  1. Which CAI?
  2. n/a no longer- turbo or centrifugal?
  3. scanning tool-worth the money
  4. Creader obdII scanner
  5. aftermarket opti???
  6. LT1 seized?
  7. Location of Schraeder valve, also coil reinstallation question?
  8. Eliminating Pollution Control!?!?
  9. Clutch install, now very hard to shift with car running!!
  10. help with clutch install, pics inside
  11. best pushrods?
  12. How much does spray hurt an LT1?
  13. Will this cam pass emissions?
  14. Is there any trick to getting a brake hose off?
  15. Car has trouble barking tires on 1-2 shift?
  16. My left side taillights are dimmer than my rigt side. How do I fix it?
  17. Fuel delivery problem
  18. starting probs
  19. How do I bleed the clutch system??
  20. A-Pillar install
  21. did tune up after opti went bad and it know misses all on one side?
  22. oil pick up tube info.
  23. popping sound
  24. Some LT1 Myths/Misconceptions
  25. What mark should the clutch fluid be at?
  26. Which Mods? What order?
  27. high rpm miss ,roughness?
  28. Best brake pads
  29. Corsa CatBack sounds Bitchin! Hear for your self Inside
  30. Does this sound like the fuel pump?
  31. deleting cat = hurting engine?
  32. Lt4 components
  33. factory alarm stopped working, Shoebox?
  34. What is the best clutch for the lt1
  35. Exhaust is on!!!
  36. camaro z28 mods
  37. cooling fans not coming on, any ideas???
  38. noisy power steering pump
  39. 14.3 @ 96 mph Please look inside, is this slow?
  40. Starter
  41. Are these any good?
  42. Car almost cuts off with new cam!
  43. Headliner messed up
  44. Will a vortech S trim F-body kit work on a B-body?
  45. Cam selection for some hot heads?
  46. oxygen sensors
  47. wheels on a T/A
  48. I need to win-----please look>>>>>
  49. Where to get COMP R Llifters??
  50. Would a skinny fit on a space saver spare??
  51. 700r4
  52. this clutch install could not have been worse*please someone help me*
  53. How to hook up guages and keep stock guages?
  54. Service Engine Light after coil reinstall?
  55. which notch on opti drive
  56. Best times and HP/TQ wih 230/236 cam
  57. cooling fan mod, getting SES code
  58. O2 Extender Question
  59. shifter cable and two cooler lines... simple q's.. if you've dealt with either before
  60. SES light on after getting into it hard!!
  61. Can anyone help me interpret a 1/4 mi scan and diagnose why my car lacks power?
  62. window motor questions
  63. Need help hooking up oil & water temp, keeping s..
  64. Please tell me what the fuel canister purge tube is and how t
  65. I need help on fixing this problem
  66. quick question!
  67. SLP Clutch...Clutch Chatter??
  68. MSD wires question
  69. ?? for those with digital h2o Temp Gauges?
  70. Big cam, stock heads...What problems can it cause???
  71. melling stock volume oil pump pick up ???
  72. Can I run open headers for about 25 miles?
  73. low oil press, knocking sound..HELP, long
  74. 94" Corvette gear ratio?
  75. Will this work?
  76. What did you do about your altenator when installing lt's??
  77. as&m headers
  78. cutout question
  79. Drag radials or tq converter
  80. Hesitation up top. opti??
  81. stall converters are $750?
  82. ZO6 MAF....Worth it?
  83. How Many Times Can You Mill Heads???
  84. Complete LT checklist....
  85. Do i have to bleed all 4 brakes?
  86. 236/242 cam...stock 1.5rr's capable of handling Comp 918springs?
  87. Cats
  88. where can i buy this?
  89. stud replacement
  90. Opti died?
  91. With 255/50-16's make you 2 mph off????
  92. A4ers, Something I've Noticed
  93. Got some lights coming on, please help
  94. These tranny cooler lines are REALLY STARTING TO GET ON my nerves
  95. This require a break in time??
  96. Low Fuel
  97. Possibly louder?
  98. Need help kinda fast got to pass inspection
  99. Clutches
  100. low on cash, need mods
  101. Are the oil pressure senders different on the 94 and 96 LT1's??
  102. Anyone know what the 230/236 Revs to?
  103. ABS and smaller front tires
  104. What is involved in "stroking"?
  105. Help!!!!!!!!!!!
  106. Is this worth the $
  107. Cheapest place to buy EBC Greenstuff pads
  108. 17" et streets
  109. Stock LT1 combustion chamber size?
  110. throttle cable pulled through...
  111. Midwest Converters
  112. strange idle
  113. SLP Fan Switch Install Question.
  114. Head Break in Period?
  115. Part number
  116. TB Bypass Intallation Question
  117. Suspension/tires help with 400rwhp?
  118. Borl+LTs=ricey tone
  119. Rocker arm question
  120. transmission linkage???
  121. cc305 or cc306?
  122. Is it true that 100lbs equals a full car length in racing?
  123. Anybody ever changed....
  124. tire pics
  125. Tranny Prob in a 67' w/ LT1
  126. Lambert Salvage
  127. LT1 swap update (II)....still wont start
  128. fuel pump discussion (standard 255 vs. racetronix 255)
  129. Smalled tire for 9.5"???
  130. Would SFCs be in the way when I go to do headers?
  131. ? about underhood relays and fan operation..
  132. Alternator
  133. 3:73's or 3:42's????????
  134. Code 300 after oil change
  135. Aftermarket starters?
  136. AustinZ28 future buy
  137. The New guess the motor output *reward*
  138. Glovebox not closing tight. Question and pic....
  139. ARP intake manifold bolts on LT1?
  140. Best clutch for cheap
  141. lt4 EGR Block off plate part number
  142. Valve adjustment
  143. Thanks Shoebox!!!!!!!!!!!!
  144. Car died magically overnight?
  145. Weight difference between Ttop cars the coupes
  146. where to buy ZR1 replica wheels?
  147. Operating temps with electric WP
  148. How is my car going to sound with jet hot lt's and a hooker catback??
  149. Exhaust options
  150. Torque specs for diff cover nuts?
  151. Autozone opti does not include cap and rotor
  152. ? on Record RWHP on a stock bottom LT1 N/A, Hows 452!
  153. break in period for new gears?
  154. What forged pistons (part #'s) have you guys used for 355 and Nitrous?
  155. What all attaches to intake manifold studs?
  156. oil on spark plugs?
  157. manual Fan Swithch Questions
  158. what are the chances of a blown headgasket if you don't have mixed oil/coolant?
  159. pushrod broke through rocker arm, curious questions
  160. Just blew up my star stage 3 clutch.what now?
  161. CMotorsports Stage II Heads/Cam package ? ?
  162. How cold is everyones A/C?
  163. Ignition wires
  164. o2 sensor dilemma.....
  165. Dex Cool
  166. How much play should there be in clutch fork?
  167. alternator question
  168. crappy tranz
  169. Re use heat shields on plug change?
  170. is there a way to verify an opti is going bad?
  171. Serious header question...anyone with SLP headers please help!
  172. Need part #
  173. what clutch to use
  174. Why am I blowing out coolant
  175. Does the PCM use 02's if SES is tripped?
  176. What do you think about these tires?
  177. pcm
  178. Next Problem::::
  179. Help!!
  180. What do I need for a
  181. what header gasket to get, and where??
  182. oxygen sensors...
  183. Engine Analyzer v 3.0
  184. Remote battery terminal thing....
  185. After high speed run tranny shifts hard, change fluid?
  186. i need some mandrel bent 90* bends please help
  187. General Radiator fluid ???
  188. Dyno Desktop 2000
  189. Plugs glowing blue?????
  190. PCMforless and wires or SLP CAI??
  191. LT4 valve covers?
  192. Vette Motors
  193. If you mix two weights of oil....
  194. Still Burning Coolant
  195. Car not starting right???
  196. I Got Wheel Hop!!!
  197. Ported LT4 Heads from Pace
  198. car running rich
  199. Solid Pinion Spacer Worth It for Gear Install?
  200. Spark plug fouling/cleaning/replacing
  201. MSD Ignition Retarding
  202. just order my exhaust
  203. Still have a problem with tuning after cam!
  204. Installing Jet Hot LT's
  205. TA headlight question...
  206. shoebox , need part # please!
  207. i need ricer jokes!!!
  208. Best budget LT1 ported heads?
  209. LS1 coil packs on LT1 car
  210. hood leaks
  211. Good sound cheap
  212. - - > Choosing Cylinder Heads < - -
  213. 95 computer vs a 96
  214. what to ask for when taking block to mahcine shop?
  215. can you use flex pipe for exhaust setups? can it be welded?
  216. diagnostic or computer scan
  217. Bad Fuel Pump? Schrader Valve?
  218. Will the Hooker Y-Pipe work on the Jet Hot LTs?
  219. brakes bad after 6 month hibernation ...?
  220. I need recommendations for a new alternator.
  221. how to keep rear differential from leaking???
  222. LT1 Eldebrock heads
  223. OK to use gaskets that came with JET-HOTS?????
  224. ? about blown engine what caused this
  225. Dual Exhaust Mufflers
  226. What do you think is wrong?
  227. attention shoebox
  228. machine heads?
  229. This is my LAST Jet-Hot LT question I swear fo lawd!
  230. 383 Stroker Start but no temp indication after a min of Idle? Headers are Hot?
  231. A few problems after I've completed my LT-4 conversion
  232. after motor swap air bag light is on
  233. Is this even possible?? PICs of my rear end's carnage
  234. Am i getting ripped off? Rear End Rebuild
  235. question about Hooker shorties bolts...
  236. underdrive pulleys does it ruin a/c?
  237. LS1 Brake upgrade?
  238. Key OHM Resistance a Factor??
  239. how to check resistance on power window switches?
  240. put car back together and it backfires alittle bit????
  241. Fuel Pump Bad??
  242. Starting problems. repeatable
  243. Chrip First To Second
  244. Speed Inc. : Yay or nay
  245. LOUD ticking noise from drivers side???
  246. Car Stalled!!!
  247. whats this little red button?
  248. Engine VERY sluggish after new Opti install
  249. Spray
  250. Draglites
