- SOS GOD HELP ME!!! (just came from garage)
- 160° Stat require new chip/program?
- Hp loss with 7' knock retard?
- yall prob know more about this tranny than i do
- CSI elec wp wiring question
- Where can I get pilot bushing (not bearing)?
- Air Intake Duct
- Yes, im a dipstick, i need help with my dipstick...
- I am buying new Heads, cams, headers.. WHICH DO I GET?
- engine light comes on when a/c is on
- Quick question- These are SVO injectors right?
- Codes 32 and, what the heck is 77?
- Anyone have there dash lights go out? not a fuse
- how much HP do you loose if you race with the A/C on?
- Oil pump swap in garage on jackstands, how hard??
- Will 0.19 Amps draw be enough to kill the battery in a few days?
- Can't find last bolt to take tranny out!
- Want to remove PS,AC and heater core
- Tbryne CNC heads?
- 700 R4?
- SLP header install?
- Overdrive on auto tranny
- T56 upgrades?
- LT4 valve covers
- Overheating Problem Please HELP!!!!!
- Has anyone used Cottman transmissions before?
- My New Z
- Need p/n for mass air wire harness pigtail?
- Exhaust manifold studs
- Gear Swappers question
- How do you hook up emissions on passenger side LT?
- Problem - Please Help
- wiring 95car to a 98+door
- What do you guys recommend for a ring gap?
- Intermittent starter problem
- 3.42 & 3.73 A4 people inside please!
- 95 Lowering Kit
- Manifold bolt/nut?
- Stroker is finally ALIVE!
- Need help with Diagnostic codes!!!!!
- OBD1 Manual Fan Switch?
- what info from scanner should i post for everyone to figure out my problem?
- Is it hard to change the EGR value??
- alternator problem?
- R/R bearings in drivetrain??
- Does anyone have, or know where to get, just a starter solenoid?
- New cyclinder heads
- Which 2 intake bolts are used to mount cruise unit over valve cover
- codes 13 and 63..
- 93 LT1 Chips
- Opti vaccuum hose ?
- Easy fan switch question
- confused... how do you bleed the coolant system?
- Broken Bolt in my head :( help?
- Shrader valve??
- Need help with TC terminology
- Strange vibration after I let off throttle?
- LT4 Knock Module ???
- 93 LT1 mods question
- Q's about new Torque converter and mail order tune??
- Scanmaster mounting???
- Just fired up my Z with the GTP's for the first time & have a RR ?...
- Will I be ok with 2 different types of wires?
- Firebird to Trans Am
- Production mubers
- Noise after i let off the clutch?
- What can I use to clean EGR VALVE???
- testing the coil with a multimeter or something
- Throttle body difference???
- Clutch alighment tool specs
- Just bought an LT1... let me know what you think (pics inside)
- Do T56's tend to slip out of gear.
- EGR p/n?
- Z06 Maf?
- Lakewood Lower Control Arms and Panhard rod
- Electronic B&M shift kit just as good as a real shift kit?
- help
- what do I need to do a 2500 mile trip or so?
- Need Ideas For my next Mod?????
- Where can I buy a relay?
- Comp 875-16 Lifters & valve lash question
- Gear Question
- LS1 intake swap...
- Jet-Hot LT install.......done!!!
- Rods
- Bad machine job
- Someone wanted a gear poll...
- Car still aint starting, no spark
- Need amber bulb part number for front clear corners on '94 Z!
- Everyones take on the huge tach shift lite subject.
- Can a breather hurt?
- I don't think it's the intake leaking after all...
- LT1 Dave
- Do the cooling system on the LT1's suck? Yes they do
- LT4 Intake Manifold In Summit Catalog???
- Differences Between '93 and '97 LT1s?
- where do i get these parts??
- Tunnel Brace
- tire size
- Morning Backfires.
- Cheap gas by miskate?
- Msd Opti Replacement
- Delayed start, any ideas?
- Cutting Out MAF Sensor Screens?
- stock sounding cam?
- Idle gets choppy after about 1 minute of running!!
- plug gap ??
- Is the Z28 LT-1 2 or 4 bolt main block
- 4L60-E running to red line before 3-4 shift
- Hey guys will this engine work with my car?
- Where to get a pigtail for 94-95 coil?
- my passenger side fog light went dead!!!
- Coolant light
- p&p heads
- Headers banging on floorboard...remedies?
- is it normal to run this cool after !AIR and !EGR?
- Bolt on 400HP+....How???
- CC's on stock heads
- anyone heard of gm performance exhaust??
- do '93's take platinum plugs?
- Stock LS1 MAF, will it work on an LT1?
- Those with Black camaros....Whats your paint code?
- Which fuel line goes from the filter to the tank?
- Where to mount MSD Digital 6
- Trans, rear end, or suspension? plez help me pick
- PS delete Without Skinnies?
- Max effort LT1 Cam with stock bottom end
- valve / lifter tapping diagnosis - please help!
- Hotchkis lower control arm
- Getting transgo shift kit and new torque converter, do I need reprogramming?
- What is the part # for a Mobil 1 oil filter?
- This noise is driving me crazy, please help.
- Steering Binding...
- code 44 where to start
- lifter swap?
- Last Minute advise..
- What would be some signs of bad EGR valve?
- Another LT4 KM Question??
- What should oil pressure gauge do at WOT?
- LM + LT + Cats
- How can I tell if it is a real lt4?
- Stock fuel pump and injectors handle 375RWHP??
- What kind of lube for pilot bushing?
- rear axle swap?
- Anyone running 236/244 Cam?
- Driving without in-tank fuel filter??
- what causes backfiring, popping sounds...
- optispark problem
- Tapping noise under low throttle
- My AC is going out
- Heads to go with CC305 cam....
- Front cover oil leak -- need advice
- HELP! security light comes on and car doesnt start
- how do i know what gears my car has?
- Cruise intermittently not working?
- LT1 cars
- Can the stock oil pan be used with a 396
- roller rockers
- optispark change in progress...need help
- Hows the change to a 3rd gen rear sway bar???
- Changing optispark drive oil seal, how hard? Install guides?
- Trans Dipstick Tube
- LT1 Problems?
- i cant get traction, and i'm stock! Help!
- throttle problem i think...come inside
- How to lubricate window
- what to do next?
- dipstick problems with new motor (main caps or pan are in the way)
- What is my car's problem?? HELP!
- Replacement Brembo Brakes???
- Decision heads or heads and cam
- Cooling/Computer Help
- PA K Members?
- 12 Disc Magazine
- Cam Gurus Inside Please! Mind34game, Bret, etc.
- What is doing this??
- Scanmaster
- "ABS INOP" light is on
- true dual exhaust
- what mods?
- EVAP canister?
- Are 12's possible?
- How do you guys remove the radiator?
- help, no start
- Saggy motor mounts? how to tell
- 12 bolt? Yes or no?
- Exhaust cut-out make e.t. faster?
- anybody know of a good honest place to rebuild an A4 tranny in NE Ohio or surr. areas
- how to beat a stock LS1?
- MSD wires pictures
- XE 230/236 Questions
- fuel pump....help
- Loss of power, flashes of light around plug area??
- Need a quick accurate answer!!
- where to buy from?
- exhaust cutout??
- OK to use pennies to plug AIR holes in manifolds?
- what if i
- A.i.r. ?
- Cruise Control
- are the tie rod ends actually bent...?
- Just found out I dont have Cruise Control...
- Love My Z
- Where can I find a good fuel filter online?
- 400 RWHP = 0 to 60 in ?
- dash question
- Bleeding Brakes???
- need help fast, car overheating
- Scanned car today found out new opti maybe bad, please read.
- 75 Shot ruin engine?
- Can someone help me on this misfire??
- Anyone have any extra A/C knobs?
- Throttle Body ?
- broke my exuast manifold stud
- burnt coolant smell thru a/c after flush
- AC problems
- Pop-Up Headlight Question
- why does my car pull to the left while braking?
- do you have to degree the hot cam
- stock cam info for 93?
- Cai
- Transmission Cooler Lines
- 94 vs 95 LT1
- Clutch ???
- Help deciding on new brakes and rotors
- Lt4 ported heads
- overheating lt1 help me please
- loudmouth install
- cam install
- noaperformance aluminum valve covers
- cc305???s
- does ABS actually make u stop faster or more control??
- dynomax cat back?
- Oil on PCV
- SLP Air Filters
- Auto trans shifting
- tranny cooler on a stock car?
- Cruise control does not work? Possible problems/troubleshooting
- Thunder racing v.s Ls1speed relialbility
- Knock sensor - DTC 43
- Anyone in the NY AREA, wanna do an intake gasket leak fix???
- Cooling fan assistance...
- Pilot bushing install - bevel goes which way??
- Łncoated Headers Damaging Ac Evaporator Enclosure
- Intake leak damaging clutch?
- Help me understand.
- Manual Fan Switch Problem (shoebox?)
- Do i use copper gasket sealer on my felpro 1406??
- False? knock readings
- Firebird Formula to Z28???
