- HELP!!!!!!!Electric Locks problem HELP!!!!!!!
- XE 236/242 dyno #'s
- Wierd rumble/vibration/resonance at idle
- Fixed creaking rear suspension(I think)
- Loud Thumpin.....tranny????????
- Tubbing out the rear?
- help power window problem!!!
- Heddman X-pipe
- Help! A/C service...
- lightweight k-member, more clearance with AS&M headers?
- Need help finding a !CAGS diagram
- Gear Drive
- Wild data log of 1/4 mile run
- Can windshield wipersarms be taken off and readjusted/mine don't seem right?
- Flapper doors on the fans, what do they do?
- help! goin to the track today
- Hotcam-cc305-224/230-cc306?
- Getting discouraged w/IM fix...need a pep talk
- Coolant Light- I'm stumped!
- Fixed my car. Thoughts on 306 with stock TC and heads
- A/C Fixed (for now)
- Shift Point For Stock Motor
- How to decode Lucas Fuel Injectors?
- Please Tell Me Shift Point ! I Have To Go
- Wiring CSI, need people w/ electrical knowledge PLEASE
- car wants to stall while cruising in neutral!!!
- how bad is header "slip-in primary" leak????
- ANOTHER exhaust Question Which one..?
- Should I do my cam install myself or pay someone???
- what temperature do the outside of headers reach?
- Dynoed my car today
- Southside subframe connecters
- doing intake leak
- Dyno'ed my car last night
- homemade 8.8 is in the car. Total cost=$125.
- I gutted a the cat too....
- track times
- need help!
- Need Hep Asap Please
- slugish when warm
- RPM stumble
- looking for an upper control arm bushing
- Converting Victor Sportsman Intake
- Need gaskets
- burnt wire?
- what lifters to use with hotcam
- question about moving car
- Ok my 12 bolt is pretty damn quiet...will it get louder?
- Cam selection help please.
- How far off is the stock tach?
- People with SLP headers (93-95) inside
- header bolts come loose
- how long does jet-hot coating last
- Such thing as an LT1 girdle?
- what am I missing?
- EGR blockoff
- 12 bolt ABS TC question
- worth it to get emmisions with LTs??
- EGR "valve" removal best tool and what to do with the vacuum hose
- What does this wire go to?
- Possible dying opti Pt. II
- Bad o2 sensor?
- all those with jethot lt's...........question
- plug wires
- coil wires and abs light
- Alternator output only 14.1 volts
- Mufflex, Install Photos ?
- Can I replace my catalytic with a dynomax bullet muffler??
- Worst Dyno Day Ever!!!
- Catco cat ...is 14" long enough ?
- BeCool Radiator
- Coolant hoses going, all within a few weeks.
- serpentine trick
- which exaust to buy?
- Wheel weight question
- nitrous backfire
- New Clutch
- help me build my engine
- Help, is this to much airflow at one time?
- Lloyd Elliot does it again! flow #s inside
- Best Shift Points for A4 2.73?
- hood heat shield replacement
- The smell of gas inside my car
- Mr Gasket Copper Seal Gasket is Part # 7154
- need help picking out torque converter
- I can feel my hesitation in my gas pedal..
- Engine Work
- security light on when ignition is off???
- quick magnaflow question...take a look
- hp question relating to time slip
- Difference in these AC delco oil filters??
- Koni DA's
- Confirm P/N #'s on LT1-T56 Bellhousing
- Eibach Vs. 1LE springs
- what would happen if i plugged the wrong wire into the wrong injector?
- Stock Exhaust size
- MAC Headers
- Options?
- overheating! friend in need of help
- Pace Setters Short Headers
- T-top leak
- hesitation? turns off? PLEASE HELP
- part question
- Have LT4 conversion, but what NEXT???
- I need a timing set
- Preps for Starting an engine that hasnt run since at least 1998 ?
- Just had my first dyno run....NOT GOOD!
- plug wires
- Holley HP Annihilator Ignition System any good?
- heres a good article on optispark
- Ignition woes
- T56 removal, installation (with new clutch)
- What would you pay for this?
- Cleaning Coated headers
- Oil pressure gauge "bouncing" a little. Anything wrong?
- Oil Pressure Sensor Plug ?
- Speedo cluster swap question
- Cant drop the tank for new Walbro
- 384 rwhp 354 rwtq
- Stall Converter Questions
- HO intercooled w/ P600B / 8psi. 2 core intercooler
- New or rebuild
- Why Doesn't My Keyless Remote Work??
- Broken exhaust manifold studs
- Whats going my opti or my clutch???
- What advantage will I have with a 2500 stall t.c.?
- McLeod street twin users: does your t/o bearing?
- Correct Fuel Pressure
- Questions about MAF upgrade.
- What is a speed sensor?
- new to the group, quick ?
- Misfire diagnosis, ECM logs inside
- Stock 6speed Owners & 1/4 Times
- Lloyds phone #
- how could i tell if this cam is a LT4 hot cam??
- Can I take out a LS1 Yet???
- Anyone have base shift points for 3.42s?
- AHH! Exaust Leak !!!
- What is the widest tire for a stock 16" wheel?
- Vig 2800
- Transmission help
- Throttle body bypass
- color me confused
- What is the fastest anyone here has gone with a stock A4?
- Part number for OEM rear brake pads please?
- Difference in quality for Brake Rotors?
- Car is running like crap....any opinions.....?
- Stock Oil Pan Depth
- "Jerking" on acceleration...
- Anyone use Yokohama AVS ES100 tires?
- RR size question
- replacement filters slp
- How to make DFI work in harmony with factory gauges and accessories
- where can I get a 93 single cat off road pipe?
- Bad Opti Symptoms?
- worth gutting cats on a dual cat car?
- should i keep my LT1???
- Which Cars can I take
- need some help on new tranny, stall and old mount.
- what size bolts for engine stand?
- Do i need 4.10s for the xe 230/236 cam??
- Water Wetter?
- any websites with guides on replacing the posi?
- One green wire left by the MAF Whats it for ? Shoebox ?
- CO2 Purge?
- Exhaust Cut out
- Rear end Lube
- Sucking noise + hesitation
- What does a closed EGR valve look like?
- CAM, can i do it or should i pay
- o2 sims
- High Beams
- No Tach
- throwout bearing is making noise
- How do the A pillar covers come out?
- Mufflex 3.5" or 4"??????
- My tranny may be dying...
- Steering wheel isnt 100% strait
- gmmg on lt1
- head install guide
- Won't turn over... 94Z
- Oil Pressure
- lakewood d/s loop, who's using one
- Where is the best place to buy intake elbow?
- where to buy lt-4 knock retard
- Its got a big Crack!!!!
- Dual filter Oil filter????
- Evaluate my engine combo plz...
- Driveshaft Safety Loop with Duals?
- Roller rocker size question
- Auto trans needs work. should I switch to 6 SPD?
- blown head gasket???????
- What are the symptoms of a bad map sensor?
- Switching ASR over to non ASR?
- True Duals: I need "how to"
- What are the symptoms of a bad opti?
- Struts
- BULL****! My dash plastic cracked for no reason: LOOK PLEASE
- Would dilectric grease change the resistance of my msd rpm pills at all?
- odd starter problem
- GM additive...Is the autozone ok?
- 10PSI SC 93 Z on ebay ... STOCK BOTTOM
- Which Headers To Get?
- Borla Diferences?
- Help!
- M E/T streets or H Q/T?
- Car is very hard to get into 6th gear! What is messed?
- best way to hook up fuel pressure gauge
- supercharger? do or dont, and what needs to be done to handle it
- how many liters your z28 need?
- In thory which would give better flow?
- Getting Knock Retard...What to do?
- Problems after mods
- Flywheel resurfacing
- changed my plugs and wires... well 4 of them
- Cat Cut-Out on a 94 T/A???
- Plugs........is it really that hard????
- how do you lock the blms with TC
- who used thes tires
- What can I use to fix a crack from the airbags going off?
- spohn torque arm
- Horsepower
- OK what in the hell does an oil/pcv breather do for the car???
- how to tell if injectors are HIGH Z or LOW Z?
- ONEQUICKTA2=good seller!!!!!!!11
- strange elec. problem
- put the gear in neutral, rev it up a little bit, the SES comes on, then off
- What is a good head porting book?
- Question about actual exhaust piping
- ABS inop and air bag light fixed.
- Ball Bearing Oil Gallery Plug??
- Hesitation.. wires.. and more..
- First time at the track what do you think?
- Where should the power peak in my motor?
- how do yuo diconnect the throttle and cruise cables from tB?
- How many fuel filters are there on my 97 Z?
- Anyone ever have an A4 chatter in reverse?
- where to find exhaust hanger bushings?
- turbo 400 conversion
- Need Technical help with HIGH idle issues...Please
- Y-Pipe for 97 LT1
- Will Ford 35# injectors work with LT1?
- Best place for 1le elbow?
- halfway through longtube install and have a couple questions...
- Please Help Asap
- confused and needs help?
- quik tranny ????
- Best place to remove a quart of tranny fluid?
- Havng trouble taking shifter off
- Small leak
