- HELP! Jet Hot install problems...
- A/C not coming on, LP switch or PCM?
- Winter project? Need ideas!
- Changed chip, now exhaust leak???
- ASR and Alarm
- Why is my off road pipe too short...!!??
- CC305 question
- What kind of rotating assem for 1000hp
- Swapping to OBD-ll because of stall , what is needed??
- Replacement Clutch
- car idiles at 400 wtf?
- top end stumble
- wire arcing to header
- !! overheating !!
- How common is intake oil leak?
- Exciter wire from alternator HELP PLEASE
- clutch pedal problems
- Another oil leak question...
- LT1 scanmaster
- Jet Hot / Hooker Long Tubes owners.
- Exhaust clips
- Header Suggestions Please
- jet hot lt headers
- race gas?
- MAC dual CAT
- How does the PCM sense the AIR?
- Back from track
- Posi breakaway torque?
- to go w/ TransGo or something else...or nothin at all
- How to hollow out the cat?
- how to check cracks on the heads??
- $10 to whoever figures this out.......T56 probs
- So I switched to synthetic oil and...
- Pilot Bushing Part #
- looking for a suspension package. where?
- Anyone else's oil drain plug leak?
- Troubleshooting the Great Low RPM stumble
- Cracking
- Forced Induction
- noisy power steering pump anyone tried Seafoam TransTune?
- Is this ok on a new clutch?
- Changing rear gear... Please Answer These Q's
- Door Window Trim
- Kennedy's Dynotune - Buffalo, NY
- Trans temp gauge...Pressure port??
- True duals with Flowmaster race mufflers?
- Few ??? about LT1's??
- Jumping on the dyno. Any last minute tips?
- Hypertech Thermostat
- Is there any way to remove the traction control box, but retain ABS?
- Best short throw shifter?
- LTCC user, a question on spark wires.
- engine seals
- On the fuel rails, which connector is for the feed line and which is the return line
- Trans cooler question
- Stock MAF
- CLUTCH INSTALL PRICE... this good?
- K&N VS Cool Blue
- oil light sensor
- Do all LT1's have the same smog pump?
- Need emissions/programming help BADLY
- Manual Fan Switch problem.
- Do you have weatherstripping all the way around your rear glass?
- PLEASE HELP, problem with g-friends car
- PowerMax 2050
- Clutch Fluid Reservoir Question
- Lt 4
- $400 bucks, what to do?
- Opti Woes Theory
- Would I benifit from computer tuning?
- ? Re. Torque Arm Bushing
- brake bleeding question
- question about posi-traction
- exhaust rattle
- tell me what this is??
- Qeust on water pump and thermostat
- intake elbow
- Does it hurt to run w/ just manifolds?
- Accel 300+ & Timing Retard Problem
- Front turn signal/marker acting funny?
- Question about coolant crossover tube
- Need Help with high rpm Miss
- Could I do a Cam and parts for the same price as a $600 n20 kit??
- Questions about 3-4 upshift module?
- Unbelievable! LT1 owners inside.
- ABS light... help
- Side door panel guard things!!
- rear view mirror
- Cutting hole in Ram Air hood?
- Exhaust Gas Temps - This is What I Did
- Name that driveline noise
- speedo correction?!?
- Help with disc brake install
- cc306 and 3.42's???
- Where to get C4 valve covers for our LT1's??
- Hooker LT question
- steam pocket in the block
- headlight hostility
- McCord Cutout
- oil change
- How good are you? Tell me what this sound is coming from...
- Has anyone removed the solenoids from pass side of intake?
- How to fix certain things on my car
- charger all done!
- Waterpump rigging...
- Next mod?
- Torque Converter
- Best tires for stock tire size?
- How to measure pinion angle?
- adjusting valves
- intake gasket or rear main?
- Starter Failure?
- How to make sure your rear isn't bent (without driving it)
- A/C Compressor (I've Searched)
- Too big for CA smog?
- Who's running a custom cam in their 350?
- Woo hoo! I think I found my Problem!
- Rear end not centered?
- can this happen?
- XE 230/236 and LT4 Heads
- offroad y-pipe for 96-97?
- Aftermarket Valve Seal question...
- New Here
- Wiring Schematic Needed
- Default KR settings?....Injuneer?
- Real LT1 SS owners inside
- 97 Y-Pipe Removal
- Why TB bypass and EGR block off?
- LT1 ported heads, with LT4 hotcam kit and summit forged kit --> 400HP N/A??
- Best bang for buck CAI ???
- MagnaCore wires? Where?
- Best plug wires and easiest way to change?
- How much will be ET improve going from 2.73s to 3.42s?
- For those who bypassed stock trans cooler
- No start, no spark.... im buying module today.
- Question about the LT4 conversion kit.
- Going to the track
- Trans wont shift into 3 or 4, sometimes it does. HELP
- Quick question about changing coolent?
- lug pattern on 95 z28?
- is the code stored if ses came on then went off?
- Hesitation patch.. EGR easy to clean?
- are 1993 computers similar to previous computers?
- EGR and AIR
- Wet or Dry?
- High idle
- auto to manual swap
- 3.73's or TC?
- How long do you go before you wash your K&N filter?
- LS1 Brakes
- Bolt size on tranny inspection shield? Rob?
- Is it OK to use sandpaper on a flywheel?
- dead spot on starter
- Best header bolts
- How much for custom Y-Pipe?
- what could cause low idile???
- Big cam guys with stock lifters?
- Quick one, weight of tire, tire & rim, stock 16" salad shooter
- question about getting the air and egr programmed out??
- O2 Voltage
- will LS1 eibachs work on a LT1???
- Quick Coil Replacement Q
- Comparable plug to the TR55?
- Fastest N/A LT1 in a 4th gen?
- Rear Brakes
- How does the PCM determine WOT?
- ??? for FLP Owners
- More than a few questions inside..
- Help
- The Bunny is about to die!
- Cam gear runout and wobble?
- Valve cover questions...
- Cam question
- Which stall to get?
- Does anyone else have problems with thier...........
- what should i expect from 3.73's
- Hooker sortie header owners inside
- URGENT is it okay to put the DEX cool in my car??
- WHAT REAR GEAR DOES MY CAR HAVE
- Spark plug gapping???
- is it necessary ......
- Got Vigilante, Stall question
- Quick! My bellhousing wont detach from my block (T56)
- Bump stops?
- Leaking SLP shorties
- hooker long tubes??
- Those with DMS springs inside please
- Applying Die-electric compond to S-Plug Boots.
- crackling noise coming from left side of the engine
- Hate the Opti..anyone else hate it too?
- Paging Shoebox... Part number needed
- stupid a4 ?'s
- possible cause for low idle?
- Tick on one side of block, only at idle...any suggestions?
- Help With My Brakes
- does anybody have tru duals?
- no suction
- thinking about going with 30lb. injectors
- Eibach Alignment Question
- LT4 Knock Module
- Flames shooting out the exhaust...
- First time ever at track.
- Best way to keep valves from dropping during cam install??
- what et and mph should i see?
- Connecting to the switched power block
- Ahh! I hate my tips!
- Anyone have dynomax bullet muffler?
- Coolant had a little bit of a rust tint to it what does it mean?
- heat shield/tape
- what is this? (pic)
- ZO6 MAF conversion
- Are there any simple ways to adjust the steering wheel?
- New complete OPTIS at NAPA $160 !!!!
- Strange noise at 5400 rpm
- what scanning equipment do you use?
- i am looking for a rpo and vin decoder
- LT4 Hot Cam
- I think this is why my ABS light was kicking on
- shoebox, ABS on rearend?
- Changing wires - Passenger Side
- busted radiator veterans/here!!!!!!!!
- Pro 5.0 question!!!!!
- Skinnies question
- Just wondering?...........(exhaust question)
- Cutting off exhaust after cat.
- Both bump stops broken,. ?
- suspension upgrade
- reccomend a cam!!
- New Numbers.. Idea's?
- how much clearance do you lose with cutouts?
- Clutch/stuff while your down there parts list?
- Factory Freak?
- FLP HP Gains w/ cats on
- hotcam guys with high mileage and stock ( oringinal) bearings
- Lt5 Crate?!
- Two batteries in 1 year....bad alternator?
- anybody try this?
- broke power door lock switch
- How much could fouled spark plugs hurt you?
- Front-End Alignment Question
- Gear and stall suggestions needed
- last header bolt
- Timing cover seems to be leaking
- Question on exhaust insert cones...
- Car won't start!! Please help!!!!!!!!!!
- What will i run
- Any advise or experience welcome (modded LT1)
- Replacing Fuel Filter
- Purpose of Bucket in tank
- E-Brake/parking brake doesnt work ... new pads and cables installed
