- popping through exhaust...too rich or too lean?
- How good are the restalled SLP or LT1Dave converters?
- engine rebuild
- MAC Header Question
- diff between 95 caprice auto tranny and 4l60e?
- Auto Tranny feels like its starting in 3rd gear???
- Lt1 Help
- Why am i having to give my car gas for it to start?
- Tie rod end boots?
- clicking in steering column....
- Oil level sensor leaks oil!!!!!! Anyone?
- CAT or transmission. is one going out?
- Proper method for cutting shifter stick???
- !EGR and !AIR, reversable???
- Part number for K&N Air FIlter for 97 SS
- What's better toe in or toe out on wheel alignments?
- Cam Swap
- How do I remove my rotors
- is there any difference in timing chains between a 96 and 94 LT-1
- lowering springs
- Moser 9", Leaking fluid out the breather tube
- did the intake leak fix and now i have a check engine light and my fans are always on
- What size cutout for stock exhaust?
- Installed SFC's
- Wilwood Upgrade and Firehawk Wheels
- Longtubes with the Loudmouth...
- what happens when you unplug the IAC?
- Ignition switch?!
- Will someone help me post a DYNO graph for XE224/230?
- I should know this, but whare are the options that come with GT package?
- Oil leak from fill tube?
- How Hard is it to put Rocker Arm Studs in????
- weird bump when I floor it
- How hard to get to the EGR??
- Wheels/Tire.......how big??
- Turn Signal Lights....on front????
- Where is the oil pressure sending unit
- timing on opti change
- pass. side header, what's that tube for??
- Anyone have Flowmaster 1 chambers?
- 93 and 94 Y-pipes the same?
- First time at the track
- Dropping engine... steering linkage and sir coil question...
- Exhaust Help
- Chasis Lube, Where to Lube?
- Throttle Body Cover Plate?
- Oil sending unit or oil pressure or something of that effect?? need help please
- Power gain from these mods?
- will a 98 99 gms MAF work on a 94 LT1?
- T56 swap done... car vibrates like crazy above 3K RPM
- nasty backfire....
- cam timing
- K&N opinions.
- MAFT Question....
- What would help this?
- summit sent bad lifters, bent 2 of my pushrods
- Car now has low idle
- Anyone know what this knob might be for?
- I need some help with my AC
- I need a wav clip of..
- Cam/Stall/other suggestions needed
- Suggestions on what to retorque?
- Ran the 1/8th!! Q's about time inside!!
- Bilstein Tuned Suspension good price?
- A couple of questions
- Cranking car by hand
- What breaks torque arms?
- back spacing for skinnys up front
- So what is considered a light moded car?
- Cam Selection
- help with egr removal
- Questions about handling/suspension mods
- Camaro Cowl Hoods
- Better Lighting ?
- What is Considered "Lean" when at WOT
- Tapping a fuel rail
- Oil Spike On The Spray???
- R062 Redundant SIR Indicator Circuit Failure
- m6 conversion is complete
- tranny mount issues
- how does "check guages" light work???
- Bosch 42lb Injectors
- AS&M throttle body's
- ordering parts for a 383 shot block within the next few months.. couple q's
- It's GOT to be the EGR...
- clutch adjustment (M6, SPEC stg3)
- flakey power window...
- If true duals makes more hp why dont more v8 guys run them?
- Best Distributor for LT1?
- problem after gears
- Budget Exhaust System???
- OK to switch from synth trans fluid to organic?
- Loose steering
- People will high grabing clutches, READ!
- Very happy with my tune from PCMforless!!
- WOT Timing
- In need of 1 valve cover bolt......Badly!
- damm trani places
- need part #, belt for march pullies?
- lt4 block off plate part #
- Can I use CAM 2 leaded gas.
- Suspension trials & observations
- Clutch
- Setting pinion angle with BMR TA.
- HELPPP.... my right and left o2's sensor's are running lean the scan said
- 94 Z28 Redline and WOT shift points?
- where to buy 2 new 02 sensors??
- Hello from newest member & ???
- Question about switching to Synthetic?
- What could prevent Hard Acceleration whe you floor it from a STOP??
- A4 guys what are you running for max line pressure
- electrical/stumbling problems....please help
- Auto meter A/F gauge ?
- HELP! Oil in the intake???
- EVAP canister purge solenoid valve rubber boot replacement...!!!
- Who thinks total seal piston rings are junk?
- What's a good oil pan for 396?
- Does anyone make a non-detergant 30wt dino oil?
- Locked pcm?
- in the middle of opti change
- tune up
- What to do What to do..... Just bought LT1
- blew out the center of my strut mount!!!
- New Wires Or Opti?
- What kind of summer tires?
- Vented Opti Conversion!!!
- losing oil pressure when accelerating
- 3:73 gears
- what to look out for in a used 4th-Gen
- Stock Z28 tire size
- Lt1 pictures
- Name that noise
- Mac vs slp vs jet hot lt's?
- Clutch is slipping
- checking out new car
- A4 Trans Problem
- 383 sortblock
- 3:73 gears what else do i need
- I think my turn signal flasher is bad, am I right?
- Be cool or CAS radiator
- What Rachet Shifter?
- supid slipping clutch
- Egr Help!!!
- New tranny and converter and cooler how much fluid?
- Why is my car running like crap with open headers??
- Need help with Fog lights
- Am i the only one who's steering knuckle is rubbing their headers??
- where to mount MSD digi 6 in 95 Z-28
- If i lover fuel pressure will PCM correct it??
- Synthetic brake fluid - safe to use?
- What are some difference between OBD1 and OBD2?
- Por Que No Whoosh?
- what tranny?
- Fuel pump ...please?????????
- Who sells a stock MAF
- Popping exhuast please help!
- Intake Elbow????
- Grinding noise...
- Can't seem to pass SMOG even with fixes...can someone help?
- Loud sounds from rear......not gas!
- Maf
- Weird noises when cooling fans turn on...
- New cam/spring swap info on my Tech Page
- car wont start
- Turn-over problem
- Intake oil leak, a question....
- Windshield wiper problem???
- No SES lite but ABS inop AND air bag.
- I Have the Slowest Stroker ever
- Question on Hypertech termostat install.
- Moser 12 bolt ?'s LS1 rear swapped to an LT1
- Gears
- Clutch Material
- What did you use to install your new pilot bushing?
- Anyone have a COMPLETE list of parts needed for a Heads/Cam swap?
- Part# Confusion
- Anyone have a MSD 6al bite the dust?
- steady temp rise at idle but lowers when under load??
- Coarted vs Uncoated bearings?
- What would you do? 396 rebuild
- Shoebox Why is the wholesale price on headliners here so high
- Am I Asking For Trouble??
- Dyno Graph of Torque converter gains!
- Cutouts
- Got a problem need help
- need help ASAP: car goes sideways inder throttle after adj lca install and new slicks
- gettin a bad vibration after tranny/converter install...?? HELP!
- Metal grinding noise
- Can someone PLEASE help me with this sputter.....???????
- Where can I get a good crate motor??
- light/short shift
- any video clips
- Is this 12 bolt any good?
- Where to put the counterweight on the back of the Street Twin flywheel?
- ??? About Heads Wapring
- High Temp vs High Performance Thread Sealant???
- Encountered a problem with my main studs . Any input appreciated
- My Experience With Thunderracing aftermarket Wire Looms...
- where's my Torque at?
- LT4 KM Results (G Tech #'s)
- broke a bolt in the axle..help
- What causes O2 sensors to fail?
- Will '93 exhaust manifolds work on a '95?
- why is my y-pipe rotting out from under my car?
- high impedence injectors?
- Will I lose low end torque?
- Well finally dynoed my car...CC306 w/stock heads.
- LS1 brakes question (about brake line interchange)
- Should the clutch slave cylinder look like this? PICS
- easiest way to remove steering linkage?
- Need LT4 Knock moduel#?
- Those with LTs and no cats, questions inside.
- Need some parts #'s..
- 4l60e
- Fuel Pressure Questions
- springs
- With my mods, do I need a larger throttle body?
- will the 224/230 get me into the 12's?
- Can you test a Fuel Pressure Regulator?
- Help: What is the firing order for wires
- HELP!! My car is F'd up.
- Best clutch
- Help me Diagnos front end problem
- 02's at 950mv at WOT, no retard, rich??
- Spark Plugs
- LS1 in a LT1 car
- Making your own OBDII/I diagnostic cables
- Header install is done and it has less power!!
- ofWhat does this connect to (part clutch fork) *PIC*
- Removing fuel lines...
- Losing oil pressure under acceleration with 383
- how to determine what rearend you have??
- What size taps are needed...
- Door swap? 94 doors to a 99
- Dyno Results in
- Where to purchase lug nuts for SS wheels ?
- knocking sound from the tranny area(loud)!!!
- MSD Blaster coil and optispark problems...
- Lowering fuel pressure
- weird misfire please help!!!!!(long)
- how far will crank hub slide on until it needs "persuasion"??
- New #ers.
- Please Help With AC Problem
- Major loss of power while running open headers, very hard to start
- Need help diagnosing problem from a datalogged 1/4 run.
- Rear end and Nitrous
- What to use on bolts?
- Vent control not chaging from defroster
- How do you get clutch fork on properly??
- smoke from ABS unit when trying to start new motor setup?
