- Double springs on LT1 heads?
- Cat flow question
- Check this out!!!
- what gains from a 2800 stall?
- Clutchless Shifting??
- QUICK SURVEY: LT-1 Tune-Up Quotes you've gotten from Dealers/shops
- Anyone Using The Borla Muffler Only?
- computer relearning?
- Oil leak
- Short in MAF wiring how to test?
- Mustang GT ->Camaro Z28 Transformation
- LT1 vs. LS1
- car hesitating
- tuning when i put 3.73s???
- Will SES flash from trans. problem???
- Hard to start and idles between 1500 to 2000rpm?
- odometer fraud!!!!
- Would this help or hurt on 1le lca brace and panhard
- LT4 Hot cam question
- what is the correct way to use sea foam deep creep for tb
- On the quest for 12.5x or better
- Where Can I Get A 1le Intake Elbow??
- fuel rail question
- What is ment by bolt on?
- Code scanners
- gmmg catback?good?
- People with GM847 inside!
- Do I Stand a Chance??
- HELP...annoying vibration
- Which Is Bigger Cc305 Or Hotcam???
- Pulling motor.
- IAT Relocation
- Which gears to get????
- transmission shop problem
- Should I get a Dynotune with these mods?
- Need info. on Caprice 9C1 police package??
- Paging Brent94Z!!
- Opinions Please!!!
- Need Opinions on TPIS LT1 405HP Engine Package
- lsa...108 or 110..undecided...help...
- 95 Z wiring diagrams
- Howd I do on these Prices (Heads/Cam)
- anti-seize on header bolts??
- Did anyone get their heads and intake port matched?
- What is this trans worth?
- Purchased hotcam today
- LT4 Conversion
- any company selling cc305 cam kit??
- Opti-spark
- Putting engine and trans back in together (Conected, one piece.)
- is it possible to install old style block on our cars?
- threadlocker on all bolts?
- balancing eagle 396 stroker kit? does it require mallory metal?
- Estimate
- What valve springs for cc306?
- McLeod Street Twin ... chattery?
- GMS Z06 MAF vs. GM Z06 MAF ? ?
- Walbro 255lph intank
- tunning questions
- Problem after I took alternator apart...
- Which offset for 17x11inch rims?????
- What is it? and do i need it?
- 58MM Air volume?????
- IAC part number??
- Anyone Running 4" Cat-Back??
- insane exhaust ideas??
- saving the rear with an M6
- coolant leak help!!
- 3" exhaust over the axle?
- GM 12370846 cam
- Need a converter.
- Anyone purchase from cmotorsports before?
- any track results with MW converters?
- Timing Chain options?
- Drag Radials
- First mods
- First modifications?
- trans blanket?
- Aluminum Driveshaft
- Any problems with main studs hitting oil pan?
- 160 Thermostat needed with Jet Fan Module??
- Guideplates?
- emergency brack no longer works wtf?
- exhaust
- Underdrive Crank Pulley
- Opti
- Edelbrock Lt1 Heads
- HELP ASAP! CAR wont start
- 94Z Runs rough intermittently.
- Where Can I Buy A Throttle Body Shaft
- heater not blowing hot
- starting problem
- Anybody know the number to speed automotive?
- got ahold of a tech2 for a few minuites... what might these values mean?
- brakes
- Spark Plugs
- I am new
- Okay to re-use head bolts on the LT1???
- Heads and Cam
- Ignition wire/coil survey
- Does anybody have the e-mail phone # for Dale
- Guys I need a 93 throttlebody
- Clip holding TO bearing on new PP.
- McLeod Street twin master cylinder:
- Great read for new owners and older
- Best exhaust for 95 z28??
- how tell what gears
- SLP or ASM Headers
- car help
- hotcam canada
- Can I do anything wrong by setting my detent cable too tight or too loose? (93 Z28)
- how much hp from an aluminum driveshaft
- low mount alternator braket
- Strut tower brace install
- Mtrhd13
- Fix for scratches in your windshield?????????
- Need basic Exhaust Help
- Long Tube Headers a wise choice?
- o2 sensor question
- Help with Holley TB
- Someone please help quick!!! (starter problem)
- pics of single turbo
- What do you think of this cam?
- Over Opti, any alternatives.
- what tranny is in my car?
- Trying to find out the height from the ground to the bottom of a stock exhaust tip
- Cam Surge
- Looking for bearings. Main and maybe rod.....
- 58 mm tb size
- gear change
- What LT1 year do think is the best??
- Mysterious oil leak?????
- What Ya' Think?
- slp header install questions
- FAST with dif ignition system?
- Oh "Darn"!!! Borla Owners Come In Please! (edited by moderator)
- DMS SFCs?
- So, when are the Bilstein HD going to be back in stock?
- Stock Cam Specs?????????
- lingenfelter 58 mm TB adjustment questions..
- Upgrading to a 4th Gen
- problems with axle removal!!!!
- Best First Mod?
- If I want to Have LT4 clutch
- Oil Leak Help.
- creaking steering
- LT4 Conversion
- Bank1 . . driver or pass side??
- just sent my pcm to brian
- Best Aftermarket Shifter
- vibration at highway speeds
- Changing main bearings w/ motor in car?
- Magnaflow on an LT!
- high flow cat?
- Swapping the V6 for an LT1??Help Needed
- cat
- cant get M6 into reverse
- help! cant not set valve lash
- Oil Leak
- suspension
- Who would you bring your LT4s to, to get ported?
- Question for Texas F-Bodies
- Is this seal replacable easy?
- Best $$$$ deal on LT4 heads
- More horsepower?
- Role cage
- Air Pump?
- Coolant Loss?
- leak update
- strange problem w/ motor swap
- Quick hot cam question?
- Does anyone know the difference in head bolt torque between 95-96?
- Stock Injectors
- Adjustable stops on Pro 5.0?
- headers again
- Need a car-fax please
- Cam and valve spring Q's
- Longtubes Or Roller Rockers
- heating the coil springs to lower the car?
- Is single Disc Mcleod clutch right for me?
- Non LT1 ??? (You guys are good so I know someone knows)
- Sounds of everyone's exhaust set-up
- squeaky clutch??
- XE 224/230 w/ hot cam kit? can i do that?
- "Darn" Brake Pads!!!! Help!! (edited by moderator)
- Quick Question
- What oil is right for me (dyno too)
- Is it in my head that my Z is really that fast.
- Headers- for my car long or short- please help.
- OH CRAP! I need help please, my friend fried my car!
- Spec stage II clutch and LT4PP installed. Question..
- T56 rebuild...anybody done it
- 4L60E Shift Improvement Module (Automatic)
- Please advise...heater doesn't blow hot for long...
- Where is the BEST/CHEAPEST place to buy gauge pods and gauges??
- I need a decent clutch kit which can hold up to a 383... at least for a while :)
- Windsheild wiper problem
- Hey Shoebox...
- $$265 for motor???
- shifting 3rd at 90
- Gauge cluster switch in lt1
- what do the fuel corrections sit at on a car with nothing wrong?
- Spal fan vs. dual lt1 fans
- are Relocation Brackets worth it with stock springs?
- T-56 transmission
- Why does the PCV just does a horse shoe back in?
- Torque Converter
- Can I remove the CAT at home?
- CAM Questions
- How do I read injector pulsewidth in Spd Dens 93 and 94-95 OBDI LT1 cars
- Poping noise while steering
- Swap LT1 rear to LS1 style Q's
- has any one rebuilt or bought a rebuit opti?
- Looking to buy 95, valve train noise, need advice
- slp LM+quad kit installation?????????
- Codes P1416 and P1657?
- hesitation only in open loop
- SLP header for 1994 Z
- electric water pump or not?
- Copper tubing alright for TB Bypass?
- QUICK HELP PLEASE: Will an LS1 FE2 steering rack work in my 94 Formula?
- Header Gaskets
- Shooting Falmes?
- Brakes
- What Cam Is Bigger Than Cc305 But More Streetable Than Cc306??
- Difference between 1LE and BMR
- 383 with stock heads?
- Lt1 Tb
- Just hit 83K on my car...what sensors plugs wigits and dodads need replacing?
- cutout running open for the last 2 years now. plugs go bad now??
- Question about O2 sensors...
- PCV inline filter or passenger side filter?
- cat back questions
- What gauges?
- 2.73 to 3.73
- Readend Question?
- Do fuel pressure regulators rarely go bad?
- Cost of salad shooters
- anyone do a head swap with motor in the car?
- which 17x11 to get..the GS rim or the regular corvette zr1 17x11??
- Changing Spark Plug wires ?????
- Please Help,cant Leave My House!, Car Just Died!!
- 383 or 396 Stroker kit?
- Please Help Me, My Car WONT start
- Is it a V6 or V8?
- Mechanics in Jax Fl.
- Coated header cleaning & polishing??
- Goal- 320rwhp
- What is the heat range(#) of the stock spark plugs??
- DSM Suspension?
