- opti
- project kelley
- How many quarts of oil?
- Just scored a LT-1 4bolt block
- Tranny cooler hoses question
- What are the tell tale signs of a failing opti???
- Ok dumb question here.
- 1/4 mile trap speeds with a full bolt on LT1 w/100shot or more (n20)??
- lumbar support
- Got some problems with the car...look inside..weird stumble.
- 58mm Throttle body Question
- Tranny Mount Options?
- 94 LT1 and 700R4.. which flexplate?
- Spark Retard Observations from Testing
- OTVC wires and looms HELP
- drag radial???????
- Stumbling
- Pcmforless?????
- OBD2 - issues after longtube install
- lt1 to carburator
- Canton Oil pan clearence problems?
- Doing Headers, What Stuff Do I need?
- where the hell do I get bolts for these valve covers??
- 306cc, ported head without headers
- 93 Z28 Should I buy this car?
- Bolt Size???
- Want to replace some gaskets now that the trans is out
- balancer bolt
- Royal Purple?
- What I FORGOT to do while doin IM LEAK
- SES Light
- changing the alternator
- New dyno numbers!
- i need traction my 1/8th is terrible
- Need pics of modified valve covers PLEASE!!
- Dumb TB bypass Question
- Stock A4 Trans-how Much Power?
- Exhaust questions???
- AC & underdrive pully?
- ICM pics and location price etc
- Need Help! 12 bolt for stroker??? Look Inside!
- quick easy question for all you pros
- yet another head removal ?
- just finished draining the oil on a change, and realized I got the wrong oil..
- busted radiator leaking????
- Jounce bumper part #
- Time for another Motor
- What sensor/module is in the rear hatch?
- LTCC Problems =(
- Any problems with BMR tubular...
- Need help Quick! What type sealant on waterpump retaining bolts?!
- car wont start after tb install
- T65 clutch questions
- Now what should I do to lower AC line? HELP!
- Opti Keeps EXPLODING =/
- Timing retard at 6200 RPM's?
- Is it possible for a bad MAF make you lean out?
- anyone know where i can order TB gaskets?
- Dynamic Compression Ratio
- 4L60 in a 94 Z-28
- Using pepper to stop coolant leaks???
- A4 and Speed Range
- Shifting
- Help .... what do I do now?
- 98+Camaro Tailight conversion
- SLP exhaust gains
- A S & M header gaskets
- What is causing clunky front suspention?
- Opti Q
- Part number web site
- wiring LED for performance shift mod
- PNs needed
- Cam Dowel pin? On a vented opti
- want to go under 12.5 1/4 mi
- Where to get Honda ATF?
- abs light?
- Is it OK to buy a used...
- Auto Zone power steering pump...good or bad?
- How much oil should I use...
- Corsa Catback?
- need nitrous works lt1 setup instructions!
- delco/bose headunits, all the same?
- Issues with Mcleod Street Twin
- 30# fuel injectors
- what to buy
- Which valve is which
- holy code! help me please!!
- HELP Where does the factory tach get its power/reading from?
- Rotors, turn or no turn?
- SLP CLUTCH INSTALL... Questions...
- can cross drilled rotors be turned?
- i need a part #
- rear shocks....
- Really odd problem...
- SS Spoiler and ABS INOP light
- I want to lower my car for free.. whos done it?
- horsepower gain?????
- 4.8 of Knock Retard?
- Question on new plug wires......?
- 85 MM SLP MAF for a LS1, work on a LT1?
- if i get slp PP and mcloud disc???
- How to pull the LT1 with the wiring harness!
- need some help with translation... easy!
- Brake pad part #?
- LT1 Slave Cyl
- Oil leaking from under car. How much oil can an intake leak produce??
- optispark install afterthoughts
- New stock driveshaft is shorter than the old one? WTF gives?
- How do I connect this remote starter
- Is it possible to use LS1 air lid intake systems on an lt1?
- is this bad?
- Help me fix my miss, it's my only car!
- Help! Keep the cc304 or install a cc305
- Throttle Body Air Foil
- Now let me get this right about the LT 4 Knock Module
- Question about injectors!
- Shifting Question on Automatic LT1
- Need your guys opinion on which head/cam setup to buy
- spark plug wires
- What are the causes of a stumble/hesitation??
- How much HP am I running???
- where can i get a o2 sensor simulator?
- cheapest place to get hot cam kit? plus new times
- Torque arm eliminator
- What kind of gain should I see?
- Is this a sign of a bad lifter?
- long tubes, PITA!!!
- Transmission Problem
- I think my LSD is going south.
- Track this weekend...good and bad news
- What happens when i run the car with out the coolant temp sensor plugged in??
- milling heads/intake questions
- Brakes Questions
- new o2's...code 13...accelerate like ****...after lt install
- Anyone heard of/use jones cylinder heads?
- Is my guage off?
- Warning about mechanics...
- LT's and other parts go on this week!
- code #42
- question for shoebox
- Coolent Temp Sensor
- Part # needed for SVO 36# injectors ASAP.
- M6 guys inside...
- removing crankshaft hub
- Electric cutout to open under WOT
- I was told I had a replica 30th EDITION
- Only "ticks" at load...
- how to valve sizes
- Fuel Pressure Question
- M6
- Re-coating headers
- Slow track times, HELP!
- home dyno
- M6 Shifter install...help?
- electric water pump
- Rev Limiter
- TQ cam
- Charging problems
- Anybody use one of these in their cut-out?
- What all do I need off an LS1 for the brake upgrade?
- Knock sensor install
- Air Lines for Lumbar Supports
- MAF is good, but car only runs when MAF is unplugged
- valve sizing
- Need steps to install trans cooler!
- ses problem
- 380+rwtq is this possible for stock bottom end Lt1
- Brake Gurus inside
- Paint thinner on ceramic coating???
- Vented cap on unvented Opti,Does it work?
- A/C help needed, pressure side gets way too high....
- Get 52mm TB after heads/cam?
- when should the stock thermostat open???
- a differnet kind of cam ?
- msd box
- how hard is it to change the o2 sensors in my car
- Catback recomendations w\ big cam, headers and no cats...
- Steering Wheel
- Street Twin Come with Throwout Bearing?
- stroker question
- stroker
- Rear End Help
- How Do I Know I'm Getting Fuel
- Weld Pro Stars or Pro Stars XP's ???
- Is there no place to get decent heads from?
- Catalytic converter and big cam
- setting my valves???
- Misfire/Won't go after 4k-4.5k rpm in '93 LT1...knock retard? what else can it be?
- check gauge light
- Dumb question about 4th gens and clutches and where they grab...adjusting?
- I think my PCM is messed up can I use my friends pcm on my car?
- LS! MAF on an LT1?
- Walbro making noise
- part # for switch blank. ex:fog light switch
- Howling Noise??
- Nasty oil leak, rear main or dipstick tube possibly?
- Can the differental be rebuit??
- Help choosing next mod...
- timing gears?
- Can someone quickly confirm that...
- Need radiator hose(s) part numbers...
- about the ex 224/230
- Install ? elect water pump
- Can I Remove All Retard & Live???
- Bad feul problem please help
- Useable HP and TQ for the street
- what clutch to get?
- Line Lock question.
- Just dyno'd the car with GTP's & Hot Cam
- Just bought a Z-28 and have a couple questions
- Cruise Control Removal on a '97
- Ignition fuse keeps blowing!
- Car Is Driving Me Crazy
- Need help guys..engine is screwed up..diagnosis?? big problem..
- Freaky "stuff"!!!!! (edited by moderator)
- Temperature Rising
- 383 price
- installed headers and car dies??????????
- Are pushrods down when cylinder is at tdc?
- I need a starting/charging wiring diagram...shoebox?
- random tecnology y-pipe for dual cat cars??
- Maiden voyage after heads and LT install
- WTF is up with this??
- purple wire
- Driveshaft length
- s10 or 3rd gen wheels on 4th gen
- !AIR people, what did you use to plug the hole in the intake?
- Auburn Posi vs. Zexel-Torsen posi
- what the hell???
- Quick question
- ? about deleting charcoal canister
- i need a little more detailed info on the egr and air delete for 96 z
- What to do with my extra money?
- Why the hell is my 95 Z28 Vert an OBD 2 ?
- Crank Pulley Wobbling bad!
- clutches
- set my valves almost every way and still make noise!!!!!
- i need a part # for the tension pulley...
- Car is starving for fuel ... Help ASAP
- Coolant Fan Mod
- sparks and smoke after intake leak fix
- reverse cooled radiator?
- now what?
- Why is my car sound like it's Missing???
- Where can I get a Dash Pad without paying big bucks??
- ? tuner cat
- Why does my car sound like it's MISSING??
- OBD I Palm scan...
- Put the 93Z on scanner, need some info
- What is all needed to go !air
