- opti spark, installed 2 BRAND NEW GM units in 4 days!!! READ!
- PLEASE HELP Car takes long time to start and hesitates at low rpms.
- quick question?
- Best place to purchase SLP Headers
- Time for new tires! Need Suggestions.
- Ported intake question?
- need help quick!!
- Help!!!!!!
- Length of wire for fan switch.
- Difference between X-Pipe, H-Pipe, and Y-Pipe?
- Rear End Clunks After Changing Pinion Seal
- Quick Corsa exhaust question
- help/suggestions for 383 nitrous bottom end.
- Drilling out the IAC passage in the TB?
- What is this connector under the console? shoebox?
- Intake Manifold Gasket that covers everything?
- keyless entry
- a small leak at the head gasket.
- Weird noise
- Where to buy EGR blockoff plate?
- loose hose
- pple w/200amp alt. from beavco(ebay)
- Relocation brackets with 12 bolt?
- 12 bolt and stock ds..pic inside..enough slack?
- Any guides to removing bumper supports..
- Trouble Starting
- what gears do i have....
- header question
- need help in dismantle
- AHH $800 for LT header,y-pipe
- cutout or cat back exhaust system?
- Step on it=hesitation?HELP!
- Another cheer for MadZ28.com!!!!
- Opinion on this setup pls..
- Biggest Cam and Still pass Emissions (ODBII)
- How hard should it be to turn an engine out of the car?
- Question for all with outboard pump & sumped tank-
- Where to buy walbro255 in tank fuel pump?
- 93-96 rear caliper bracket?
- Optispark wiring
- posted hear because you are the smartest of all
- crazy tb idea????????
- lt1 to lt4 or 383?
- Optispark and Spark Plug wiring
- noisy tranny
- Need info on this off road pipe....
- Performance problems
- Some questions you could answer...
- Stock Tailpipe Size
- For anyone whos HVAC fan slows down when accelerating
- steering problem???
- RPM Idle Down Issue
- changed plugs
- Almost there.
- would i get a code?
- Rod Selection
- Fuel pump pressure
- 94Z28 won't flash any codes???
- LCA Relocation Brackets worth it without lowering?
- Shoebox, A TPS question
- Square or Tubular SFC's. Any real Difference?
- besides fasttrackperformance.com, where do i get...?
- A/C vents broken, how do I get inside?
- Does anyone know where the factory tach runs off of?
- What are signs of a bad torque converter?
- Where to buy ring filing tool?
- c5 vette seats
- What is hypoy c gear oil?
- Lost 28+ hp through stock cat-back, not good, what do I need?
- went to get my new clutch installed and it died out on the way there
- Bad hesitation problem
- Driver's window problem
- Titanium Retainers or Steel?
- What are unported stock LT1 heads worth ?
- Desktop Dyno LT1 file
- ses what code??
- Does anyone have '93 A4 wiring diagrams?
- Weird motor behavior.....
- Are stock plugs platinum?
- Torque specs for Eagle rods?
- What the cheapest way to do good true duals???
- Will 17x11's help or hurt me
- RWHP vs Flywheel HP
- HELP me fix my hesitation!!
- overheathing with idle at1700rpm help
- Need some T56 related help
- shoebox
- panhard bar adjustments?
- Rotors/Pads - Whats good?
- how to "pop" start an m6 f-body
- CC503 vs CC305
- Throttle body bypass on a 94
- Centerline Telstars - longer studs?
- Cammed LT1's?
- Anyone have Bilstein shocks with stock springs?
- Level ten trannies?
- Cleaning Combustion Chamber And More
- ses code = shift sensor?
- Vented Opti Conversion Help ASAP!!!!
- ABS problems. bad connection? Interference?
- ..alternator accesory bracket question,..
- Ive tried everything i can think of...
- Paging Shoebox!!!
- Moser 12 bolt and Drivershaft..
- Weld wheel question
- Where to get the Crank Balancer Bolts?
- Pulled intake manifold
- 1LE intake elbow part #
- TDC & Different Head Gasket
- seat belt light
- Weird fluctuations on oil press gauge. Mobile one oil filter the reason?
- Torque Arm install
- Engine running real rough
- lt4 km on 93
- 1:6 rockers
- Please Help!!
- what size cutout for a stock 94 z28????
- Starting Issues
- Cranking, not starting. What else could it be besides opti?
- Borla + heads/cam + 383 + no cats + LTs? Rice?
- Electric Water pumps...
- m6 tranny oil change has filter?
- what all to remove before pulling motor?
- Open headers and o2 sensors
- LT1 seems to be choking a little?
- Problems after cam install
- Okay what are ses codes 100 and 372 mean?
- Roller Rocker?
- any gains w/ cam/ no headers??
- part number
- SES code 372 what is it???
- transmission/car done!!!!
- true duals or cat back?
- cc305
- Tomarrow trans coming out....
- Fuel Problems?
- No Stored SES codes? WTF?
- Shift rpm
- POSI/Limited Slip or Lockers
- AIR fittings
- Why is my car slower this year??
- ran car for first extended time in 4 months....
- Need some 700R4 advice....
- scan tool for 93
- Oil reading still way off.
- A4 2 M6 Swap
- Since I'm doing head gasket I'll go with 1.6 RR, but have valve cover ?
- Lloyd Elliot Heads
- pcm woes
- Ignition or fuel probs
- PCMForless is OK!
- Nitrous Mastermind help
- 60ft ?
- Shoebox or anyone big problem help
- Nitrous vs blower vs turbo?
- changing m6 tranny fluid
- Now that the heads are off....
- look at these smoking reaction and 60ft times
- My buddy's Z needs help on next mod...
- HAL/QA1 users!!!
- How does air foil work?
- Best shocks for Eibach Pro Kit
- CAI and catback or headers
- do i need a cutout?
- I have a question,....@ what compression ratio does a stock LT1 1994 5.7 L V8 run @?
- I'm going to buy gears, what are the strongest ones?
- Has anyone installed an oil temperature gauge?
- Excessive tranny noise still....
- Eaton blower on 4th Gen. Firebird--Step by step
- Rebuilt trans + shift it = no reverse and slushy shifts?
- Stereo question - please help
- 3.42
- why isnt the performance shift mod working for me?
- Track times: CC306 and stock heads
- LT1 headers in a 3rd gen
- a/c compressor
- Factory Alarm Location
- Car Runs Like %&#@ At WOT
- Car still will Not Run
- NEW DYNO #'S (still needs improvement)
- Prothane motor mount install
- how to get ford 9" into 95 camaro?
- A/C repair
- changing wheel size?'s
- ignition switch problems
- How can I tell who made my Cat Back?
- Aftermarket oil cooler with thermo worth it?
- 383 Stroker kit
- Here's a weird one!
- Just used Prestone Radiator stop leak..now overheats/cools back down
- Transgo question
- limitations of a stock fuel pump
- cat convertor problems
- lost power after tune?
- somebody help my car just went into trama
- Can I use guide plates with SA RR?
- How to go 12.50's in LT1 M6 car?
- universal plug wires??
- Opti...
- Wtf happened last night??? help!
- Question for all who have removed your tracion control ( ASR )
- Trick flow elbow
- Middle of Intake Leak fix...
- PISSED OFF!! 5th set of burnt plug wires!!
- too much oil?
- Carb intake for LT1s
- zr1 rims
- New EGR fixed my 'MISS' under heavy load
- Paging everyone who's used McLeod Dual Perf. Clutch!
- speedo aint workin
- What should I expect?
- what will I need?
- Car is pissin me off
- Squeaking sound............?
- Brake pads
- What happens if you warped your heads??
- When pulling your motor...
- Hp loss due to heat
- Looking for shop manual
- sputter, backfire, super rich need advice
- I need BEAVCO alt. # or adress!
- Urgent what does this code mean!!!!!!1
- Rebuilding 4L60E.. need some advice
- need more info on the egr delete for a 96?
- A4
- Loosing weight
- Replacing motor... poly motor mounts?
- Coolant Question
- my brother needs help w/ his truck...
- Intake fix almost done... HELP .....
- excessive brake dust
- anyone know what this is?
- Need help with torque converter
- How many people get that annoying squeak every time they hit a bump?
- Borla/No cats/LTs sound clips? anyone?
- Race Fuel
- Stupid ? ... But where does the Integrated Body Controll Module go ? lol
- lt1 delete pulley
- Budget build up to handle a big shot of N2O
- Clicking in passenger side kick panel?
- What to look for in a Tranny cooler??
- I think i broke a mount
- Crank (hub) bolt broke in two
- welding ceramic coated pipe
- safety equip ? roll bar
- Security light and no start
- Took the car to the track
- valve covers and 1.6 rr's
- horn
