- Factor freak?
- Air/Fuel gauge..useful or eye candy?
- Need Help Car Still Wont Start
- What to expect with jet hot lt's??
- Need Help with plug/wire install
- loud *click* after i let off the gas?
- camber prob on rear? wtf?
- Nedd step/step install info on trans cooler
- Valve-Springs, Lifters, Pushrods
- Front Camber ?
- Whats this noise when its shifts?
- smoging in cali
- edelbrock shorties with off road pipe + dynomax muffler = cop magnet??
- My Z28 stalled in the middle of nowhere
- help!...please
- crumpling tin cans sound
- Will this O2 Idea work
- cc 305 guys inside please
- Hollow clunk
- Stage 1 or STage 2 heads?
- 1.6 magnum question.
- Late Night Help -please-!!!
- just when u thought a question couldnt be dumber
- Exhaust question on headers/catback
- Has anyone tried this
- Running Rich, flooding while driving
- Swap
- Going to Get heads today Quick Question
- canton pan fitment problems!
- Injector Help on 96 Ram Air
- A wet dog in my car?
- opinions on Kieth Black pistons...
- Drive Train Clunking driving me nuts
- dyno numbers are in and was hoping for more!!!!
- Anyone else have rattling in the back?
- car fells like it falls into neutral
- Need a part#
- Transmission whine
- Why does this part # = a "valve kit"
- Need GM Part No. for 3.73:1 gear set.
- Help! Please! Opti ?
- plugs and gap with a 150 shot?
- wheres the fuel filter and how do you change it?
- Hypertech shift firmness
- How long did it take you to swap converters (at home/no lift) - and torque specs
- Open loop/closed loop question:
- Opti Contact vs cylinder
- Knock sensor ses.
- Transmission Mount Help!
- guide plates vs. self aligning rr's
- Transmission wiring (m6-a4, 94-96)
- Car over revs
- electric cutout dying after 1 day?
- car wont start, not battery or fuel pump
- AIR pump bracket bolt size
- At idle, car's rpms lower after a while and SES light comes on????
- guys with camaro parts book- need part number
- Idle Problems
- Scanmaster and LT1 Edit
- HELP!! misfiring on the freeway
- Best Street/Strip shock/spring combo?
- any scanning freeware for OBDII?
- New Spark Plugs
- What's acceptable knock retard readings?
- HP loss from to running high octane fuel
- Oil Coated inside of intake manifold, how to prevent it.
- Doing front alignment with string.
- Anyone running the LPE 3.5" Alum. DS?
- Car wont start!?
- Will the SLP DS LOOP work with a 3.5" DS?
- How to get into the high 10s N/A?
- swaping from 4l60e to th 350
- push rod lenght for afr 210
- Suspention
- Slow Acceleration
- Whats this Valve For
- Code P412, Fuse Blows, Mechanic said:
- Keyless programming
- stock LT1 specs
- Engine refresh versus rebuild
- Torque arm mount bolts type
- Quick 12 bolt rear question....
- How do you degree your cam?
- rear end question. 2 problems.
- Regarding the SLP Linelock, for anyone who has it!
- Quick Help !! EGR Line Broke off Manifold
- anyone with NO leakage or dipstick problems with a Canton pan?
- Running in Speed Density
- Got my jet hot lt's today got a ? about the drivers side?
- How much is new egr valve from dealership?
- CC306 on a 114 LSA
- belt for underdrives...small problem...
- guys who did head swaps with motor in the car-
- Opinions before car gets worked on
- Please help me with my bad idle problems
- How correct is the HP Calculator
- What rims to get?!
- I no longer have posi traction, how bad it that?
- where the heck is the sensor for the evap system?
- More power with .600 lift cam?
- federal mogul.........
- Guys with 230/236 on 6M...I need honesty.
- Is there a torque seqence for the intake man. bolts?
- AC Bracket question
- 2 questions:smell gas while driving & car runs hot
- Knocking Sound
- Ive got anifreeze coming out when i drain the oil
- Bad Lifters Or Not?
- can i take the heads off without takeing the intake off?
- Cooling fan Mod.
- Anyone been able to take the clutch fork out "without" taking the 6sp trans down???
- gears and rear end...come inside
- All those connectors on the T56 tranny?
- Hydralic Roller Lifters Vs. Solid Roller Lifters
- found this in the door panel...what is it?
- HELP: car dies as soon as hits 3k rpms?
- Intake manifold gaskets, put on dry or a spray on sealant?
- biggest slicks possible? And what brand to get?
- ported LT1 heads VS ported LT4 heads
- Intercooler Needed
- 4l60e
- Dissapointed with my heads/cam results. Any suggestions?
- i did a search
- Okay everyone, list your low gear, 2k V-light throttle surging fixes
- Help with fuel line disconnects?
- Found a cut wire near tranny HELP!
- HELP SHOEBOX! Broke A.I.R. Diverter Valve
- Need bolt size for tranny mount.
- starting problem
- Oil Pan and Oil Pump
- URGENT! What is the correct voltage for the TPS at idle?
- Tuning for 1.6RR's and stock cam??
- WHat percent does the rev limiter kick in before the push rods bend?
- quick msd ignition ??
- Header Bolt Help
- oil under intake manifold
- biggest gains from heads and cam
- back up lights
- length of axleshaft please
- Tall Aftermarket Valve Covers PICS INSIDE
- Which intake elbow is best?
- Where to buy an electric exhaust cut out (prefer 4")
- wtf!
- Tubular K member install questions
- LT4 heads and Hooker LTs
- How long for Harlan shift light to come?
- third gen IROC 17in rims on fouth gen
- Is this the right cable to get my pcm tuned by pcmforless??
- Call me crazy but...
- Chewed On Another Opti =)
- LS1 Brake Upgrade ???
- Headliner Price
- Wrong stall converter?
- Ever ran the same ET 4 times in one day
- How often do u change spark plugs?
- How do you pull off the rear side panels?
- Where can I pull switched 12v power under the hood????
- Tune Up Help!!!!
- LT1 383 GP Going on
- Coating on MAC headers...HTS???? quality????
- What Cat-back should i use???
- Change cap and rotor, yes or no.
- Post you exhasust sound clips please!
- 3" exhaust cutout plates?
- Latest mods...
- Starter Clicks But No Start, Any Ideas?
- Ratchet Shifter
- Post timing chain break........valves trashed and need opinions
- oil cooler removed, observations
- Ordering SLP 2OTL today....will it interfere with SFCs though?
- New Here....My Car w/ Pics and Dyno
- another thread about a header leak!!
- front rotors
- Bat kitty?
- Could i put chrome polish on my headers??
- After Market Oil Cooler Question
- Question on O2 Sensor's
- Going to the track,need to pick up a couple of tenths
- Does My Motor Need Rebalancing?
- Immediate Help Please
- T56 on Ebay - Questions
- How to recharge A/C?
- Shoebox, here is one for ya! What timming set works with 97 lt1??
- Width of the rearend?
- tell me if this sounds like the opti
- Have they come out with anything new to remove/replace our crank hubs?
- Has anyone ever taken there belt off on a pass
- Whos 6 speed tranny growls at them comming out of first with little gas?
- Engine vibration
- D'oh!
- Little help with header install...
- DS Removal/Intallation
- long run Lt1 would be more relyable
- hey shoebox (or anyone else who may know)...quick window question..
- Vert's Frame Weakness
- Anybody know anything about Ohio laws
- Just installed lt4 km.
- Local dealer is a joke
- Grip's T-top conversion
- someone please tell me how to insert pictureson here, i have my dyno-graph picture...
- My brakes squeal, and they are not worn out!
- Fuel Pump Bucket Glue??
- Pulling A Piston
- ignition switch location on 2000 sunfire?
- Car misfiring through entire RPM Band
- What to clean intake with (off car)?
- What to clean fuel injectors with (off car)?
- is this article accurate?
- hose
- U-Joint Q's
- Power window motor
- 85mm Z06 MAF conversion for '94-'97 LT1
- Bad miss in upper rpm's need help!!
- Can me and 2 of my friends install jet hot lt's in 6hrs on a lift?
- pulleys
- Can you completely remove..
- Corsa exhaust finally installed
- Z06 MAF wiring
- Quick ? about Eagle ES rods
- Why can an LS1 get into low 11s.....
- Suspension Issues?
- might help someone out
- anyshops in Md. that dyno tune w/ LT1 Edit?
- GM or Electric waterpump?
- Needed LT1 wiper arms, or part numbers
- fluid
- Pilot Bearing Removal Help
- Benifit of V6 springs on rear?
- 95z exhaust
- Fed up! PLEASE help! Surging at idle, stumbling/hesitation
- Update!!
- Finally have photos
- Code 32. EGR.
- How to pull crankshaft hub?
- hooker vs. flowmaster
- How much for a cam install???
- LT1 edit questions
- New Source for Built Transmissions
- Need Help.......115MPH?????
- Racetronix dual intank pump
- Valvoline Max Life
- DIfference Between Sealants???
- Transmission Cooler Line - Double or Single Flare?
- Connecting Fuel Lines????
- elect. short
- Good News For ALL Opti Owners =)
- LS1 brake upgrade question
- rattle from rear driver side hatch area, ideas??
- Wash lifters using a solvent or mineral spirits???
- Brass pilot bushing FYI
