- New idea in header bolts
- B&M trans cooler
- Oil and smoke out of exhaust on start up??!?!
- Not any normal 12 bolt question
- V6 to V8???
- vented opti conversion - parts needed??
- Trouble with new motor...
- Best Methods For Changing Passenger Spark Wires
- Tranny bangs on downshift
- Wires and Plugs?
- Changing oil pan gasket in car---Any tips??
- need help on line lock slp
- Someone needs to make a coil pack conversion kit
- Problems with monster tach....
- how do i fix this, and how much?
- Block decking questions
- Block decking questions. Need help
- Please help, car died and won't start
- putting the drive shaft in?
- After 1.5yrs of bickering, did we figure if our flywheels are nutral balanced???
- help with SFC
- My car has 2 problems!!
- Dexcool, or the green stuff? (max cooling)
- Problems all fixed... now mods... advice?
- Is this rocker ruined? I bent a HARDENED pushrod?
- When backing up I sometimes hear a "thud"
- Help Blue Smoke
- quick dual exhaust question(s)
- EGR gaskets?
- 383 Stroker and Cam question
- Backfire!
- Please help with my engine build up.
- tranny temp
- Intake elbow's- Vortech vs. Stock
- green vs red ! (coolant that is)
- How to: Cam install
- Easiest way to put door panels back on?
- Lt4 Km
- a/c pressure level?
- a/c clutch
- Oil Weights and Ratings
- !CAGS question
- Anybody had thier car weighed at a truck stop?
- I can tell you how to improve PERFORMANCE and GAS mileage IN HERE
- HP Diff. between the mild cams?
- 355 rebuild Q & A
- Strut Tower Bar
- What bulbs for orange display backlighting on stock 'Bird stereo?
- Changing the clutch
- LT4KM part number
- Has anyone passes Emissions with LT's ?
- stock heads, worth XXX$??
- How to raise IAC counts?
- anyone using wilwood kits from summit?
- How to plug CAI after !AIR??
- hot cam install ?
- Does it hurt to leave the cut-out open all day and night?
- Removing the A.I.R. Pump???
- coolant crossover tube
- Are LT4 & LT1 spring seat diameters the same?
- What size are the LCA bolts?
- evap code 1441 ???
- Best header bolts? need to order today!
- part # for clips on power window/door lock panel??
- Help with low vaccuum readings?
- testing vacuum/sensors/etc
- taking my car in shop
- Question on measuring cams
- Y-Pipe
- HELP?! Reverse problems...
- LT's over Shorties?????
- A few ?'s while I'm doing the LT-1 to LT-4 conversion package.
- 95 Z28 Suspension
- WS6 Ram Air Box
- Wow, is this board slowing down, I ask too many questions, nobody likes me, lol???
- SLP Stall.......Yes or No?
- Main Bearing Cap Wear Marks????
- The A/C or fan will NOT work, why?
- airbag light
- 160* thermo question
- Converting my OBDI car to speed density? maybe? maybe not?
- any gains from having a throttle body airfoil?
- 2.5 inch yipe vs. 3inch ypipe
- Tuner Cat A4 Shift question
- What hose is this?(Radiator to Waterpump)
- HP/TQ gains from 224/230 cam set???
- Getting the shaft.
- How to flush with electric WP
- Stage 1 and 2 heads......3?
- Spec stage 3 ceramic wearing out after 2500 miles???wtf
- Stall converter! Need as much feedback as possible.
- Preparing for a cross country drive. Anything I need to do beforehand
- Tranny suddenly not grabbing 3rd
- how the f*#@$ did this happen? my opti outlasted my engine. how much to rering/rebld?
- Need to adjust TA headlight in down position!
- need part number for LT4 egr blockoff plate
- digital dash
- Who has the most miles on their original opti?
- Yet another problem.
- what is this hose called?
- Electrical Problems! @$*&%
- Just installed SLP CAI
- Show me your custom T-56 floor jack mount
- A/C keeps quiting on me in hot weather, using HPP to restart computer??WHY??
- Trans Grinding HELP
- Quick/Easy crank/timing queston
- LCA Relocation
- Where to buy solid/poly engine and tranny mount?
- TB bypass, help
- will i lose low end with Lt's and xpipe true duals?
- Mass air Senser
- Mindgame, come on, tell us more about your car!
- back to fuel smell battle
- Easy question for ya.
- need part # for lt4 (plastic) valve covers
- cant get ngk platinums
- "LT1 ported mass air flow end" is it worth the money??
- Cheap OBDI scan tool
- running car without thermostat?
- Do you need a X-PIPE on true dual?
- anyone using raised guideplates?
- 86,000 miles, think i should do the valve guide seals with the spring change?
- can raised guideplates be used on lt1's?
- slp line lock help!
- Timing Gears
- What should I replace before this cam install?
- ATF in t-56, why?
- Argh %$#%$#
- Uh Oh! Ticking sound....suggestions?
- Bryan Herter ( www.pcmforless.com ) delivers BIG TIME! AGAIN!!!
- Looking for flow numbers!!!!
- clutch alinement tool
- Stuck Convertible Top TSBs?
- Need Help Locating a Dyno shop
- I need plugs for A.I.R. fittings in headers
- 99,000 miles on original plugs and wires... anybody do better? :)
- Anyone ever use Type F in a 4-L60E?
- Speedo not working..
- WTF?!? Am I doing this right???
- power windows???
- Automatic LT1...engine dies
- looks like I get to drop my oil pan :(
- Spark Plugs SUCK
- Oil Pressure Fluctuations
- 2 1/2 in duals or 3 in cat???
- What STALL CONVERTER to go with? Please Help
- Coolant cross over tube question
- Help me spend my $Money$
- I need some info on a fuel pump please
- What could cause a reverse lockout not to work?
- Exhaust cutout ??'s.. anyone?
- Rough idle question and o2 sensors question
- Stock fuel pump with SVO #30s?
- HV pump and stock pan ?
- When should the o2 sensors be replaced?
- My Z28, A love/hate relationship (long)
- Ovc?
- How hard is it to get the manifold bolts off?
- oil leak problem...
- Cam Selections and TQ Area Under the Curve
- oil consumption thru throttle body possible?
- Vig 2800
- Th 350 swap
- redline
- '97 up opti and spark test?!
- What exhaust should i get...someone help plzz
- Rebuilding tranny....
- Offroad pipe with Hooker Cat Back.
- SES Light On - Suggestions?
- Y-Pipe for Jet Hot LTs???
- ta ta ta t atatata ta ta ta TIMING!
- PN Lease!
- Need help with tires
- camaro LT1 chasing a bmw M3
- How does an engine management system interface with PCM?
- need measurements of EGR blockoff plates and TB plate
- Upper AC vents stopped blowing
- hey shorbox... have a picture of this part #?
- Car options.
- Why do they make adj. LCAs?
- AS&M Install Question?
- Corvette fuel rain covers and traction control....
- Where to get cheap 02's.
- anyone have pics of their car lowered?
- How much HP is a stock clutch good for?
- Anyone run straight h2o and water wetter in the summer?
- Is a MSD 6A worth the money?
- Turn Signal problem
- Plugging EGR vacuum lines?
- good setup for not spinning?
- are my headers leaking??
- Canton Oil Pan # 15-244T (vs) 15-242T
- Shoebox ??
- Car Won't Start, Help!
- cowl hood
- Question about A4 transmission.
- Looking for Rims....Please help!
- All with Stall Converter!!!!
- Things to know before buying a 9"
- map sensor part #
- knock module ?
- opti spark ?
- did i get screwed?
- serpentine belt (help please, quick)
- 396 Stroker GP packages added
- electric waterpump install question
- Wha is the best shop for T-56 tranny work??
- Just found out that my blown head gasket is perfectly fine!!!!!! WTF
- Shift light
- Throttle response and hesitation bad
- OEM vs. Aftermarket Fuel Pump
- a/c clutch?
- Red line
- 1.7 ratio on an LT1?
- did many 97 camaros come with aluminum driveshafts?
- Bmr Relocating Brackets
- Clutch fork slipping off when installing slave cylinder
- How many runs on a bottle of NOS?
- A/C fuse buster
- ATTN: Everyone who had problems the same day they used seafom...
- 18 inch rims all around?
- parking brake
- Any Tricks to yanking the alternator pulley?
- SLP header install question
- Fuel System Problem - Need Help
- muffler part# for duel exhaust
- Car spudders and back fires from intake
- Stroker kits ???
- Crane Gold 1.6 3/8 self-align
- What PSI for street tires at the track?
- part-throttle hesitation
- Do I remove front Radiator when removing AC???
- Question about clutch and tranny
- Low Coolant Light
- Is a 700R4 just as strong as a 4L60E
- Help me decide..
- Wheel Hop
- How to check for a fouled plug
- How to test Oil Pressure Gauge??
- Remove crank pulley for doing wires?
- motor mounts
- new clutch, synchros, flywheel... Opinions?
- rear axle fluid change
- Clutch bites hard..
- Removing Entire EMISIONS from car
- How wide of a tire will fit a15x8 rim
- Cam question
- 600+ hp. 3.42 or 4.10 gears in M6?
- 3.42's alright with 2800 stall?
