  1. TB Bypass 94 clarification
  2. Tick tick tick tick tick tick tick tick...
  3. Oil leak from EGR tube...
  4. How do I disconnect fuel line from fuel rail?
  5. Soon to be LT1 owner
  6. Who has solved the Low RPM Stumble?
  7. Coolant fans not working
  8. How do you know if the rockers need adjusted?
  9. 600" lift valve springs with cc305?
  10. Ignition problem?! (Kinda long.)
  11. BIG PROBLEM, car is sitting in drive way, need to get fixed
  12. Oil pump
  13. Whats Faster Trans Am, FireBird or Camaro??
  14. throttle body blades???
  15. installing long tubes
  16. LT4 Clutch
  17. Has anyone ever had problems with justin sutton sending them their parts?
  18. New Shocks?
  19. LT4 valve cover gasket stretched a full inch !!
  20. how to tell what gears thses are?
  21. I need pictures and suggestions on suspension set ups
  22. Wiring scematics on line??
  23. What exactly is cam surge???
  24. Anyone have a spare intake that they trashed and need to get rid of?
  25. What is the combustion chamber size on the stock lt1 head?
  26. Cop prob w/ exhaust
  27. where's PWR door lock Relay on a 93?
  28. 12's possible with
  29. Simple Question:
  30. Big Problems, new to Lt1, need some help
  31. Help with AFR rev kit!
  32. Oil Pan gasket question
  33. things needed for slp dual cat shorty install?
  34. how to delete air and egr systems totally?
  35. 93 vs. 94-95 AS&M headers
  36. Ignition Switch Question (Need Clarification)
  37. Another what would you do...
  38. Low water light?
  39. Worried about getting bolts out of manifolds the ones that go to the heads.
  40. What to do?!?!?!?!
  41. low cooling fans is not enough
  42. anybody replaced the brake line that runs from the abs cylinder to the rear brakes?
  43. What Is The Best Aftermarket Clutch For A T56 Trans?
  44. abnormal shifts on my A4 tranny
  45. My car passed emissions! lol! finally got to debut my new custom plate!
  46. Somebody please help! Shoebox?
  47. Valvetrain Advice needed
  48. check out this deal >>>
  49. Need to change EGR valve quick question?
  50. Just Got 95z...Need Engine Help!!!!
  51. ram air hood question????
  52. Best Performance Non-lowering Spings
  53. has anyone went from dino to synthetic in rear end??
  54. anybody running a cam with 111lsa or lower
  55. did anyone cut out splash guard after cai install?
  56. rear end or shocks
  57. SLP Loudmouth
  58. power steering pump replacement...best option?
  59. Got my afr 220's flowed, what do you think?
  60. Where is the BCM on a 94 car?
  61. Possible to swap keyless.........
  62. Car is slower.
  63. finally, some track results
  64. 93 A4 Servo
  65. How do I adjust the throttle cable
  66. Blower & 42# inj, what else will this car need?
  67. Great. car doesn't start now
  68. trans cooler location
  69. axle swap
  70. Once again,many thanks Shoebox
  71. When your 10 bolt goes...?
  72. Need KM after only headers?
  73. 1993 f-body kick down cable
  74. Tranny Cooler
  75. Gains with 4.10s?
  76. ls1and lt1
  77. backspacing and bolt pattern for stock wheels?
  78. dealership doesnt know what there talking about?
  79. Shoebox I need your help one last time!!
  80. another complaint with my pacesetter shorties
  81. Still cannot decide on which cam for stroker/nitrous PLEASE HELP!
  82. cars with duals and x pipe inside, g load brace?
  83. Driveshaft Vibration Problem Solved - Fast, Quick and Cheap!!!
  84. tranny temp
  85. what gauge cluster years will work with my 94z?
  86. Gas milage...
  87. Anyone running LT's and a cat inside please.
  88. dyno graph
  89. Doing header install tomorrow any words of wisdom or a simple good luck.
  90. help what gears do i go with
  91. can i run dual-cats on AS&M headers?
  92. Case of beer to who gets my car to start
  93. th350 kickdown cable
  94. Mufflex Y-pipe?
  95. Brents headlight fix
  96. Underhood Temperature
  97. need help real quick - LCA stock bolt sizes
  98. So what do you guys think?
  99. please tell I didnt break something
  100. need advice on fuel pump
  101. Stock gear options???
  102. rocker arm / valve problem ...
  103. wheels?
  104. A4 guys with 3.73's......
  105. Where does these vacuum lines go ?
  106. A4-M6 swap questions
  107. Found this box under dash.. alarm?
  108. newbie here
  109. Lunati Timing Chain
  110. Want to show the car I'm buying
  111. HELP! T56 still 1/2" away from bellhousing
  112. How To Build A '95 Camaro/transam Right
  113. cam on stock LT1?
  114. OEM Coil or aftermarket ign coil?
  115. Is there anything I can spray on the weatherstripping so my window goes up faster???
  116. Can't get fuel rail out, need help?
  117. How much knock does it take...
  118. Combination Motorsports Stage 1 Head/Cam Combo
  119. 93 z axles
  120. opti differences. help needed
  121. What headgaskets and injectors w/ new heads/cam ?
  122. Stubborn Valve Lock
  123. Anxious headlights
  124. hooker with borla cat back
  125. help Best plate or wide open
  126. AutoZone Opti Parts? More than one Model?
  127. Well, my tranny went out on my tonight
  128. which splayed main caps for lt1
  129. help me choose SA vs Non SA rockers
  130. pics of GM Perf. aluminum valve covers
  131. Anybody with the new MSD 96-97 Coil?
  132. Man i ran with open manifolds today details inside!
  133. opti/plugs and plug wire?
  134. Check Gauges, then car dies......Opti? ALternator? Battery? HELP PLEASE!
  135. Just installed Crane Cams HI-6S and LX-91, 1/4 ?
  136. Could I have bent a pushrod?
  137. Handling questions
  138. bad brake booster ?
  139. stumble with open LT's.....HELP
  140. Hesitation Problem..Happens right at start up
  141. Tranmission overheating?!?!!!!! (shoebox and others that know about this stuff)
  142. Cars dead! In somebodys yard Need HELP
  143. Well since motor is almost together, what do you think it will put down? *Reward*
  144. LT1 w/ Hooker Cat-Back sound clip
  145. Mcleod adj. master cylinder ?
  146. standard sbc heads on a lt1
  147. Cam dowel length from cam gear?
  148. good deal or bad
  149. flushing coolant from block
  150. LT4 heads w/ cc305
  151. Loudmouth and no cat, anyone
  152. lost oil pressure!
  153. quick swaybar install question!
  154. Possible Lifter Tick??
  155. Heads and Cam or NOS???
  156. AutoTap EFILive work with LT1?
  157. Please help, Tranny Problems
  158. broke a ball off the pushrod last night. need advise where it could have gone???
  159. A4 to M6 flashing computer
  160. 93 throttle valve cable preventing WOT
  161. jegs torque arm kit
  162. What aftermarket valvecovers do you have?
  163. cc305?
  164. Solved my oil pressure problem
  165. A/C what should the high and low pressures be?
  166. T-56 Swap in a 93
  167. Drags at Steele, AL
  168. will this throw-out bearing work,pics inside
  169. Question???
  170. Budget strokers, can it be done?
  171. NHRA kill switch ?
  172. Finished the Goodyear "High-Miler" Hoses install
  173. cooling problems, please help!
  174. Time to play, Name that Part ...again (got pics)
  175. Problem Codes 100 and 103
  176. help with hooking up manual fan switch
  177. heads and cams help decipher
  178. fuel pump?
  179. LT shopping list. Anything I'm forgetting
  180. LT1 swap problem
  181. T56 w/ problems... fork or syncros?
  182. Dielectric grease
  183. 450RWHP LT1... How much?
  184. tire size
  185. oil primeing question
  186. Need opinions with the "hidden" shift kit
  187. Camshaft Questions
  188. My plans, what kinda numbers?
  189. Edelbrock CHs again
  190. Trans shot
  191. Gtech Pro .... Good or garbage?
  192. ***urgent*** need help with this clutch please help
  193. Tried to install headers today and it couldnt have went worse!!!!
  194. What do you use to add tranny oil to M6?
  195. Occasional SES light and code 34
  196. speed limiter
  197. I need part Number.......
  198. Fuel Line leaking ?
  199. anyone else have a rattling clutch?
  200. Were to buy a 383 short block?
  201. rewiring help!!!!
  202. Granatelli? or just port the maf?
  203. Exhaust Question. Catback vs Muffler?
  204. 97 z rims on a 92 jimmy 4x4 ?
  205. SS Ram air intake VS Cold air intake
  206. Pound rating for stock springs?
  207. Bigges diameter valves that I can use on 190 LT1 AFR Heads?
  208. I need an EGR solenoid....
  209. What exhaust.. Post all Exhaust Clips here plzz
  210. Longer length valves will result in what?
  211. 302 camaro??
  212. Oiling problem
  213. Poll: 245/50-16's or 255/50-16's?
  214. Knock count and PCM learning
  215. WANTED - mjcent922
  216. TPS Question
  217. Jumping in and out of closed loop, split BLMs, and more fun stuff
  218. Alternator wire/plug
  219. Ha another cut out question
  220. what are some indicators of a bad opti?
  221. any good launching tips for a4 lt1 Z??
  222. How easy it is to change the tranny's 5th gear?
  223. Mechanical or electric Autometer, which do you prefer?
  224. Best spark plugs for LT1????
  225. Accel Shortie Plugs Anyone have a part #?
  226. PCM tuning
  227. BMR Boxed SFCs'
  228. Which RTv is best for all?
  229. Electronic Spark Control, Anyone ever use it?
  230. Intermitten start problem. Help.
  231. maf gasket??
  232. Which motor oil weight to use?
  233. Torque Converter Shims
  234. Question about cam install!
  235. Installed my Spohn rear LCA's yesterday
  236. HP with CC306 cam ???
  237. need help quick!
  238. Ok, did a search, still confused...
  239. Piston to valve clearance
  240. new turbo motor break-in?
  241. Solid Roller Stroker Peaking Too Early?
  242. Please help me pick the right gear!
  243. I need Knock Sensor part# for 95 Z
  244. Where to start Diagnosing Missing Power? (Recently dyno'd Solid Roller 392).
  245. T56 swap done... but the starter won't work... dash lights come on... please help
  246. please! please, help me pick a gear!
  247. Are these headers/exhaust good?
  248. Milling heads and compression
  249. Help! Parking brake lever stuck up!
  250. Lower Oil Pressure since Synthetic switch...
