- gauges
- Died in the middle of traffic!
- plug wires and waterpump
- Horn
- Moser 9 inch
- electronic spark control ?
- My electric water pump went out!!!
- Plugging opti hole on timing cover?
- 3.42 gears
- HP/Torque #'s
- o2 sim question
- Newbie Tire Question
- Opti Help~!
- SES light question
- Help!! No First Gear In A4 Trans !!
- Crate motor
- Is there more than one tranny mount?
- Funny small stumble only in 2nd gear?
- When going from 7mm to 8mm plug wires
- MSD 8.5 Universal with Made For You OVC Looms
- I need sensor part #'s....
- MSD Dig 6 VS. Tranny Tach signal
- My LT1 is SLUGGISH when warmed up!!!
- Chrome Valve covers??
- catback & cai, what next?
- PA RACING TUBE STYLE K MEMBER AND LONGTUBE's
- XE230/236 = 20Hg of MAP at idle? WTF!!
- High rpm miss
- 1LE Part #s
- Man! MSD coil PITA!!
- Can OBDII be tricked into thinking an EGR and AIR pump exist?
- wiring problem
- POSI/Limited Slip
- 3rd Gen Tq Arm on a 4th gen
- Choice on Valves, Manley, Ferrera, LT4?
- spark plugs maybe stuck
- Security light???
- Removing air pump and hoses?!
- If I put mt CATS back on...will be SES light go off?
- Doing an oil change, first time on my baby
- I Need More For Calendar
- Buying Enkei 17x9.5's, what size tires will fit perfectly?
- spark plugs?
- Going on a diet......
- Help Me Please....
- skip shift question
- I'm so sick of my car...
- Running Tempature
- help me piece together a 355 rotating assembley!!!!
- what do u think of this 355 build up?
- Rear end Swap
- What would turn engine oil milky?
- t-top fastener
- What do you think about LS1 speed inc.(Shamburg IL.)
- HOOKER HEADERS longtube for 93+ TA and Z's (are they for real?)
- does not idle after header install
- heads/Hotcam program
- whats a good brand for piston rings?
- EGR blockoff plate part #
- HELP Exhaust
- Whats Best Exhaust?!?!
- Low-Temp Thermostat
- Very slow acceleration
- thump when accerating...not a broken transmount
- How much Break in time?
- Fuel Pressure Problem... need help fast!!
- rattling?
- Screw in valve cover Breather for LT4 valve covers?
- Removeing more emissions
- Remve the cats
- Sorry about remove cats post
- is this supposed to happen?
- 12 Bolt with 1350 yoke..whats ujoin do i need.
- WTF is up with my water temp gauge?
- I have A few tranny questions, Please try to help me
- reversed?
- Trans Tailshaft
- Plugging water pump hole on timing cover?
- coolant gone, dunno where it go
- Need help ASAP
- OBD1 PCM on OBD2 z28
- 93 guys only, with cams
- slight problem after cam
- ARP Head Bolts
- LS1 vs. LT1 Exhaust Compatibility
- Long tube install ?'s
- Impalla SS Gasket - Does Summit sell it?
- who ports LT4 heads?
- O2 sensors
- Starter Problem
- test?
- LTCC coil per cylinder converter
- i really need your guys's opinions... what would you do?
- Wiring Question...need help ASAP
- Need Help Quick
- BMR k-member and LT's
- Shocks -need new rears -affordable options?
- Hypertech 160 Powerstat
- Book...
- Clutch Cellonoid
- who is running a Transo go shift kit and a billet servo 2gether?
- Does non mandrel pipes make that much of a difference?
- Header Question
- O2 Bungs location?
- Tie-Rod
- Skip Shift in 6 Speeds
- why cant i run 4:10's in a a4
- vibration in clutch
- switching to th400 ?'s
- any way to get rid of eltronic shift on 4l60e
- New springs for LT4 conversion kit
- finished lt install, ok to run w/o O2s?
- 9 degrees knock at idle, 6 at WOT, about 3-4 at cruise
- Why is there so much play in the throttle?
- Keyless Entry?
- Electrical Wiring Help for a switch
- Canton pan fitment issues?
- corvette converter
- Help please..
- A/C questions
- cloyes and timing chain cover clearance?
- A/C fuse problem. Any ideas?
- aside from cam specs on a N/A car, how hard of a redline can the bottom end handle?
- 58mm t/b gains on 12.5:1 383 stroker
- How much Hp is a computer tune worth???
- Shrader valve fitting
- Alright help me get this hesitation fixed details inside..
- Tire wear
- Borla Y pipe
- I couldnt be more pissed
- Loud clunk and Vibrations form under Car
- transmission problems
- need close up pics of engine!!!please
- Hotcam guys.. In here Please
- '97 Suspension question
- Dynabatt battery? Bolt in and go??
- Throttle body spacer worth putting on?
- Anyone know Lloyd Elliots mailing address?
- ok, my turn to get cam! which one.
- BMR Bolt In Relocation Bracket Install
- best bang for the buck for a 1993 automatic transmission??
- Need scan help in Louisville
- Got my SLP Bolt-On SFCs installed.. WOW
- I love my LT1!!!!!
- speedo off?
- Flushed Radiator, now got small problem.
- MadZ28.com ownz you!
- 75/25 water + coolant okay for winter
- Corvette magnesium wheels
- I am gonna have to fix IM leak :mad: ...
- What's causing problems?
- Woodurff Keys???
- My HPPIII Problem and Yours LIST THEM Please*
- Changed Wires and coil Trouble Code?
- some more longtube install prep questions
- Where to get MSD universal fit wires??
- Xe 224/230
- opti questions
- Extremely Hot Trick Flow...
- Manual Fan Switch owners inside.
- wierd noise
- Throw out bearing
- Oil Gage at 80+ any answers?
- some codes
- torque arm
- Richmond 3.73's... how much "whine" is normal?
- Best brake pads for 17" rims???
- Ok my car has some serious problems
- Is there a message forum for Pontiac Grand Prix?
- What kind of transmission mount to get?
- Lifter valley screen kit questions, mindgame, bret?
- Designed to leak oil?
- Why the hell has no company made a complete, cheap, reliable opti eliminator?
- Old time jerry rigging
- An open in a ground wire, will it still ground?
- Header Bolt Argghhhhh
- 58mm Throttle body
- Stock steel vs 1LE for drag racing...
- Which should I get?
- Thought my converter was stock but...
- Airfoil
- power lose?
- Ok, so I've got this annoying squeak...
- Stock Exhaust
- 4L60E Locks into Second at WOT WHY WHY WHY!?
- Nitto Dr's on stock rims?
- is it ok to pull a head bolt to reseal it?
- $450 for flywheel, clutch assembly, motor mounts, trans mount??
- Putting a petcock in the block drain hole
- Decided on 4.10's....what do I need to order??
- headlight switch and dipstick part#'s pls
- Need to get a new fuel line
- anyone have the water pump housing????
- would someone please reply to my tread?
- Throttlebody Elbow Hose
- msd plug wires
- Window Help!!! Please Help
- Roller Cam Button??
- Just changed my oil.... Kinda Glittery...
- General wait time for a PCMforless program?
- TB bypass
- Throttle Position Sensor Wires
- tt2 17x11
- Water Wetter? yea or na
- Quick zero lash queston.
- clutch grinding once in a while-is she on her last days?
- Any white autometer 2 5/8" gauges that light up blue at night?
- hotcam with ported heads, what kinda power?
- What do you call these things?
- LT4 dyno numbers from today
- Autotapped my car lastnight (many probs)
- HELP! Oil pressure drops to zero when braking hard!!!
- header bolts?
- little engine help please
- Dyno #'s
- Looking for pictures of BMR Extream torque arm cross brace installed.
- How do I put a video file of my 383 Idle run on the BOARD?
- on my 96 will i keep getting ses code p0400 cause i have no cats?
- Is no muffler good or bad???
- I hate taylor ovc's!!!
- install guide for jet fan switch
- Help with Crank sprocket.
- Starter Installation
- Car bogs down low and hits wall up high
- TC lock up mod
- code 64 right o2 sensor reading lean
- exhaust question (anyone one with sims)
- Poly motor mounts, will they cause bad vibrations on an A4?
- LS1 Front Brakes: Wear Indicator Inboard or Outboard?
- hotcam people in here (shift point for hotcam?)
- better fuel pump and bigger injectors?
- BMR torque arm hitting floor pan (???)
- want to see pics of DD subframes installed on your cars
- Help Asap...cam Bearings!!!
- Hood rubber gasket,will removing it for summer let heat out faster?
- How much is my engine worth?
- Cheap place to buy throwout and imput shaft bearing
- got a 383 and a hotcam
- Oil reading WAY off.
- CRAP! My AC stopped working..plz help
- Subframes needed if you have a 6 point?
- Aluminum Driveshaft
- ran my first track time tonight........
- speedo swap question....
- 30 or 33 spline axles for 12 bolt..
- Cometic head Gasket users in here
- Hypertech or jet??
- cluth problems maybe???
- PCMforLess question.............
