- ignition,fuelpump and injectors??
- DriveShaft Safety Loop
- Time for a tune up.
- stock 94 TA
- please help me, codes and eec??
- I have a humming/howling noise coming from the rear of my car
- OBD1 Computer Question
- Wanted to get ported heads with STOCK cam
- How to retard timing
- I feel retarded asking but ...
- 95 LT1 Rebuild Costs
- Driveline Question!
- im getting an SLP clutch...any objections?
- 96 Z28 low coolant light
- electric water pump?
- any worthwhile mods?
- sick 10-bolt
- Paging all 93 Owner's!! Please check this.
- Highest HP parts for $1,500?
- My car bogs down really bad... know what it could be?
- valve spring question???
- Trans Am guys w/ K&N FIPK, where to mount headlight control module?
- LT4 heads/ cc306 good combo?
- Emissions testing
- Just realized my cruise control cable has been pressed against my headers!
- High idle
- SFC's how will they affect the car?
- Jet Hot Lt's Suck To Install
- cracked Intake Manifold ?
- Tb bypass
- if the opti gets wet
- power buttons
- Any suggestions
- Headers toasted my O2 wires, have to fix and need advice
- how much grinding on calipers to clear draglites?
- cc305 CAM PEOPLE
- LOUDmouth!!
- Hot valve adjustment.
- Summit discound code?????
- rough and squeaking sounds from the rear
- Will A 97 Tranny Work In My 95?
- What all can cause low IAC steps?
- How long does it take to get items from thunderracing.com??
- LT1 exhaust question........
- need part numbers asap!!
- WTF?? Have to drop the rack and pinion to install long tubes?
- Slave cylinder mod for m6's
- LT4 conversion #
- high speed fan wire, blue or green?
- timing retard box????
- little miss at part throttle
- Windage tray with 3.75" stroke crank?
- Possibe different rear gears in 97 aniversey Z28
- raceconverters.com
- nitrous
- pulled code #'s...
- What next?
- Exhaust question from a newbie
- problem. need help
- 97 Z28 - Problems abound?
- 4.10's on a full bolt on and 100shot LT1??
- autotap
- I Hate Advance Auto Parts !!!
- Will this work on the LT1? timing cover related
- when hot outside, knock goes away
- Head and cam package down on power
- Help!!
- price of conv. top and windshield??
- true dual sound clips??
- Problem with 97z28
- Reactions and a question about my new XE 224/230 and heads setup
- OVC wires install tips?
- 97 stall work in my 95?
- New, with a new LT1, and questions
- Phantom Tires
- Where could my vacuum leak be?
- Temp Gauge Questions???
- need part #'s for pistons and rings
- track times vs. temperature???
- How does a bullet muffler effect sound?
- DS question
- where can i get flex pipe? autozone= no more flex pipe
- fan problems
- What are the limit's of the LT1 block?
- removing hatch
- LCA's, which are the best?
- Need opinions please,anyone?
- LT install......do i remove the alternator bracket?
- Detonation and KNOCK What is the indication.
- What could be causing my car to run so slow?
- acdelco wires $92 WTF
- write up on changing plugs and wires?
- anyone dealt with lambert?
- Interior Smell
- 1/4 mile improvements with SLP 2OTL
- what size pipes to runn from Jet hots?
- Do I need to keep EGR solanoid if the EGR valve is removed? SMOG ???
- What type of oil to use?
- Bad lifters?
- Changing opti, any hints or suggestions?
- Loose rocker arms
- Part # for ARP Main Studs?
- why do my altinator bearings keep going bad?
- Help again with schraeder valve!
- Red Coolant Light!
- attention SHOEBOX.....
- worn posi clutches???
- please help identify this wire...
- 12 Bolt question What size drive to open the drain
- Electronic Speedometer Converter
- The Fastest LT1/LS1 T-56
- Spacing the ICM from the Block with Washers - Myth?
- getting jethot longtubes what else?
- car bucks when going down the highway
- Switching to mobile 1...
- What would you do with this car?
- loyd elliot (sp?) heads.. any hp #'s?
- Moving to California - Emissions Questions??
- Does a 99 v6 have the same brakes as a 99 LS1?
- 93&94 door glass rattle fix
- car couldnt be running worse
- Huh??
- i guess you guys were right may not be opti im so lost want to sell???
- Mac Hearders
- Car won't start, just clicks???
- any other ideas... "high end miss"
- Need info/part number on oil pressure sensor
- Will my stock plug wire location be alright with my headers for now?
- Bullet in ORP
- Gains with hooker cat-back on a 96'?
- One more time....what cleaner do i use on the TB
- Oil pressure sending unit, uses one connector... but!
- Need Jason Cromer's #
- What are EGR bolt sizes? Must have ASAP
- odd miss after overheat..
- HELP!!! My battery keeps discharging!!!!!!!!!!!!!
- What is this?
- Ram Air hood mod?????!!
- Over Heat
- fog light question
- constant miss at all rpms
- how to get dipstick tube back in with LTs?
- quick plug wire help please
- Header Questions
- Resistors for OBDII fan mod question...
- Borg Warner Oxygen Sensors
- Autometer Electronic Speedometer??
- LT1Edit and new dell laptop not working!!
- Single Cat Headers Conversion
- Going to burn my LT1, who's with me??
- Wet moist opti. Is taht bad?
- Car running Lean?
- Shifting out of reverse.
- LT-4 Intake?
- what to torque arp main studs at?
- How hard is it to install an oil sending unit?
- How much do you tighten the sway bar bolts
- 383 runs bad, ticks
- how to test plug wires?!?
- guage says I'm runnin mega rich, i have PCM data though, help
- 95' 10 bolt into an 02'?
- I wonder why new optis are brown?
- opti spark
- What cam should i get to match my head flow numbers...
- will this rearend fit?
- SES CODE help!
- broken valve seats
- Vented opti lines... where do they go?
- Transmission finally kicked the bucket... Where to buy?
- Does anyone offer these items as a cam package
- Z throws codes on sustained high speeds, is this common with modded Zs?
- Rethreading Pro 5.0 shifter for Cobra knob
- Replacing lower radiator hose tips
- AutoTrannyMod what does it really do?
- Car is running too hot...need suggestions
- Damn Fuel Lines!!! Give Me Some Help.
- Xtreme cam, FP drop and stalling HELP!
- Bad MAP Sensor?? Help!
- CSI waterpump
- Quickest/Easiest way to bleed brakes?
- New to LT1's...
- I Hate Gm Engineers
- can you remoce stock catback without cutting?
- Mystery
- in the middle of 6spd swap and noticed something
- Need good pics of mounted MSD's (search no..)
- Swapping Door
- installed springs/struts and now i have a knock!!!
- Could this have been a partial/full cause to my problems? Intake centerline related
- Why does my car take forever to fire up?
- One screw up, but the beast roars.
- Need some help here...
- Is converting from 6 Speed to an Auto hard?
- Largest tire size for 17x9.5
- Educate me on rear end gear oil....
- How to remove steering wheel
- PLEASE help me diagnos this problem
- 8.8 Ford
- Adding 52mm, 22lb injectors will ECM adjust accordingly?
- O2 Sims...what happens without em?
- How to remove gas cap, help asap please!
- e-brake rattles
- trani gone
- Thoughts?
- Fuse Question
- LS1 K&N FIPK on an LT1? How can it be done?
- Low RPM stumble when dead cold
- Oil Pressure
- OBD2 LT1 programming ... what are my options?
- New to Site, a Few Questions
- Could use bushings...
- LT4 Knock part #
- Whoops! I think i just ruined my MAP SENSOR!!!
- Aftermarket Hub and wheel install
- Cam questions, what size??
- What Brand Tranny Fluid Do You Recommend?
- Problems in the rain
- 95 T/A A4 sticking in park. Cause?
- Drive shaft question? Anyone know of AAM American axle manufacturing..????????
- XE 236/242 cam and head installation done...**VIDEO**
- EGR problems...
- Too much pre-load on valvetrain - Symptoms?
- How fast in 3rd gear??
- Running True Duals OVER rear axle...anyone?
- dangerous?
- A few Keyless entry questions..
- Got cam yesterday.......card says wrong cam????
- help my buddy is about to give up!!!!!
- Window tint, is this right?
- fuel pressure
- Allright techies, how EXACTLY do you match a custom cam to a set of heads...
- CATS or ORY on MAC headers???
- Will check guages light throw a code??
- ported exhaust manifolds and other ?s
- Hydraulic and solid roller cams
- LPE 211/219 cam question.
- Running without MAP Sensor!! No Choice!!
- Rototech Rotors
- best pistons+rods for supercharged engine
- O2 Sensor Location
- CC305 cam, too big for stock exhaust?
- LT1 383 budget build in progress; need opinions
- LS1 fuel injectors.....
- Th 350/400
- Air ? ...
- clicking nosie in the front of car
- GP on Spec clutches ends today. Order yours!
- What if I don't want to get headers right now?
- 383 or 355?
