, power gained?
  26. SLP takeoff shocks - questions within...
  27. Parking brake not releasing
  28. Header gasket fix?
  29. New LM and the law...
  30. Help just got Dyno results, not good!
  31. Might be saying good bye to LT1 for LS1 or 6 if I hold out a little longer.
  32. Car turns over but doesn't start...
  33. O2's good or bad???
  34. changed head gasket.. now I have low oil pressure, groaning, stalling, etc.. wth?
  35. which Honda ATF do I need for M6 dealer says type for auto or for manual trans
  36. hypertech?
  37. Ahh going crazy, what could this ticking noise be??
  38. LPE cam...How good is it?
  39. R&R Battery - now chime sounds & car won't start
  40. Distance between ground and quarter panel
  41. Cheapest price on opti
  42. Its Sunday - Power window switch dies.
  43. did tb bypass and homeade cai
  44. need power window motor help - stumped
  45. Need help fast! TH700R4 related
  46. mod performance links
  47. Reverse gear continued....
  48. Any problem with bigger injectors...
  49. windows rolling!
  50. Lunati, Cloyes, or Edelbrock?
  51. Over-heating now, no fluid or noise...
  52. BIG problem filing rings!
  53. Question about timing chain!
  54. Traction Control on 97 ws6
  55. Fuel pressure = zero psi?
  56. pilot bushing???
  57. Just got some money! What do I do? haha
  58. loudmouth or flowmaster
  59. leaking trans HELP
  60. What kind of numbers are people getting with this combo
  61. Trans Question
  62. So Cal Wideband Dyno?
  63. MAFT...yes or no??
  64. anyone seen a yellow ta better than this?
  65. '95 fuel lines diagram.
  66. My car feels a bit sluggish... will gears do it?
  67. Help! Can't Pull LT4 Timing Set! No Slack!
  68. what rearend gear?
  69. stuffing a 96 LT-1 in a 89 camaro
  70. lock-up or non lock-up converter??
  71. New plugs, wires, opti, coil, ICM and still a hesitation when cold at low rpms??
  72. 97 and 01 M6 shift boot ?
  73. MSD Retard box WTF!! ADVANCED!!!
  74. A few pics of some new stuff
  75. car missing....
  76. Losing Fuel pressure while sitting parked
  77. wires and abs?
  78. adjusting speedo?
  79. what is the best cam
  80. M6 tranny fliud.......synthetic????
  81. Dyno #s - Where is my bottleneck?
  82. Lt-1 vs. LT-4
  83. I need a part # for.......
  84. whats up with my SLP dual-cat shorties?
  85. Tuning a 93 LT1
  86. How important is an AFPR???
  87. Turbo Kits
  88. Scorpion rocker arms, ever heard of them?
  89. Retained accessory power problems? shoebox?
  90. will this get me 20 rwhp??
  91. possible misfire
  92. SLP 2OTL catback and "cone of silence"
  93. Anyone running Total Engine Airflow heads?
  94. Timing chain for cam install?
  95. Plugs and wires, whats best?
  96. Msd digi 6 went dead???
  97. so longtubes are a pain???
  98. Breaking up is hard to do
  99. LT1 Swap
  100. anyone want longtubes?
  101. Stock bottom end @ 6500RPM?
  102. Lowering Questions - Please help
  103. 4l60e question
  104. need some pricing help here
  105. SS Ram Air vs. Aftmkt CAI
  106. opti from autozone $165,... not a good idea???
  107. Auto drivetrain loss not as bad as people say
  108. Humming noise from rear of 6 spd
  109. Is this a decent cam, Compucam 210/224?
  110. What exactly is the purpose of traction control button?
  111. 3000 vig. should I get a custome tune?
  112. has anyone gained power going form FLP Ypipe to true duals?
  113. Capabilities of stock block with forged internals
  114. This is my 3rd post on this subject (really need help!)
  115. Would a LT install be easier with the tranny out?
  116. Cheapest place to get Mac headers for a 93 LT1?
  117. bad idle, tried to fix, now need help
  118. Taylor OVC and SLP shorties
  119. guys with cams on stock bottom end....in here
  120. Code 61 A/C Performance ????
  121. Installed Gale Banks cat-back....i love it!
  122. what mods should I get?
  123. BIG idling problem...
  124. The Ultimate Question......
  125. What combo are people runnin to get 12.0s
  126. shift light ???
  127. big problem need help!
  128. Track problems, please help?
  129. Did I lose power with my off road pipe ?
  130. 1994 Tru 1996
  131. Who has done true duals with cats ?
  132. Welding the car
  133. Strange vibration
  134. Cam Swap
  135. Wierd horn issues
  136. 4L60E Question?
  137. tb bypass on a 93 z
  138. 93Z Speedo/ High RPM Problem
  139. Monroe Sensa trac
  140. goodyear f1 gs-d3 tires, any comments?
  141. Adverse effects of removing tunnel brace?
  142. gears on a 93
  143. Catalytic converter code 0420
  144. new gears?
  145. Rocker Part Number
  146. asr
  147. running too rich?
  148. Speedometer acting funny?
  149. will a high stall torque converter help me besides just from a stop??
  150. Video clips after the headers
  151. Just Curious, which rear gears does my car have?
  152. My car got flooded out.
  153. What are some good settings to play with in TUNERCAT ?
  154. Mods to beat almost stock LS1's
  155. Quick Brake install ?
  156. Good Deal?
  157. Can bad opti cause really bad low end hesitation?
  158. Th400 Help!
  159. goofy problem with fans drawing too much juice...
  160. How hard is installing new injectors?
  161. Lowering question
  162. Lower Gears = Higher Top Speed?!?!
  163. Wheel hop bad
  164. 230/236 cam gas mileage info
  165. People with SLP headers and stock y-pipe inside please
  166. Hybrid fuel system
  167. Zero Gas Milage
  168. E-brake cable hitting DS yoke in rear. Anyone have this before?
  169. Where should my friend be shifting at? (Dyno sheet)
  170. Spec Stage II + N2O + ET Streets - will it hold?
  171. Why so many spinning bearings with new cams?
  172. No Cats
  173. New here, need some help!
  174. A/C Delete/ Heater Only Question!
  175. Does J. Cromier (sp) still offer parts? I need a valvetrain kit
  176. header install
  177. How Do I Do a Compression Check?
  178. Does anybody know a good shop in southern IL?
  179. Oil pressure fluctuation at WOT! help
  180. Need new clutch, what should i get?
  181. Can you drop a stock LS1 into a 1993?
  182. Why did my cam gear eat itself?
  183. how many people own 93 z28
  184. How come nobody sells stock LT1 crate engines?
  185. Horsepower estimate
  186. is there a gasket for the TAIL LIGHTS??? Shoebox???
  187. Schrader valve on A/C leaking...possible to tighten?
  188. Infamous Surge/sputter
  189. Quick Easy Question
  190. starts and then dies
  191. How much of a difference can an opti make b/c the shop says....
  192. Where To Buy CSI Water Pump
  193. I dont understand this light....Water pump install Schematic question
  194. What do you think i should do? (f'd up rebuild)
  195. o2 problem?
  196. Those of you who have gone from mildly blown to n/a
  197. street twin in, observations/concerns..
  198. supercharged
  199. Harder install clutch or headers
  200. Strange 12-bolt
  201. need help please
  202. Offroad Y Pipe
  203. Harmonic Balancer removal...HELP!!
  204. mobile 1 vs. redline
  205. Surge/Stumble Part 2
  206. I need help pease I am on my last leg!!
  207. Headers for a 97 formula???
  208. Have clutch question
  209. How fast does Jason Cromer reply
  210. Physical difference between SA and NSA rocker arms
  211. annoying whistle??
  212. Is it possible for a clogged fuel filter to make you run lean?
  213. Everyone take a look I need it (esp. pros)
  214. How much RWHP?
  215. Different type of O2 sensor needed w/ my setup??
  216. water on air filter
  217. ball and socket exhaust
  218. LT1 Edit worth it?
  219. Difference between long and short block
  220. How to bypass Neutral Safter Switch?
  221. springs
  222. need torque specs for header flange to y-pipe
  223. MPH @ 5800 rpm with 3.73s?
  224. Brake fitting sizes..............?
  225. best place online to buy shocks for my new eibach set-up?
  226. 400+ CI LS1s are everywhere why are there no big inch LT1s
  227. electrical problem?
  228. clunk
  229. dependability of STRANGE 12 bolt and mcleod clutch?
  230. M6
  231. low oil indicator sending unit, can it be deleted
  232. Suspension to make my car hook up?
  233. e-brake handle flies up
  234. What different on a 94 as opposed to other lt1s?
  235. 94 Z Blowing 15amp courtesy fuse
  236. eibach vs. slp springs
  237. Mobil One made my car leak oil...
  238. Does GM have a 1 year warranty on ALL parts including the performance parts?
  239. How long is your hooker catback lasting?
  240. Help with car. Help me figure out my problem.
  241. Ever read this?
  242. F body experts needed on questions?
  243. cam change question..
  244. Weird cruise control problem
  245. Volts from Alt? Original from my '94..
  246. M6 Rebuild questions for those who Upgraded
  247. Nitrous-Hall A$$ or Horror Story!!!
  248. Lighting Problem ...
  249. Do NO stores carry the pulley I need or what??
  250. Power (underdrive) Pulley question.
