  1. GP on spec clutches...what do you guys think???
  2. 402.3 RWHP on stock bottom end.
  3. Lt1 Engine Overheating
  4. If the 10-bolt doesn't break...
  5. I very interesting Cooling problem NEED HELP FROM THE EXPERTS!
  6. fuel injector o-rings
  7. car wont run NEED HELP!!!
  8. need some torque specs please
  9. Manual Fan Switch Help ASAP
  10. Can anyone take a guess why my pedal vibrates?
  11. Mushy throttle at low RPM's
  12. I live in the city and I've got "crickets" under the hood...HELP!!
  13. gettin tranny rebuilt...wut kit should i throw in?
  14. what do these wires go to
  15. Just did Over The Valve wires from Thunder..
  16. transmission swap
  17. Just bought 95 T/A, have a couple ?'s?
  18. Anyone with Hotchkin's lowering springs?
  19. code 62 air bag help!!
  20. Why do i have a popping sound from my exhaust?
  21. Are shocks a good mod?
  22. DRL Install
  23. Vigilante converter? Need feedback so I can order it!
  24. Lt-1 Motor Rebuild
  25. Finally went to track tonight, are these good #'s?
  26. SIMPLE question about pcm... please help, please?
  27. How Can I tell if My Car Is Hestitating
  28. Rotors
  29. XE 224/230 good enough to blow tranny on 1st day
  30. mounting pro ratchet shifter
  31. Anyone replaced p/s pump seals?
  32. Transmission preform button
  33. Steering gear, torn boot.
  34. heads and cam help
  35. headers
  36. Crap!!! Need Emergency Help!!!!
  37. Crap!!! Need Emergency Help!!!!
  38. How can i clean my Throttle Body??????
  39. Big day ! Opti / H2o Pump Install, anything I need to becarefull of ?
  40. Removing stem seals
  41. Will these gears fit my car...
  42. Front shock "top hat"
  43. This is funny
  44. This would be easier if I had a torch
  45. Anyone have a second to explain to me what cam surge is?
  46. Where to buy LT1 Engine?
  47. Which camaros have LT1's?
  48. Question about NGK's?
  49. My car makes a funny noise when I take off.
  50. Oil pressure sending switch ?
  51. Need engine help!
  52. brand new dyno numbers
  53. How loud are the rollers supposed to be?
  54. EGR going bad?
  55. After 2 years, same problem...ideas?
  56. California Drivers with SLP LoudMouth
  57. The IAC passage in the intake goes where?
  58. What is the most power you can make with stock heads?
  59. Lunati LT1 Timing Chain??? Anyone got any info on this thing???
  60. need caliper hex bolt size
  61. Where can I get a map sensor
  62. How to remove back seat, pass seat and frnt sway bar
  63. Oil pressure GAUGE drop.
  64. 94Z A4 transmission slips @ WOT 2/3 rd gear shift
  65. fuel filter change?
  66. What is part # 22128877, and do I need it?
  67. Wheels and Tires
  68. Who is selling GM Motive 3.73s right now.
  69. Aluminum Driveshaft
  70. what and where is the icm ?
  71. What FP are you guys running
  72. Seized Fuel Filter
  73. Is it ok to re use rings?
  74. T56 or 4L60E
  75. confused by my car
  76. Look at all the passages in the LT1 INTAKE MANIFOLD!
  77. Is my tranny slipping?
  78. 3.42 gears
  79. Tranny Help
  80. 4:10 gears whinning
  81. throttle body fuel smell
  82. Exhuast too quiet..suggestions
  83. Shoebox or just any body please help!!!!
  84. Need ideas
  85. 60' Times
  86. does this sound like blown rings?
  87. little throttle response
  88. 1LE suspension
  89. Before you go and replace your MAP
  90. All people with DMS springs please
  91. 95 a4 tranny problems
  92. come inside & guess Dyno #'s!!!
  93. Quick newbie question
  94. Amazing thing happened today...
  95. LT4 roller rockers and valve cover part #'s
  96. FNG with car problems. Pls help (long)
  97. F.S.- 1995 red trans am rebuilt everything
  98. Newbie in the Mod Department. Few Questions.
  99. Fuel System Q's
  100. how can i get more traction.., sugestions?
  101. harland shift light
  102. No power steering...please help!
  103. 315 Nitto Drag Radials. What best psi to run them on the street?
  104. Is the aluminum driveshaft really worth the $$
  105. Manifold porting advice...
  106. Help me with Changing Fuel Filter please.
  107. ?'s for guys runnin skinnies
  108. cost to get machine work for bigger valves?
  109. you have $2000 for a blew tranny, what would you do?
  110. Trani Swap
  111. opti idea
  112. Camaro vs Mustang
  113. Cleaning Injectors the right way
  114. how many hours to do rocker swap?
  115. name this part please read?
  116. Anyone using this TB?
  117. Does a gasket exist?
  118. 218/230 114 inside
  119. HELP Heater Hose ?'s ...
  120. Does wheel hop cause damage?
  121. new motor - vibration :(
  122. wires have been arching...........did i possibly damage anything?
  123. running rich...
  124. Help with code 34, MAP sensor.
  125. Z28--------to-------->SS
  126. Coolant Air Bleed Pipe....HELP!
  127. dowel pin length on 95-97 LT1 cam
  128. Almost Threw Longtube Through Windshield
  129. could bad/old plugs/wires cause engine damage?
  130. 6 liter LT1 STOCK?
  131. Which motor oil?
  132. Think I got a bad load of gas... few q's
  133. Dipstick tube and kick down cable for TH350 swap
  134. is a 50gph t rex inline and a stock pump good enough?
  135. getting extremely frustrated
  136. i ran a 115 trap today, et??
  137. How to break in a clutch?
  138. well quickly figuring out total new motor will have to wait. Are heads/cam a waste!
  139. How To Fix A Flaired Cam Dowl........????????
  140. anyone own a 30th LT4 SS?
  141. Which wheels?
  142. Tc?
  143. 4.10s and Drag Radials?
  144. Cant get opti boots on
  145. Royal Purple or Amsoil ??? What's the best ???
  146. Does anyone have the part number for the power window switch LEDs?
  147. help with jethot LT install
  148. shattering noise that happens occasionally
  149. LT1 to LS1 or maybe LS6
  150. ASR install?
  151. tranny install
  152. Synthetics
  153. Battery Dying after a few days of not driving...
  154. What's involved in replacing the seal on the oil cooler?
  155. 18mm Thread
  156. im hard of hearing and need advice
  157. moroso intake is amazing
  158. Roller Rocker Poly locks backing out Help!
  159. This should be my last jet hot lt install?
  160. How much power differenve between??
  161. 380+ hp w/ 8.3:1 compression, what octane fuel?
  162. AC Delete question
  163. replaced clutch and it still rattles... WTF!?
  164. what header bolt lenght w/ hooker shorties
  165. can someone direct me
  166. TDC question
  167. Does the Opti include the cap and rotor?
  168. alternator problem
  169. hmm... someone help me out on this one..
  170. *pics of spark plug tips*.....these look ok?
  171. what fuel pressure
  172. What is this?
  173. Intake gaskets - dry or use sealant??
  174. Clutch won't disengage?!?!
  175. A4's with 3.73's inside.
  176. high flow cat
  177. Question on Catalytic Converters
  178. Realistically, what does it cost...?
  179. Vats Security light ?
  180. Removal of ABS system
  181. Need a Fuel Pump Bucket
  182. What is a good streetable clutch?
  183. my first dyno #'s
  184. Can I test the EGR with the car off??
  185. PWR Window & PWR Door Question..(Shoebox or other) please enter:
  186. Help me pic my next mod please
  187. ARGH!!! Help w/ Ignition Switch!!!
  188. Aeromotive AFPR
  189. i dont know what else to do car still stutters and surges please read
  190. just installed PRO 5.0
  191. 94z obd connection
  192. Im gonna f'ing blow my car up
  193. Tail lights took a dump??? WTF??? Help!!
  194. A/F ratio in the 16's!!!
  195. are the coolant flushing kits any good?
  196. A4 problems... AGAIN!!
  197. one range colder than TR6?
  198. heat soak
  199. Is it time for a 12 bolt?
  200. Broke Oil Sender Sensor/Unit During Tranny Install
  201. Silicon Hose Help Needed
  202. 02 firehawk exhaust on 94?
  203. How many of you tune with AutoTap and a Translator?
  204. dynoed my formual today
  205. two ?'s, $ for sfc install, won't pass smog w/ cutout?
  206. chip install
  207. How do I set the valves?????
  208. Anyone who has done auto to 6 speed in please!
  209. rocker swap not going well at all
  210. better hdlts. for 93-97 Firebirds
  211. Engine noise on cold start
  212. Tranny Problem Please Help
  213. Quick ? about NGK TR55GP Platinums.
  214. Vette starter
  215. Brake help
  216. Cooling fan problem, somebody explain how they work?
  217. Power seat acting funny!
  218. Question about getting into the 11's
  219. 170k miles on a 95' z28?
  220. T/A front facia
  221. Dual LED electric WP schematic?
  222. Code p1441, Evap Hose Leak Question?
  223. Quick question
  224. Need suspension help!!!!!!
  225. Where can i get a holley SS air filter
  226. Spec stage 3 aggressive? Um no!
  227. fuel pressure regulator
  228. Hot Cam or XE 224/230
  229. o2 extension install
  230. LS1 MAF on an LT1 motor
  231. need help A/C removal or any other weight reduction
  232. engine light mystery
  233. which headers? whats the difference ?
  234. 3.42's stock in A4 1995 Z28?!
  235. 4L60E tranny rebuild price
  236. How do Rockers get Oiled when using Solid Lifters?
  237. 4l60E prob. reverse
  238. clunking noise when I engage my clutch w/ new engine
  239. Trans Am Bit the Dust
  240. opinions on lmperformance.com
  241. Any 93 owners out there change their own EGR???
  242. Writing transmission program out of computer
  243. 200R4 to replace 4l60e in 95 T/A
  244. My boost gauge is hooked up the EGR vacumn source...
  245. How bad will a slipping tranny affect dyno numbers...
  246. Take a look at my Sig
  247. Made a BET, NEED PROOF!
  248. How to change fog light bulb on 95 T/A>
  249. Hard to start?
  250. How much did you pay to lower your car?
