  1. Cracked dash from the sun, fixable??
  2. TH400 swap questions
  3. How much power would I gain n/a and be giving up on the juice? LSA Related
  4. how to change regulator
  5. vacuum leak causing problems maybe? (hopefully)
  6. THis is total BS, need to get this solved
  7. heating/cooling ducting problems
  8. lifter/valve lash question
  9. Car takes forever to start!
  10. Injector relay code
  11. Did TB bypass- need to "burp" my cooling system???
  12. I got my street twin today!!!
  13. impala head gaskets: which side up?
  14. Heater Core
  15. "Swoosh of air" sound from eng. bay when I hit the gas??
  16. ABS reluctor and Eaton posi???
  17. Lunati Hydraulic Lifters fit, work?
  18. LT1-Solid Roller conversion
  19. How do u test the cruise control module??
  20. Looking for long tube header pics....
  21. what year computer???
  22. Do I really need to mod my tune after head install?
  23. My TPS reads 100% before it's to the floor?
  24. Question about back pressure!
  25. Help quiet my car down
  26. Need help Bfg or E/t streets
  27. get computer scanned?
  28. Weight of "T-tops"
  29. y-pipe for hooker lt's
  30. changing motor mounts, big job??
  31. can ZO6 parts help us pass emissions?
  32. Killed 2 coils
  33. question about mufflex y-pipe!!
  34. Sounds like a knock but not sure??
  35. Coolant leaking from hole in bottom of waterpump. Is it history?
  36. Weird Ignition Problem
  37. Think i may have solved my problem could a intake elbow cause this??
  38. Warning to Long tube users
  39. How do u get the coil out of its bracket??
  40. titanium retainers and 1.6 RR
  41. ATTN: Injuneer, turbo_Z, slopokrodrigez please help
  42. hmm, called jegs, ordered motor mounts they recomend, look on net, looks wrong??
  43. You gotta be ****ting me....stupid cam
  44. electric waterpump on a daily driver? specifically a 383?
  45. LT1 Head Gasket Replacment Questions....
  46. Will Stock Z06 Wheels fit on 4th-Gen?
  47. Finally got some times
  48. car smokes after wot!!!!
  49. 1 fog light turned off?
  50. what mufflers to use with duals
  51. I got a big problem....
  52. Strange 12 bolt (bent axles)
  53. Failed smog, what to fix?
  54. Annoying people again, LTs vs Gears?
  55. I have no power when i turn the key on
  56. 4.10 Gear Swap Vibration Figured out... I think....
  57. Y pipe
  58. Assorted LT1 Problems...
  59. Is My LT1 Running Right
  60. body repair
  61. A few Formula Questions
  62. Fuel pump question
  63. transmission gurus in here please....
  64. What can I fit?
  65. Please HELP my friend, he posted this on the Impala Forum
  66. hesitation!
  67. Who installed your SFC's?
  68. Gear question and Help
  69. G-Load Brace
  70. Lingenfelter CAI
  71. 99 LS1 gauges cluster in a 97 LT1?
  72. Help! vented opti harness doesnt fit
  73. Difference between 93 and 94+ LT1
  74. Speedometer going up from revving engine???
  75. Door locks quit working.
  76. Trick Flow Elbow Problem... Plz Help!!
  77. Just bought a 1994 Z28!
  78. Intake manifold bolt treads
  79. Milodon Windage tray
  80. anyone with a trailer in chicago/ nw indiana
  81. New product in PHR..."Plasma Booster"
  82. Tranny Question (vettes)
  83. White Residue On Spark Plug Tip (l-shaped Tip)?????
  84. MSD Wiring Harness, Shoebox?
  85. Critical mistake during timing chain install?
  86. Best / cheapest relocation brackets
  87. Did I do right or OVERDO it with mods??
  88. Electrical Question!!!
  89. Moser 12 bolt questions, free Heavy duty cover?
  90. rounded off header bolt, help!
  91. SPA duel gauges
  92. jet hot longtube questions
  93. gonna look at a 93 for sale tomorrow...
  94. dash board part #
  95. Pontiac headlight problem...
  96. Help... ABS and ASR Light stay on!
  97. 160 stat now hotter?
  98. Enlightenment please.
  99. 94 transmission in a 96??
  100. Who here has the free ram air mod?
  101. TPS error with 224/230?
  102. Help me out!
  103. Rear brake replacement? (quick question)
  104. tires / potenza
  105. alternater
  106. what do i need to install GMPP 1.6rr's
  107. experts, PLEASE come on in.. i NEED help
  108. LS1 Brake Swap?
  109. how to install 255 Walbro inline fuel pump??
  110. QTEC electric cutout for borla catback
  111. radiator replacement
  112. Longtube Install
  113. running the car on friday with nitrous, will it be safe?
  114. comp 305 cam with 600" lift valvesprings
  115. unibody repair
  116. Your oil pressure?
  117. Excessive crankcase pressure ?
  118. Could a bad opti cause arcing wires?
  119. Oil pickup screen. Loss of Pressure at High G's
  120. Dynatech Headers and Spark Plugs
  121. Shifting Problems
  122. Top speed
  123. Will i have to modify my vortech intake elbow for it to fit my fipk?
  124. Which Crank for 396 build up?
  125. Pictures of my Combination Motorsports Stage II heads
  126. AC Delco Platinum Plugs. yay or nay?
  127. car won't start; possible fuel pump problem?
  128. 1997 Firebird Formula Questions
  129. what is a normal temp readout for an A4 transmission?
  130. Which tire?
  131. think i may have fixed miss yaa!now need to get rid of surge what causes surging?
  132. LS1 SPEED (SPEED Inc. Shaumburg IL)
  133. 1996 M6 w/ 2000+ tremec syncros... will they work?
  134. anyone know of injector cleaning services
  135. Can someone check out my Datamaster file?
  136. Please help me! spark plug #1 popped out!
  137. Who has dealt with Supersport Camaro Performance Specialists?
  138. Changing my brake pads
  139. 1.6rr???
  140. Valve spring micrometer.
  141. solid motor mounts and poly trans mount, OK??
  142. People with aftermarket intake elbows question?
  143. CSI BOOOO! ...This website YEA.....
  144. abs inop?
  145. Got 32 code, replaced EGR valve, still get the same code?
  146. squeaky wheels
  147. Gauge problem?
  148. Shoebox my problem is solved, but.....
  149. can i run 12s now,or am i crazy
  150. LT1 wheel well fit?
  151. Anyone in the NYC area???
  152. two flanges in back of intake manifold, one is EGR and other is what??
  153. My car sounds like it has a supercharger. Is it my belt?
  154. Water lines that go into the back of the heads. I need a question answered.
  155. wow this is a change from 12mpg
  156. Opti Spark
  157. Ses
  158. SES Light.. only when 140+mph
  159. anyone seen the new ZEX air filter with nitrous injection?
  160. New clip Of Exhaust...what u think??
  161. Dyno numbers
  162. BBK throttle body
  163. Oil dripping from optispark
  164. 383 buildup
  165. Rear End Experts Traction System Help?
  166. attn" anyone about to do a t-top conversion
  167. I was looking for Car Alarms.. this website offered me Corvette rims... WTF?
  168. Here's a tip for you 96-97 guys with !cags that still have the light
  169. Help
  170. Which CAM???
  171. Ls1
  172. Flush and fill or not?
  173. New Accel ignition problems.. please help!
  174. yet another hurdle how to fix ses code p133?
  175. o2 sensor
  176. Next mod??
  177. How to get the motor and tranny out as one!!!! After a crash.
  178. How many bolts does a T56 have?
  179. Guru's help! Car dies and Chevy clueless???
  180. 1.6 r/r installs please help
  181. Felpro Impala head gasket
  182. Cam sheet
  183. LT1FlaGuy(Adam Parsons) call me!!!
  184. problems help. NEED INFO.
  185. brakeing question
  186. SRT 4 vs LT1
  187. Will a bad egr cause a ticking sound?
  188. Heads/cam/headers and ran 13.4 :(
  189. M6 Wiring Harness ?
  190. OBD-I Conversion?
  191. Grrrrrr...
  192. SES light when cut-out is open??
  193. anyone coating their y- pipe ?
  194. S.P.E.C Stage 5 =O DAYUM!!!
  195. free mod ?'s
  196. Cheapest way to the 12's?
  197. MAC problems
  198. Dynomouth exhaust too restrictive for my needs?
  199. Reading spark plugs after WOT
  200. Suspension ?
  201. Fuel pump won't properly work
  202. Need Help! Brakes Went Out!!
  203. More power with OBDI over OBDII?
  204. p1441
  205. Running out of Gas?
  206. engine codes..
  207. What kind of numbers should I get from this cam?
  208. FREE MODS (Or almost free)
  209. Anyone?
  210. I need some questions answered quick about my bolt SFCs, shop putting them on today
  211. Ground clearance w/JetHot LTs
  212. Lloyd Elliot LT4 head flow #'s
  213. what tools do you use for porting?
  214. Is the IAT sensor gasoline resistant?
  215. hpp question
  216. Eliminating dash rattles
  217. '95/'96+ LT1 differnces?
  218. How much is too much? SMOG?
  219. Part number for cloyes chain?
  220. motor mount problems.........bolt wont slide out!!!
  221. Grounds on 95 LT1
  222. What size tranny cooler for 2800stall??
  223. Tried to program my pcm
  224. 4l65-E
  225. Rear end oil change, how?
  226. Realistic gains off headers
  227. How much do GFX weigh?
  228. MAC header torque gain?
  229. Coolant Level Sensor
  230. Summit Forged Kit??
  231. Car feels sluggish after xe218/224 install, NEED HELP!
  232. HOw hard is it to replace 2 bolt mains with studs?
  233. Check out these LT1 Timing Sets
  234. what?
  235. RT Y-pipe for SLP headers and Borla catback ?
  236. What will happen is some high temp gasket sealer gets in my intake??
  237. whats going on? need help
  238. Wiring Diagrams Needed!!!
  239. Should I get better heads?
  240. Help Me With Engine Miss
  241. What Next?
  242. Front Skinnies
  243. What are the symptoms of a bad egr valve??
  244. What's the best shift point for stock A4.
  245. ? on tires. Balancing.
  246. well shoebox and everyone opti did not fix low rpm miss im so lost???
  247. how many 02 sensors?
  248. iac valve on 97 SS
  249. New Way to Clean Inside Your Engine
  250. Factory keyless entry reciever wiring question..
