  1. Egr
  2. New member
  3. Want to tune my PCM, have the cable from AKM but want a good program
  4. How long did your stock shocks and struts last?
  5. Lowering Oil Pan to replace gasket
  6. What does a Z28 weigh?
  7. DEXCOOL - u still using it?
  8. Bleeding McLeod Master
  9. Part# for a Moser 12 bolt pinion seal.
  10. First mod! woot!
  11. Aluminum Driveshaft - any gains?
  12. where to buy block off plates
  13. Need some help!!! Lookin for a G2 cold air piece...
  14. Clutch Problems HELP!!!!!!
  15. Reinstalling clutch fork
  16. Using a bullet as an ORP
  17. which swap would be better, ls1/GN?
  18. wierd trans problem
  19. ram air induction hood
  20. Anyone have experience with these companies?
  21. Another Dead End
  22. SLP Take-out Posi Install?
  23. how to tell if intake leak fix worked???
  24. paint codes?
  25. Mod Bug Bites Again
  26. Product Opinions Welcomed
  27. Car took a crap!!!
  28. Cleaning the IAC
  29. Shorty Headers...what kind of gains?
  30. I just got my car back with new mods........does this sound right or something wrong?
  31. optima batteries
  32. opinions on this set up??
  33. stereo locked
  34. New Track times. better but dissapointing
  35. Which oil?
  36. About to go to track, what should i run??
  37. Opti question
  38. Touch up paint
  39. Ticking lifter???????
  40. best radiator hoses?
  41. reasons for high idle?
  42. Oil leaks *PICS*
  43. valves why no 2.02 int 1.60 ext???????????
  44. Lean condition after header install, is it bad?
  45. LT1 powder coated Intake, ported for 58mm TB needed...WHERE...
  46. Question About Headers
  47. What do you think about bullet mufflers??
  48. Water pumps?
  49. took my car to the dealer! wow what a estimate!
  50. possible to hook up the abs on a TC rear on a non TC car.
  51. quick question about sercurity feature..
  52. Clean that MAF
  53. how often can you do seafoam???
  54. Hey Fred, you need to update your website
  55. S&W Racing SFCs
  56. Great Tool to learn about Cause and effect of cams
  57. valve cover leaks
  58. What year silverado pan and where do I find them?
  59. squek squek squek
  60. oil pressure problem?!?!
  61. AC prob, sometimes it doesn't go on, then restart car it works.....
  62. OBDII code lookup
  63. normal oil pressure
  64. Trans problem is p!ssing me off!
  65. Major Fuel Injector Problem ... need help ?
  66. is having different offset wheels up front really bad?
  67. Street Twin adjustable master cylinder
  68. Replacing the reverse gear syncromesh
  69. supercharger question
  70. 18x8.5 wheels a good thing??
  71. qucik fan mod question
  72. headers gasket for brodix track 1 teh same for lt1?
  73. What wpuld be the best cam for me...
  74. parking break help
  75. LT1 Roller Rockers?
  76. Info/help/tips on diy head porting
  77. thermostats?
  78. Damn car.
  79. What is the widest tire to fit on a 9.5" rim?
  80. Tranny Cooler Location
  81. If I upgrade to a Torsen, do I need a new cover??
  82. Is this lean because of tuning or the open headers?
  83. limited slip
  84. solid roller info please:)
  85. How to use seafoam?
  86. Quitest F-body exhaust and still make power?
  87. 52mm -VS- 58mm
  88. Breaking in sollid roller
  89. one bank normal, other bank rich
  90. Hard starting problem?
  91. Speedometer not working
  92. Hesistation off line
  93. Popping out of reverse
  94. Went to the track with new mods
  95. Please quick: need help with wiring
  96. new cat
  97. Bose stereo speakers?
  98. Low Tracktion warning?
  99. hydrolocking??
  100. 96 LT1 will not start on hot days.
  101. Where can I get heads/intake ported and polished in PA?
  102. Th350 Or Th400
  103. Correct torque for hub/bearing bolts?
  104. Valve Spring Question
  105. Rear-end noise; sounds like bad tire but isn't
  106. non-vented to vented opti
  107. plugs?
  108. What size injectors?
  109. Battery problems! Need help
  110. Takes 2 hands to get into Reverse on 6spd help
  111. tell me what I need
  112. Is there a straight thru muffler w/ 4" inlet and dual outlets?
  113. yes or no: hotchkiss strut tower brace?
  114. T56 Pilot Bearing
  115. Problem wasn't Opti, Now What?
  116. Can this mess up my PCM?
  117. insurance question
  118. Need help lots of power loss
  119. Remove cai for line lock?
  120. Anyone have the new Hooker y pipe?
  121. Rear main seal
  122. stock y pipe do you have one, i want it
  123. TB differences?
  124. Rack and Pinion Serious problem
  125. scyzoryk Needs to respond!!!!
  126. Normal RPM at idal
  127. vibration still
  128. moving battery to rear, what do you do with accessory wires?
  129. Stage 8 header bolts
  130. Turn signal
  131. LT1 Oil Problem
  132. Anyone ever modify the Ypipe where it connects to th eheader?
  133. Need some help again lt1 guys
  134. Car loaded down, vibrations were worse
  135. Ditchin the Magnaflow for Loudmouth
  136. Got $700 to spend go with converter or LT's???
  137. SS w/ ile driveshaft
  138. LT1 to LT4 conversion kit
  139. POP when braking moderately
  140. Please help to get my new motor w/cc305 etc to run right.
  141. LT1 Scanmaster Install
  142. Will ET Streets blow my rear?
  143. cleaning rims
  144. weight of custom wheels
  145. Hotwiring the fuel pump
  146. Request General Cam Info
  147. A4 cars with big cams???
  148. Backfiring
  149. Need help on choosing bottom end(383).
  150. car won't start
  151. Wiring Up Air/Fuel ratio gauge
  152. Can I get one(1) lifter out without yanking the intake???
  153. new seats
  154. Should I put my old o2's in to seafoam my engine???
  155. About to replace my starter and solenoid...anything to look out for?
  156. New ICM, still not starting!
  157. Street Rod Nationals in Louisville, Ky... loads of cars with LT-1's and many vendors!
  158. Coolent in oil
  159. 49K motor, heads and cam, burning oil only above 4K... is it the rocker arms?
  160. Ltcc Lt1 To Ls1 Ignition Coil Conversion Lt4
  161. Odd Tapping Felt Through My Clutch Pedal
  162. I have a rough idle and...
  163. Used seafoam to clean out engine before changing oil and it GELLED??!?
  164. Clutch went out today need some help
  165. Ground on intake manifold ? Shoebox ???
  166. battery amp output?
  167. LT4 Hot cam with LT4 valve springs...
  168. what else is needed for a cc305??
  169. LT1 Headers
  170. help me figure out my problem
  171. t-tops
  172. how to convert to ram air box? help
  173. Looks like I will need a opti I feel......
  174. Last bolt on Headers
  175. 04' Grand Prix trip-tronic for F-bodies?
  176. i need some help
  177. help cant launch
  178. take off intake manifold gaskets
  179. MSD Digital 6 Wiring question HELP!!
  180. Harwood Hoods
  181. xe 224/230 is in
  182. Cracked rod... new radiator needed?
  183. ..crank balancer question
  184. Power gains from stepping up to the cc305 from cc304
  185. Recharge the air conditioner system?
  186. weird noise?! please help
  187. Evil Red Fluid
  188. Car Dieing Problem. Random....
  189. O2 Sensor Question....
  190. I want to run 13's What will it take? not to much blow...
  191. What the heck is this???
  192. posible misfire????
  193. Any stand alone shift lights?
  194. M6's w/4:10's...
  195. Standstill...How bad for brakes?
  196. Running W/ No muffler..will it gain HP??
  197. new pilot bushing looks different than old one, is this normal?
  198. Spark plug change.....try this
  199. Smog Pass
  200. BMR Trak-Pak
  201. Coolant Light is on for no reason!
  202. which heads are the best?
  203. stumble solved?
  204. Went to track, couldnt be more pissed off
  205. Need cam (new to camaro's)
  206. big stall ~ little gears
  207. what kind of headers?
  208. which radiator hose is this....?
  209. WS6 "smooth bellows" scam on eBay
  210. Quick A/F Question
  211. just bought exhaust system
  212. Changing O2 Sensors
  213. Autozone Wires?
  214. Degreeing the Cam
  215. Hooker LT's or Jet Hot LT's???
  216. LT4 Cam swap
  217. Thanks for the help guys!!
  218. idle in drive is horrible!!! The IAC steps count shoot up to 140's
  219. what are the best swap in gears?
  220. o2 sims '95
  221. Got a new ignition box, and I think I've found the best bang for the buck box
  222. Not turning over
  223. emmision and o2 question
  224. Using tq to yeild head bolts have a ?'s
  225. What Y-pipe and gaskets to use with Jet Hot LT's???
  226. check guages light has issues!!
  227. durability: LT1 vs LS1
  228. installing a shift light in a '93
  229. how much would an average LT1 go for?
  230. Please..Help me decide...100shot or CC306??? *POLL*
  231. noticable diff between modded exhaust & cutout?
  232. Rethinking cam selection..........any advice?
  233. Please help with BAD low end hesitation w. new engine
  234. Is it possible to find out the stahl of a converter before it's installed?
  235. Page For Shoebox
  236. How much for this TA
  237. What brand tires are you guys running?
  238. Well I think I found the problem inside my tranny *pics*
  239. LT1 Guru's inside ... Need Help ASAP
  240. LT1 rebuild options since motor will be out...
  241. 550 hp on 383
  242. Voltage drop
  243. 3200-3400 stahl too much for LT1???
  244. Who turned out the lights??????????
  245. those w/ jet hot lts what y-pipe did you use?
  246. Stock LT1
  247. TB bypass? Good or bad?
  248. Lt4 conv., Speed Inc. dyno #'s
  249. Knock retard...Real or not how to tell.
  250. Damn Brakes...ANyone else stumped on a Low to almost NO pedal?
